Keep Last Loaded ISO When Using Zip Format
Hello all,
I'm running PCSX2, and have the .iso files in .7z format. I have zip/7-zip/GoodMerge set to yes. The emulator works fine, but every time I run a game it wants to do a full unzip to the .\Unzipped7-Zip directory. After you close the game it keeps a 1k .iso file in there. If I immediately re-run that game, the full unzip process begins. With the larger .7z isos, this may take a few minutes.
Is there anyway to set GameEx to keep the last .iso file that was run / unzipped in that directory? I realize you wouldn't want every unzipped file in there.
Any help would be appreciated.
Thanks,
Jonathan
Currently, I think the only thing you can do is make a batch file that would 'move' your extracted ISO to another folder, then just run it directly via something like an external application.
