Some roms need me to change the resolution in mame , otherwise the game runs alittle high on the screen , ive changed the resoulution in mame and it fixes the problem but it wont translate to GameEx , any ideas.
You can run all games at the same resoultion by modifying the cmd line options in GameEx. Look at Usage and Congifuration in MAME32 help file for cmd options.
Otherwise you can create an ini file for these games.
In the MAME ini directory.
Tom
