Hello
I''ve got a set of about 480 roms for Nebula.
When I setup config in gameEx it works well but i can't see all roms.
Please your advices will be appreciated.
Seb
Hello
Seb
When dealing with Arcade emulators other than MAME, usually a MAP file is used to show all the roms and to list them in a friendly manner in GameEx. Then just point to the Map File setting in Advanced Emulator Setup section of Setup Wizard. I have done the work and generated this file for the community. It can found here or also can be found in my signature. If this is not the result you're after then please give more info.
Me and Freq.always posting at the same time!
A map file would be the way to go.just a friendly heads up that nebula is kind of obsolete,since MAME runs all nebula games EXCEPT knights of valor...which may very well be working in 143u7 ;)
Same time? That was 3 minutes later! And you also edited your post. LOL. :P
But yes, MAME is doing a good job of eliminating the need for other emulators. NonMAME is my source of choice to see what games are not working in MAME yet to determine if an other emulator is recommended.
These are the games listed there:
Knights Of Valor (Version 100) (Japanese Board)
Knights Of Valor (Version 115)
Knights Of Valor (Version 117)
The main reason to keep Nebula is that I can't see my NeoGeo roms in gameEx.
I've plug NeoGeo bios but no way.
Help needed
Seb
Help needed
Seb
What version of MAME are you running? Does your romset match that version? Have you verified your romset with a rom manager? Have you tried to play a game outside of GameEx? Please provide more info. I will be in chat (link found on top of forums) for awhile if you want real-time support.
I've just checked following you version is 0.143 and I finaly manage to find my roms using durectly Mame but Mame don't start games because of a lake of chd.
What do I have to do ? Nebula never asked for any chd.
Seb
Seb
I would start here ;)
http://mameworld.info/easyemu/mameguide/mameguide.html
Probably the best MAME tutorial on the net
Nebula doesnt use chd's because it doesnt support games that use chd's
