Hey guys, I could use a little help. For some reason the last time gameex updated for me it caused a problem and I had to revert to my backup config. That fixed everything except that I didn't disable updates after that. I assumed that I must have just had a bad download. The latest update made gameex freeze at the loading screen, so I went ahead and did a system restore to an older date and now I get an error code going into Gameex. I have attached my log in the hopes that someone can sort it out for me. It seems to get stuck at some system database. Any advice on how to proceed would be greatly appreciated.
This is either data.mdb is corrupt or your system is missing some componenets. Although that normally happens with lite installs. You can try removing data.mdb (back it up) and install GameEx. Otherwise only other option is a new windows install I am afraid.
