Hi,
I am configuring gameex with installed emulators on my cab. I have a problem with the zsnes emulators. When I exit from a zsnesâ??s game, the emulatorâ??s window appears for 2 seconds and then I return to gameex (see attached photo).
When I exit from a game, how can I do for donâ??t visualize this window?
Thank you
I report my zsnesâ??s configuration in gameex:
[Emulator_4]
STARTPAGENAME=Nintendo SNES
TITLETEXT=Nintendo SNES
StartPageLogo=Nintendo SNES
ROMFilter=
RomPath=C:\EMU\zsnesw151\Roms
RomsInFolders=True
SnapPath=C:\EMU\zsnesw151\Videos
TitlePath=C:\EMU\zsnesw151\Titles
BoxPath=C:\EMU\zsnesw151\Box Art
CartPath=C:\EMU\zsnesw151\Cartridge Art
ManualPath=
ControlPanelPath=
InstructionsPath=
TVAdPath=
MusicPath=
ImageNotFound=
WorkingPath=C:\EMU\zsnesw151
MapKeys=True
WaitBeforeKeys=
SendKeys=
ReplaceDash=False
ReplaceUnder=True
Capitals=False
RemoveBrackets=True
ShowDesktop=True
Debug=False
MapFile=
AlsoLaunch=
Command=zsnesw.exe "[ROMPATH]\[ROMFILE]"
LaunchBefore=
LaunchAfter=
ConfigFile=[Mapping Off] Exit (Process Close)
ExcludedFiles=
CustomBackground=
PlayMusic=False
DontShowInfo=
PlaySelectionMusic=False
SelectionMusicFolder=
PCGame=False
Database=[Console] Nintendo SNES
UseDbName=
GamesIn7Zips=False
MergeSets=
PlayInScreenSaver=False
ShowMostPlayed=True
RandomMostPlayed=True
CDCheck=False
CDCheckFile=
CustomArtName1=
CustomArtPath1=
CustomArtName2=
CustomArtPath2=
CustomArtName3=
CustomArtPath3=
CustomArtName4=
CustomArtPath4=
CustomArtName5=
CustomArtPath5=
GameExtenderCustomArtPath=
GameExtenderConstants=
System=Nintendo SNES
Category=Console
Emulator=ZSNES
Version=1.51
Rating=9.0
DownloadUrl=http://www.gamesdbase.com/setupwizard/emulators/download/zsnes.7z
RequiredFiles=
Website=http://www.zsnes.com/
Info=Super Nintendo emulator
OLDatZip=
Set ShowDesktop=False. That will help in hiding the window if in fact you have fullscreen setup correctly for this emulator. Another thing to try if that still doesn't give you the results you're after is to make sure the emulator closes correctly by using and advanced config.
I think my setup simply sends Alt-F4 instead of sending the exit command. I'd have to check to be sure and I'm nowhere near my machine, so hopefully someone else can verify their zsnes setup for you.
I use the global escape combo hook now, but there is an advanced config specifically for ZSNES. I think it's even called ZSNES V6 or something similar.
And Freq is right, if you have to enable show desktop you're not running in full screen. :)
PS: If you're not fully committed to ZSNES yet, give BSNES a shot. It's a wonderful emulator all around, and I was a stubborn ZSNES user for ages.
