Apologies if this has been answered before, but is it possible in GameEx to have a single key alpha page up and a single key alpha page down. If so, how do I do this?
Also can I change the normal page up/down functions to something besides the PgUp and PgDown keys?
Many Thanks in Advance!
You can change these under Input Settings. Not sure about the second question though.
Flip what adultery said around - you can remap pg up/pg down. Directly mapping alpha paging (i.e., not using the modifier key) isn't possible.
Ok, where do I remap pgup/pgdn? I changed them under input settings - advanced keyboard input, but it had no effect.
Also, do you know if I can have custom game lists in GameEx? I'd like to have a couple different favorites lists in MAME, i.e. Favorites Classics, Favorite Multiplayer, etc.
Thanks again
Thanks again
Did you turn on the advanced controls? (You need to set the first option in that section to yes for any of them to work I believe).
And custom lists are done via 'Custom Folder' like files from MAME32UI. (Check here for some more details: http://www.gameex.info/forums/index.php?showtopic=8213&st=0&p=60212&hl=+custom%20+game%20+lists&fromsearch=1entry60212 )
