Bug in the Setup Wizard!
When you try to enter GameExtender settings and enter the Snap not found image it only puts in the name and not the full path so you have to manually enter it or it will not work correctly.
I can confirm this. Does this also when you try to add a static image instead of a folder.
It's not really a bug but an error in the SetupWizard xml's. The entries should be type="FilePath" instead of type="File" which only puts the filename and not the full path. So the xml's need to be modified. Thanks for reporting it.
