Ok here is the issue:
When you goto your favorites menu it will switch to favorites background. Then when you select whatever game you have in your favorites it will then switch to the background of that game in my case I have all my favorites just MAME games. Then when you run it and exit out of MAME it goes back to the image that is "emubak" not whatever the game background was. So when I exit back I want it to go back to the previous background image before you ran it which would be in my case the "MAMESelectbak" not "emubak".
Can this be corrected at all?
I think it's been that way for a while. :)
It should be corrected because it will make your background image the incorrect one when you return from the game. As the emubak is different from the one used when you ran the game from the favorites menu.
Also we still need the GameEx Arcade to have it's own background image so it will work correctly with our themes.
