I have 'Also Launch' for all my emulators run a glovepie script and I want the 'Launch After' to close the running script. 'Also Launch' and 'Launch Before' work fine with any .bat I try, but 'Launch After' doesn't run anything I set it to. I've used the editor under advanced emulator setup and edited the .ini manually but neither helps.
Could ya post your bat file so we can check it out?
My batch to run the script (which works)
@echo off
CD "C:\Program Files (x86)\GlovePIE029"
glovepie.exe -GameEX
My batch to stop the script which works if i put it as 'Launch Before'. I manually start the script I want stopped as a test. When I launch the emu the script closes, so the batch is working.
@echo off
pv -k -f glovepie*
EDIT: pv is a program to monitor and in this case kill processes
Thank you in advance Adultery, I've already received alot of help from reading your posts
Is it supposed to be pv.exe instead?
No prob. I'm always happy to assist. :)
works either way, I've tried both
The batches work outside of gameEX and they both work if they run with/ before the emu, just not after the emu closes
