Basics:
GameEx 12.24
Mame64 .144b but the same thing was happening in mame .143
Mamex per the command line is putting out:
Running: cmd.exe /c C: C:\Emulators\MAME\mame64.exe macrossp -rompath C:\Emulators\MAME\roms -nowindow -joy -skip_gameinfo -mouse -bezel -artwork_directory artworkgameex
Both the -artwork_directory and -skip_gameinfo are giving me an unknown option error and returning me to GameEx.
From a dos prompt I can type the same command line sans the two offending options and it works fine.
It seems to be any vertical game that would use a bezel. You can see from the artworkgameex that I'm not yet trying to do anything fancy.
I found another post that seemed to indicate problem solved via updating the game list but no joy there for me.
Here is the entirety of my log.txt:
14:53:22.7 11/15/2011: Opening Configuration File
14:53:22.8 11/15/2011: GameEx: Version 12.24: Starting Log
14:53:22.8 11/15/2011: Operating System Platform: Win32NT
14:53:22.8 11/15/2011: Operating System Name: Windows 7
14:53:22.8 11/15/2011: Operating System Version: 6.1.7601
14:53:22.8 11/15/2011: Aero running
14:53:22.8 11/15/2011: Initializing Vista/Windows 7 volume control
14:53:22.8 11/15/2011: Intel® Core2 Duo CPU E4500 @ 2.20GHz, 6142MB
14:53:22.8 11/15/2011: 2.2Ghz - 2 Cores or CPU's
14:53:22.8 11/15/2011: Running Randomize()
14:53:22.8 11/15/2011: Loading PlugIns
14:53:22.8 11/15/2011: Checking for applications to Launch On Startup
14:53:22.8 11/15/2011: Running Misc startup tasks
14:53:22.8 11/15/2011: Setting Menu types
14:53:22.8 11/15/2011: Getting Configuration Values
14:53:22.8 11/15/2011: Using Theme: Default - Women We Love To Play
14:53:22.8 11/15/2011: Checking for alternate Image Directory for Theme: Default - Women We Love To Play
14:53:22.9 11/15/2011: Launching HideOS.exe
14:53:22.9 11/15/2011: Initialising Video/MNG DLL's
14:53:22.9 11/15/2011: GameEx will check for media insertion (may affect performance)
14:53:22.9 11/15/2011: Hiding Taskbar
14:53:22.9 11/15/2011: Is Media Center running?
14:53:22.9 11/15/2011: Checking/Creating LCD Registry values
14:53:22.9 11/15/2011: Check Media Center Exit/Start Mode
14:53:22.9 11/15/2011: Media Center Mode 2
14:53:22.9 11/15/2011: Video previews on. Warning: Only recommended on modern systems
14:53:22.9 11/15/2011: Snap Delay set to: 2
14:53:22.9 11/15/2011: Get other settings
14:53:22.9 11/15/2011: Desktop set to Hide ICONS and set Background to Black
14:53:22.9 11/15/2011: Set: Find emulator artwork on best match basis
14:53:22.9 11/15/2011: Start work for Form
14:53:22.9 11/15/2011: Getting Original Screen Size
14:53:22.9 11/15/2011: Opening Database Connection
14:53:23.0 11/15/2011: Initializing Component
14:53:23.0 11/15/2011: MAME Path is: C:\Emulators\MAME
14:53:23.0 11/15/2011: daphne Path is: C:\Emulators\Daphne
14:53:23.0 11/15/2011: daphne EXE file is: Daphne.exe
14:53:23.0 11/15/2011: Use daphne on. Daphne.exe will launch games
14:53:23.0 11/15/2011: MAME EXE file is: mame64.exe
14:53:23.0 11/15/2011: ROM Path is: C:\Emulators\MAME\roms
14:53:23.0 11/15/2011: Catver.ini is located at: C:\GameEx\DATA\catver.ini
14:53:23.0 11/15/2011: controls.ini is located at: C:\GameEx\DATA\controls.ini
14:53:23.0 11/15/2011: History.dat is located at: C:\GameEx\DATA\history.dat
14:53:23.0 11/15/2011: nplayers.ini is located at: C:\GameEx\DATA\nplayers.ini
14:53:23.0 11/15/2011: command.dat is located at: C:\GameEx\DATA\command.dat
14:53:23.1 11/15/2011: MAMEinfo.dat is located at: C:\GameEx\DATA\mameinfo.dat
14:53:23.1 11/15/2011: Loading Controls.ini map file
14:53:23.1 11/15/2011: Snap Path is: C:\Emulators\MAME\snap
14:53:23.1 11/15/2011: AVI Snap Path is: C:\Emulators\MAME\video
14:53:23.1 11/15/2011: Flyer Path is: C:\Emulators\MAME\flyers
14:53:23.1 11/15/2011: Cabinet Path is: C:\Emulators\MAME\cabinets
14:53:23.1 11/15/2011: Cabinet 3D Path is: C:\Emulators\MAME\cabinets3d
14:53:23.1 11/15/2011: Title Path is: C:\Emulators\MAME\titles
14:53:23.1 11/15/2011: PCB Path is: C:\Emulators\MAME\pcb
14:53:23.1 11/15/2011: Artwork Preview Path is: C:\Emulators\MAME\artwork
14:53:23.1 11/15/2011: Panel Path is: C:\Emulators\MAME\cpanel
14:53:23.1 11/15/2011: Manual Path is: C:\Emulators\MAME\manual
14:53:23.1 11/15/2011: Icon Path is: C:\Emulators\MAME\Icon
14:53:23.1 11/15/2011: Marquee Path is: C:\Emulators\MAME\Marquee
14:53:23.1 11/15/2011: Applying Language/Text
14:53:23.1 11/15/2011: Text/Language: English
14:53:23.1 11/15/2011: Loading Custom Emulators
14:53:23.1 11/15/2011: Loading Emulator 2: Nintendo SNES
14:53:23.1 11/15/2011: Loading Emulator 3: Nintendo N64
14:53:23.1 11/15/2011: Loading Emulator 6: [Console] NEC TurboGrafx-16 (mednafen)
14:53:23.1 11/15/2011: Loading Emulator 7: [Console] Nintendo NES (MESS)
14:53:23.2 11/15/2011: Loading Emulator 8: [Console] Nintendo SNES (MESS)
14:53:23.2 11/15/2011: Loading Emulator 9: [Console] Sega Genesis (GENS+)
14:53:23.2 11/15/2011: Loading Emulator 11: [Console] Sega Master System (GENS+)
14:53:23.2 11/15/2011: Loading Emulator 12: [Console] SNK Neo-Geo CD (NeoGeo CDZ)
14:53:23.2 11/15/2011: Loading Emulator 13: [Console] Sony Playstation 2 (PCSX2)
14:53:23.2 11/15/2011: Loading Emulator 15: [Console] Atari 2600 (MESS)
14:53:23.2 11/15/2011: Loading Emulator 16: [Pinball] Future Pinball
14:53:23.2 11/15/2011: Using 2D Animations
14:53:23.2 11/15/2011: Retrieving resolution setting
14:53:23.2 11/15/2011: Using General Font: Trebuchet MS
14:53:23.2 11/15/2011: Using Title Font: Trebuchet MS
14:53:23.2 11/15/2011: GameEx will try to reduce CPU usage
14:53:23.3 11/15/2011: Initialising Direct3D
14:53:23.3 11/15/2011: Applying GameEx is Loading Image
14:53:23.4 11/15/2011: Setting Resolution to 1920x1080 32 bit color
14:53:23.4 11/15/2011: Creating Surfaces
14:53:23.7 11/15/2011: Creating Primary Surface - Full Screen Mode
14:53:23.7 11/15/2011: Creating Back Buffer
14:53:23.8 11/15/2011: Loading graphic Surfaces
14:53:23.8 11/15/2011: Display is running at: 1920x1080 32bit color, 60hz
14:53:23.8 11/15/2011: Adapter: ATI Radeon HD 4800 Series
14:53:23.8 11/15/2011: Initialising Bass Audio Library
14:53:23.9 11/15/2011: Creating Surfaces Misc and Dialogs
14:53:24.0 11/15/2011: Creating Surfaces Volume
14:53:24.0 11/15/2011: Creating Surfaces Arrows
14:53:24.0 11/15/2011: Creating Surfaces GameEXlogo Text
14:53:24.0 11/15/2011: Creating Surfaces Toolbar
14:53:24.0 11/15/2011: Creating Surfaces Toolbar Controls
14:53:24.1 11/15/2011: Creating Surfaces Backgrounds
14:53:24.1 11/15/2011: Creating Surfaces GameEx Logo
14:53:24.1 11/15/2011: Creating Surface Unselected
14:53:24.1 11/15/2011: Creating Surfaces Home & Exit
14:53:24.1 11/15/2011: Creating Surfaces Snaps
14:53:24.1 11/15/2011: Creating Surfaces Menu and List Bars
14:53:24.2 11/15/2011: Creating Fonts
14:53:24.2 11/15/2011: Creating Game Font
14:53:24.6 11/15/2011: Creating Game Font Faded
14:53:25.2 11/15/2011: Creating Title Font
14:53:25.3 11/15/2011: Restoring Title Font From Cache
14:53:25.6 11/15/2011: Creating Menu Font
14:53:26.0 11/15/2011: Creating Font Black
14:53:26.0 11/15/2011: Creating Font Black Small
14:53:26.1 11/15/2011: Fonts Created Succesfully
14:53:26.8 11/15/2011: Attempting to load game list
14:53:26.9 11/15/2011: MAME CMD options: -nowindow -joy -skip_gameinfo -mouse
14:53:26.9 11/15/2011: Creating DirectSound Device
14:53:27.0 11/15/2011: Trying: Primary Sound Driver
14:53:27.0 11/15/2011: Loading Sound Files
14:53:27.0 11/15/2011: DirectSound Device Created Successfully
14:53:27.0 11/15/2011: Initialising DirectInput for Gamepad support
14:53:27.2 11/15/2011: Unable to create a joystick device
14:53:27.2 11/15/2011: Loading Start Page
14:53:27.3 11/15/2011: Initializing MCE Remote
14:53:27.3 11/15/2011: Playing intro sound file
14:53:27.3 11/15/2011: Initialization OK! Starting GameEx!
14:53:27.3 11/15/2011: Testing Main Loop Once: Processing Frame
14:53:27.5 11/15/2011: Testing Main Loop Once: Main Loop ran successfully
14:53:49.2 11/15/2011: Validating: Emulator_2: Snap Path: C:\GameEx\DEMO\SNES\video
14:53:49.2 11/15/2011: Validating: Emulator_2: Database: [Console] Nintendo SNES
14:53:49.2 11/15/2011: Validating: Emulator_2: Title Snap Path: C:\GameEx\DEMO\SNES\titles
14:53:49.2 11/15/2011: Validating: Emulator_2: Box Art Path: C:\GameEx\DEMO\SNES\boxart
14:53:49.2 11/15/2011: Validating: Emulator_2: Cart Art Path: C:\GameEx\DEMO\SNES\cart
14:53:49.2 11/15/2011: Validating: Emulator_2: Manual Path: C:\GameEx\DEMO\SNES\manual
14:53:49.2 11/15/2011: Validating: Emulator_3: Snap Path: C:\GameEx\DEMO\N64\video
14:53:49.2 11/15/2011: Validating: Emulator_3: Database: [Console] Nintendo N64
14:53:49.2 11/15/2011: Validating: Emulator_3: Title Snap Path: C:\GameEx\DEMO\N64\titles
14:53:49.2 11/15/2011: Validating: Emulator_3: Box Art Path: C:\GameEx\DEMO\N64\boxart
14:53:49.2 11/15/2011: Validating: Emulator_3: Cart Art Path: C:\GameEx\DEMO\N64\cart
14:53:49.2 11/15/2011: Validating: Emulator_3: Manual Path: C:\GameEx\DEMO\N64\manual
14:53:49.2 11/15/2011: Validating: Emulator_6: Snap Path: C:\Assets\NEC TurboGrafx-16\Snaps
14:53:49.2 11/15/2011: Validating: Emulator_6: Control Panel Path: C:\Assets\NEC TurboGrafx-16\Controls
14:53:49.2 11/15/2011: Validating: Emulator_6: Database: [Console] NEC TurboGrafx-16
14:53:49.2 11/15/2011: Validating: Emulator_6: Title Snap Path: C:\Assets\NEC TurboGrafx-16\Titles
14:53:49.2 11/15/2011: Validating: Emulator_6: Box Art Path: C:\Assets\NEC TurboGrafx-16\Boxes
14:53:49.2 11/15/2011: Validating: Emulator_6: Cart Art Path: C:\Assets\NEC TurboGrafx-16\Cartridges
14:53:49.2 11/15/2011: Validating: Emulator_6: Manual Path: C:\Assets\NEC TurboGrafx-16\Manuals
14:53:49.2 11/15/2011: Validating: Emulator_7: Snap Path: C:\Assets\Nintendo NES\Snaps
14:53:49.2 11/15/2011: Validating: Emulator_7: Control Panel Path: C:\Assets\Nintendo NES\Controls
14:53:49.2 11/15/2011: Validating: Emulator_7: Database: [Console] Nintendo NES
14:53:49.2 11/15/2011: Validating: Emulator_7: Title Snap Path: C:\Assets\Nintendo NES\Titles
14:53:49.3 11/15/2011: Validating: Emulator_7: Box Art Path: C:\Assets\Nintendo NES\Boxes
14:53:49.3 11/15/2011: Validating: Emulator_7: Cart Art Path: C:\Assets\Nintendo NES\Cartridges
14:53:49.3 11/15/2011: Validating: Emulator_7: Manual Path: C:\Assets\Nintendo NES\Manuals
14:53:49.3 11/15/2011: Validating: Emulator_8: Snap Path: C:\Assets\Nintendo SNES\Snaps
14:53:49.3 11/15/2011: Validating: Emulator_8: Control Panel Path: C:\Assets\Nintendo SNES\Controls
14:53:49.3 11/15/2011: Validating: Emulator_8: Database: [Console] Nintendo SNES
14:53:49.3 11/15/2011: Validating: Emulator_8: Title Snap Path: C:\Assets\Nintendo SNES\Titles
14:53:49.3 11/15/2011: Validating: Emulator_8: Box Art Path: C:\Assets\Nintendo SNES\Boxes
14:53:49.3 11/15/2011: Validating: Emulator_8: Cart Art Path: C:\Assets\Nintendo SNES\Cartridges
14:53:49.3 11/15/2011: Validating: Emulator_8: Manual Path: C:\Assets\Nintendo SNES\Manuals
14:53:49.3 11/15/2011: Validating: Emulator_9: Snap Path: C:\Assets\Sega Genesis\Snap
14:53:49.3 11/15/2011: Validating: Emulator_9: Video Snap Path: C:\Assets\Sega Genesis\Snaps
14:53:49.3 11/15/2011: Validating: Emulator_9: Control Panel Path: C:\Assets\Sega Genesis\Controls
14:53:49.3 11/15/2011: Validating: Emulator_9: Database: [Console] Sega Genesis
14:53:49.3 11/15/2011: Validating: Emulator_9: Title Snap Path: C:\Assets\Sega Genesis\Title
14:53:49.3 11/15/2011: Validating: Emulator_9: Box Art Path: C:\Assets\Sega Genesis\Box
14:53:49.3 11/15/2011: Validating: Emulator_9: Cart Art Path: C:\Assets\Sega Genesis\Cart
14:53:49.3 11/15/2011: Validating: Emulator_9: Manual Path: C:\Assets\Sega Genesis\Manuals
14:53:49.3 11/15/2011: Validating: Emulator_11: Snap Path: C:\Assets\Sega Master System\Snaps
14:53:49.3 11/15/2011: Validating: Emulator_11: Control Panel Path: C:\Assets\Sega Master System\Controls
14:53:49.3 11/15/2011: Validating: Emulator_11: Database: [Console] Sega Master System
14:53:49.3 11/15/2011: Validating: Emulator_11: Title Snap Path: C:\Assets\Sega Master System\Titles
14:53:49.3 11/15/2011: Validating: Emulator_11: Box Art Path: C:\Assets\Sega Master System\Boxes
14:53:49.3 11/15/2011: Validating: Emulator_11: Cart Art Path: C:\Assets\Sega Master System\Cartridges
14:53:49.3 11/15/2011: Validating: Emulator_11: Manual Path: C:\Assets\Sega Master System\Manuals
14:53:49.3 11/15/2011: Validating: Emulator_12: Snap Path: C:\Assets\SNK Neo-Geo CD\Snaps
14:53:49.3 11/15/2011: Validating: Emulator_12: Control Panel Path: C:\Assets\SNK Neo-Geo CD\Controls
14:53:49.3 11/15/2011: Validating: Emulator_12: Database: [Console] SNK Neo-Geo CD
14:53:49.3 11/15/2011: Validating: Emulator_12: Title Snap Path: C:\Assets\SNK Neo-Geo CD\Titles
14:53:49.3 11/15/2011: Validating: Emulator_12: Box Art Path: C:\Assets\SNK Neo-Geo CD\Boxes
14:53:49.3 11/15/2011: Validating: Emulator_12: Cart Art Path: C:\Assets\SNK Neo-Geo CD\Cartridges
14:53:49.3 11/15/2011: Validating: Emulator_12: Manual Path: C:\Assets\SNK Neo-Geo CD\Manuals
14:53:49.3 11/15/2011: Validating: Emulator_13: Snap Path: C:\Assets\Sony Playstation 2\Snaps
14:53:49.3 11/15/2011: Validating: Emulator_13: Control Panel Path: C:\Assets\Sony Playstation 2\Controls
14:53:49.3 11/15/2011: Validating: Emulator_13: Database: [Console] Sony Playstation 2
14:53:49.4 11/15/2011: Validating: Emulator_13: Title Snap Path: C:\Assets\Sony Playstation 2\Titles
14:53:49.4 11/15/2011: Validating: Emulator_13: Box Art Path: C:\Assets\Sony Playstation 2\Boxes
14:53:49.4 11/15/2011: Validating: Emulator_13: Cart Art Path: C:\Assets\Sony Playstation 2\Cartridges
14:53:49.4 11/15/2011: Validating: Emulator_13: Manual Path: C:\Assets\Sony Playstation 2\Manuals
14:53:49.4 11/15/2011: Warning: Emulator_13: MAPFile Does Not Exist
14:53:49.4 11/15/2011: Validating: Emulator_15: Snap Path: C:\Assets\Atari 2600\Snaps
14:53:49.4 11/15/2011: Validating: Emulator_15: Control Panel Path: C:\Assets\Atari 2600\Controls
14:53:49.4 11/15/2011: Validating: Emulator_15: Database: [Console] Atari 2600
14:53:49.4 11/15/2011: Validating: Emulator_15: Title Snap Path: C:\Assets\Atari 2600\Titles
14:53:49.4 11/15/2011: Validating: Emulator_15: Box Art Path: C:\Assets\Atari 2600\Boxes
14:53:49.4 11/15/2011: Validating: Emulator_15: Cart Art Path: C:\Assets\Atari 2600\Cartridges
14:53:49.4 11/15/2011: Validating: Emulator_15: Manual Path: C:\Assets\Atari 2600\Manuals
14:53:49.4 11/15/2011: Validating: Emulator_16: Snap Path: C:\Assets\Future Pinball\Snaps
14:53:49.4 11/15/2011: Validating: Emulator_16: Control Panel Path: C:\Assets\Future Pinball\Controls
14:53:49.4 11/15/2011: Validating: Emulator_16: Database: [Pinball] Future Pinball
14:53:49.4 11/15/2011: Validating: Emulator_16: Title Snap Path: C:\Assets\Future Pinball\Titles
14:53:49.4 11/15/2011: Validating: Emulator_16: Box Art Path: C:\Assets\Future Pinball\Boxes
14:53:49.4 11/15/2011: Validating: Emulator_16: Cart Art Path: C:\Assets\Future Pinball\Cartridges
14:53:49.4 11/15/2011: Validating: Emulator_16: Manual Path: C:\Assets\Future Pinball\Manuals
14:53:49.4 11/15/2011: Restoring Emulator from Cache
14:53:49.5 11/15/2011: Restoring Emulator Database From Cache
14:53:49.5 11/15/2011: Restoring Emulator from Cache
14:53:49.6 11/15/2011: Restoring Emulator Database From Cache
14:53:49.6 11/15/2011: Restoring Emulator from Cache
14:53:49.7 11/15/2011: Restoring Emulator from Cache
14:53:49.7 11/15/2011: Restoring Emulator Database From Cache
14:53:49.8 11/15/2011: EmUDBCache Diff: 11/12/2009 6:24:26 PM - 11/12/2009 6:23:39 PM
14:53:49.8 11/15/2011: Not Restoring Emulator from Cache
14:53:49.8 11/15/2011: Restoring Emulator from Cache
14:53:49.9 11/15/2011: Restoring Emulator Database From Cache
14:53:50.9 11/15/2011: Restoring Cached ICONS from File
14:54:01.7 11/15/2011: Setting Up RawInput Hook
14:54:01.7 11/15/2011: Launching RawInputHook.exe
14:54:02.9 11/15/2011: Running: cmd.exe /c C: C:\Emulators\MAME\mame64.exe macrossp -rompath C:\Emulators\MAME\roms -nowindow -joy -skip_gameinfo -mouse -bezel -artwork_directory artworkgameex
14:54:02.9 11/15/2011: Shutting down display
14:54:04.0 11/15/2011: Shutting down RawInput Hook
14:54:04.0 11/15/2011: Writing MAME stats
14:54:04.1 11/15/2011: Restoring Bezel
14:54:04.1 11/15/2011: Plugin: Game Exit
14:54:04.1 11/15/2011: Plugin: Process Commands
14:54:04.1 11/15/2011: Restoring Window
14:54:04.1 11/15/2011: Reinitializing Graphics System
14:54:06.4 11/15/2011: Returning to GameEx
What's up????
Shouldn't it pass -artwork instead? Mine does.
Also you can remove -skip_disclaimer from your command line. If I was forced to guess GameEx isn't detecting your MAME build properly. You ran a list update I assume? They changed the artwork command a few revisions ago. Skip disclaimer can be removed under advanced MAME options in the setup wizard.
I pulled the skip game info but how do I make GameEx know that I want it to say artwork instead of artwork_directory since it's not autodetecting my MAME ver properly?
That's something GameEx does internally which is why I think your MAME build version isn't being detected. Just humor me and put a vanilla MAME exe in there and run it.
Without knowing the algorithm GameEx uses for this, maybe this will change the command line to what vanilla MAME would use and we can hope it sticks. Otherwise Tom may need to jump in here.
that seems to be it. :( If I DL the ver from the "Download emulator" list, ver 141 I believe it says, it works just fine. Let me back up that version and try again with a clean 144 and see what happens
Wow the downloader is behind! Lol!
Yep. .141 that downloads from GameEx works but 144b does not. I can play sans bezel or downgrade.
Any idea what sort of functionality, MAME wise that I lose via this trade off?
Tom, what's the newest version it will currently detect and how soom till another update? :)
What is 144b again? Its probably because of that version of MAME. Tom doesn't usually support vanilla u builds, not sure who puts your version out.
D'oh sorry! I use the MAME source code to compile my own and didn't realize that's how they label the binary release. I'm a rev behind on 0.143 but my command line reads right so try 0.143 until we can figure this out. I'm on the mobile and can't test 0.144 ATM.
It sounds like its an unnoficial build and GameEx is not properly detecting the version. Therefore using the wrong command line for bezels. You can either use a different option or turn off the bezel feature.
That is exactly the one I'm using. Straight from MAMEdev.org. It's the very latest 64bit version of the mame client. I guess I was unaware that they mark the binary releases with a B and the source with an S.
So I'm just running MAME .144 not .144b (or rather the b is insignifigant).
If anyone using this build could chime in, that'd be great. My cab is an x86 so I won't be much help.
Your alternative is to use the 32-bit 0.144 and you'll have no problems in the mean time. :)
I'm happier just going without the bezel for now. It's not a huge issue. Not to say I wouldn't like to see it resolved but I'm not going to lose any sleep because there are black bars on the side of my games.
OK. :)
You know if you were using a bezel and you added -noka to your MAME command line, the game fills the whole screen instead of leaving unused parts? Maybe you're a purist and don't like stretching the game out. :)
Yeah, It's the whole widescreen thing turned on it's side. I'd rather have black bars over distorting the picture. Especially on a wide screen LCD monitor. That would be a LOT of stretching. And honestly my main reason to post was because the games weren't loading at all. Once I determined that disabling the bezel would let them load it was just a matter of waiting for the inevitable update that recognizes .144 64 bit.
Maybe after I get around to the process of telling GameEx to use the correct bezel I'll care more but for now...
No worries. Just throwin it out there. :)
