Hi Guys,
First some background. I have a somewhat intermittent problem of my system crashing due to kernel power errors in Win7 x64. My research on this particular error has shown that the cause is something of a mystery as it can result from any number of issues. That part is neither here nor there, but it does give some background to my current problem in GameEx. To be honest the kernel power crashes occur so rarely that I haven't spent a lot of time and energy trying to address the underlying problem.
I experienced a kernel power error tonight while I was starting up GameEx. I think some of my GameEx system files may have been corrupted because now when I attempt to start GameEx it crashes and displays the following message (my GameEx log shows the same):
22:39:09.5 11/11/2011: Opening Configuration File
22:39:09.5 11/11/2011: GameEx: Version 12.20: Starting Log
22:39:09.5 11/11/2011: Operating System Platform: Win32NT
22:39:09.5 11/11/2011: Operating System Name: Windows 7
22:39:09.5 11/11/2011: Operating System Version: 6.1.7601
22:39:09.5 11/11/2011: Aero running
22:39:09.5 11/11/2011: Initializing Vista/Windows 7 volume control
22:39:09.5 11/11/2011: Checking for versions of .net Framework installed
22:39:09.5 11/11/2011: .net Framework 2.0 Installed
22:39:09.5 11/11/2011: .net Framework 3.0 Installed
22:39:09.5 11/11/2011: .net Framework 3.5 Installed
22:39:09.5 11/11/2011: Intel® Core™ i5 CPU 650 @ 3.20GHz, 8055MB
22:39:09.5 11/11/2011: 4.09Ghz - 4 Cores or CPU's
22:39:09.5 11/11/2011: Running Randomize()
22:39:09.5 11/11/2011: Loading PlugIns
22:39:09.5 11/11/2011: Checking for applications to Launch On Startup
22:39:09.5 11/11/2011: Running Misc startup tasks
22:39:09.5 11/11/2011: Setting Menu types
22:39:09.5 11/11/2011: Getting Configuration Values
22:39:09.5 11/11/2011: Using Theme: Default - Media Center
22:39:09.5 11/11/2011: Checking for alternate Image Directory for Theme: Default - Media Center
22:39:09.5 11/11/2011: Using Images from theme: Default - Media Center V1\MEDIA\
22:39:09.5 11/11/2011: Launching HideOS.exe
22:39:09.5 11/11/2011: Initialising Video/MNG DLL's
22:39:09.5 11/11/2011: GameEx will check for media insertion (may affect performance)
22:39:09.5 11/11/2011: Hiding Taskbar
22:39:09.5 11/11/2011: Is Media Center running?
22:39:09.5 11/11/2011: Checking/Creating LCD Registry values
22:39:09.5 11/11/2011: Check Media Center Exit/Start Mode
22:39:09.5 11/11/2011: Media Center Mode 2
22:39:09.5 11/11/2011: Video previews on. Warning: Only recommended on modern systems
22:39:09.6 11/11/2011: Snap Delay set to: 2
22:39:09.6 11/11/2011: Get other settings
22:39:09.6 11/11/2011: Desktop set to Hide ICONS and set Background to Black
22:39:09.6 11/11/2011: Set: Find emulator artwork on best match basis
22:39:09.6 11/11/2011: Start work for Form
22:39:09.6 11/11/2011: Getting Original Screen Size
22:39:09.6 11/11/2011: Opening Database Connection
22:39:09.6 11/11/2011: --**--
22:39:09.6 11/11/2011: Error: Unrecognized database format 'C:\GameEx\DATA\data.mdb'.
22:39:09.6 11/11/2011: at System.Data.OleDb.OleDbConnectionInternal..ctor(OleDbConnectionString constr, OleDbConnection connection)
22:39:09.6 11/11/2011: at System.Data.OleDb.OleDbConnectionFactory.CreateConnection(DbConnectionOptions options, Object poolGroupProviderInfo, DbConnectionPool pool, DbConnection owningObject)
22:39:09.6 11/11/2011: at System.Data.ProviderBase.DbConnectionFactory.CreateNonPooledConnection(DbConnection owningConnection, DbConnectionPoolGroup poolGroup)
22:39:09.6 11/11/2011: at System.Data.ProviderBase.DbConnectionFactory.GetConnection(DbConnection owningConnection)
22:39:09.6 11/11/2011: at System.Data.ProviderBase.DbConnectionClosed.OpenConnection(DbConnection outerConnection, DbConnectionFactory connectionFactory)
22:39:09.6 11/11/2011: at System.Data.OleDb.OleDbConnection.Open()
22:39:09.6 11/11/2011: at a.ᜀ(Boolean A_0, String A_1, Boolean A_2)
22:39:09.6 11/11/2011: at a..ctor()
22:39:09.6 11/11/2011: Disposing Plugins
22:39:09.6 11/11/2011: GameEx is exiting with errors
22:39:09.6 11/11/2011: Deleting search cache
22:39:11.2 11/11/2011: ERRORS DETECTED: EXITING
This error seems to be fairly persistent. I've tried reinstalling GameEx, as well as deleting my cache files from \GameEx\DATA\, but the error seems to hang in there. I haven't tried a completely fresh install, but that may be an option if necessary. Any help or advice I can get on resolving this error would be tremendously appreciated. Thanks in advance guys!
UPDATE: I just attempted rolling back to an earlier restore point in Windows. This seems to have solved the problem. Sorry for the unnecessary post!
I sometimes think its good to post even if you find or resolve the issue yourself, sometimes a pointer in the right direction is all some people need to get out of a tricking issue with a problem so its all valuable information.
