mesk Posted October 24, 2011 Share Posted October 24, 2011 Here are my HLSL settings for MAME 0143u8.they look pretty close to the real thing.check them out if you like HLSL hlsl_enable 1hlslpath hlslhlsl_ini_read 0hlsl_ini_write 0hlslini %ghlsl_prescale_x 2hlsl_prescale_y 2hlsl_preset -1hlsl_write 0hlsl_snap_width 1920hlsl_snap_height 1080shadow_mask_alpha 0.090000shadow_mask_texture aperture.pngshadow_mask_x_count 320shadow_mask_y_count 224shadow_mask_usize 0.187500shadow_mask_vsize 0.093750curvature 0.040000pincushion 0.040000scanline_alpha 0.450000scanline_size 1.000000scanline_height 0.750000scanline_bright_scale 1.000000scanline_bright_offset 0.500000scanline_jitter 0.000000defocus 0.000000,0.000000converge_x 0.000000,0.000000,0.000000converge_y 0.000000,0.000000,0.000000radial_converge_x 0.000000,0.000000,0.000000radial_converge_y 0.000000,0.000000,0.000000red_ratio 1.000000,0.000000,0.000000grn_ratio 0.000000,1.000000,0.000000blu_ratio 0.000000,0.000000,1.000000saturation 1.150000offset 0.000000,0.000000,0.000000scale 0.950000,0.950000,0.950000power 1.100000,1.100000,1.100000floor 0.000000,0.000000,0.000000phosphor_life 0.200000,0.200000,0.200000yiq_enable 0yiq_cc 3.041830yiq_a 0.000000yiq_b 0.000000yiq_o 3.600000yiq_p 1.000000yiq_n 1.000000yiq_y 2.200000yiq_i 0.800000yiq_q 0.200000yiq_scan_time 52.599998yiq_phase_count 1 Link to comment Share on other sites More sharing options...
B2K24 Posted November 5, 2011 Share Posted November 5, 2011 These are the best. Thank you mesk Link to comment Share on other sites More sharing options...
