Hi Everyone,
I'm new to gameex, I'm more familiar with hyperpsin but I wanted something more mediacenter-ish to use for a media center pc. I was wondering if someone could help me with dumb questions?
1. Is the setup wizard the only place I can setup emulators and settings? It feels more like a first time user thing, I just want to make sure there's no other settings screen while in gameex or a settings.exe or something like that
2. I installed all the emulators in the wizard setup, gameex downloaded them and everything, pretty neat. But I closed gameex and now the only thing under emulators are the gameex flash games. What happened? Did they disappear because I have no roms for the emulators? or did I do something? Even the mame games disappeared?
3. I can't create an admin password, I type in the password in the first box and then I can't do anything. I can't click on the bottom box, or the green arrow. Any ideas?
Thanks for the help!
Welcome to GameEx forums!
1) I would recommend using the setup wizard as it is too time consuming to do it manually.
2) You still need to edit each emulator using the wizard to config your directories and other settings.
3) Can't help you with this one as I don't use that feature, but I'm sure someone here will have an answer for you soon on this one.
Thanks for the help. I'm working on setting up the NES, just to become more familiar. I see that I can put snaps in the asset folder, but what about videos? Where should I place those?
