23:00:54.7 9/15/2011: Opening Configuration File
23:00:54.7 9/15/2011: GameEx: Version 12.13: Starting Log
23:00:54.8 9/15/2011: Operating System Platform: Win32NT
23:00:54.8 9/15/2011: Operating System Name: Windows Vista
23:00:54.8 9/15/2011: Operating System Version: 6.1.7601
23:00:54.8 9/15/2011: Aero running
23:00:54.8 9/15/2011: Initializing Vista/Windows 7 volume control
23:00:54.8 9/15/2011: Checking for versions of .net Framework installed
23:00:54.8 9/15/2011: .net Framework 2.0 Installed
23:00:54.8 9/15/2011: .net Framework 3.0 Installed
23:00:54.8 9/15/2011: .net Framework 3.5 Installed
23:00:54.8 9/15/2011: Intel® Core i5-2500K CPU @ 3.30GHz, 8166MB
23:00:54.8 9/15/2011: 3.31Ghz - 4 Cores or CPU's
23:00:54.8 9/15/2011: Running Randomize()
23:00:54.8 9/15/2011: Loading PlugIns
23:00:54.9 9/15/2011: Loaded Plugin:"Speak Game Name" Version 1.41 By Tom Speirs
23:00:54.9 9/15/2011: PlugIn: "Speak Game Name" Initialized OK
23:00:54.9 9/15/2011: Using Plugin System Version: 1.4
23:00:54.9 9/15/2011: Checking for applications to Launch On Startup
23:00:54.9 9/15/2011: Running Misc startup tasks
23:00:54.9 9/15/2011: Setting Menu types
23:00:54.9 9/15/2011: Getting Configuration Values
23:00:54.9 9/15/2011: Using Theme: Default - Media Center - Background V1
23:00:54.9 9/15/2011: Checking for alternate Image Directory for Theme: Default - Media Center - Background V1
23:00:54.9 9/15/2011: Using Images from theme: Default - Media Center V1\MEDIA\
23:00:54.9 9/15/2011: Launching HideOS.exe
23:00:54.9 9/15/2011: Initialising Video/MNG DLL's
23:00:54.9 9/15/2011: GameEx will check for media insertion (may affect performance)
23:00:54.9 9/15/2011: Hiding Taskbar
23:00:54.9 9/15/2011: Is Media Center running?
23:00:54.9 9/15/2011: Checking/Creating LCD Registry values
23:00:54.9 9/15/2011: Check Media Center Exit/Start Mode
23:00:54.9 9/15/2011: Media Center Mode 2
23:00:54.9 9/15/2011: Video previews on. Warning: Only recommended on modern systems
23:00:54.9 9/15/2011: Snap Delay set to: 2
23:00:54.9 9/15/2011: Get other settings
23:00:54.9 9/15/2011: Set: Find emulator artwork on best match basis
23:00:54.9 9/15/2011: Start work for Form
23:00:54.9 9/15/2011: Getting Original Screen Size
23:00:54.9 9/15/2011: Opening Database Connection
23:00:54.9 9/15/2011: Initializing Component
23:00:55.0 9/15/2011: Retrieving resolution setting
23:00:55.0 9/15/2011: MAME Path is: G:\Emulation\Mame
23:00:55.0 9/15/2011: daphne Path is: G:\Emulation\Daphne
23:00:55.0 9/15/2011: daphne EXE file is: Daphne.exe
23:00:55.0 9/15/2011: Use daphne on. Daphne.exe will launch games
23:00:55.0 9/15/2011: Model 2 Path Path is: G:\Emulation\Model2
23:00:55.0 9/15/2011: Multi Core/Hyper Threading detected. Looking for emulator_multicpu.exe
23:00:55.0 9/15/2011: Model 2 EXE file is: emulator_multicpu.exe
23:00:55.0 9/15/2011: Model 2 emulator with command line support detected
23:00:55.0 9/15/2011: Use Model 2 on. emulator_multicpu.exe will launch Sega Model 2 games
23:00:55.0 9/15/2011: ZiNc Path is: G:\Emulation\Zinc
23:00:55.0 9/15/2011: ZiNc EXE file is: ZiNc_Loader.exe
23:00:55.0 9/15/2011: Use ZiNc on. ZiNc_Loader.exe will launch PSX games
23:00:55.0 9/15/2011: MAME EXE file is: mameuihiscore64.exe
23:00:55.0 9/15/2011: ROM Path is: G:\Emulation\Mame\roms
23:00:55.0 9/15/2011: Catver.ini is located at: C:\GameEx\DATA\catver.ini
23:00:55.0 9/15/2011: controls.ini is located at: C:\GameEx\data\controls.ini
23:00:55.0 9/15/2011: History.dat is located at: C:\GameEx\DATA\history.dat
23:00:55.0 9/15/2011: nplayers.ini is located at: C:\GameEx\DATA\nplayers.ini
23:00:55.0 9/15/2011: command.dat is located at: C:\GameEx\DATA\command.dat
23:00:55.0 9/15/2011: MAMEinfo.dat is located at: C:\GameEx\DATA\mameinfo.dat
23:00:55.0 9/15/2011: Loading Controls.ini map file
23:00:55.0 9/15/2011: Snap Path is: G:\Emulation\Mame\snap
23:00:55.0 9/15/2011: AVI Snap Path is: C:\Snap\M.A.M.E. SQ
23:00:55.0 9/15/2011: Flyer Path is: G:\Emulation\Mame\flyers
23:00:55.0 9/15/2011: Cabinet Path is: G:\Emulation\Mame\cabinets
23:00:55.0 9/15/2011: Cabinet 3D Path: Not Found
23:00:55.0 9/15/2011: Title Path is: G:\Emulation\Mame\titles
23:00:55.0 9/15/2011: PCB Path: Not Found
23:00:55.0 9/15/2011: Artwork Preview Path: Not Found
23:00:55.0 9/15/2011: Panel Path is: G:\Emulation\Mame\cpanel
23:00:55.0 9/15/2011: Manual Path: Not Found
23:00:55.0 9/15/2011: Icon Path is: G:\Emulation\Mame\icons
23:00:55.0 9/15/2011: Marquee Path is: G:\Emulation\Mame\marquees
23:00:55.0 9/15/2011: Applying Language/Text
23:00:55.0 9/15/2011: Text/Language: English
23:00:55.0 9/15/2011: Loading Custom Emulators
23:00:55.0 9/15/2011: Loading Emulator 1: Nintendo N64 (Project64)
23:00:55.0 9/15/2011: Loading Emulator 2: Comics
23:00:55.0 9/15/2011: Loading Emulator 3: Pinball (VPinMAME)
23:00:55.0 9/15/2011: Loading Emulator 4: Sega Dreamcast (NullDC)
23:00:55.0 9/15/2011: Loading Emulator 5: Coleco Vision (MESS)
23:00:55.0 9/15/2011: Loading Emulator 6: PC Games
23:00:55.0 9/15/2011: Loading Emulator 7: Arcade (Raine)
23:00:55.0 9/15/2011: Loading Emulator 8: Sega CD (Fusion)
23:00:55.0 9/15/2011: Loading Emulator 10: ZiNc
23:00:55.0 9/15/2011: Loading Emulator 11: (CPS-3)
23:00:55.0 9/15/2011: Loading Emulator 12: SNK Neo-Geo CD (NeoRaine)
23:00:55.0 9/15/2011: Loading Emulator 13: Atari 2600 (MESS)
23:00:55.0 9/15/2011: Loading Emulator 14: Atari 5200 (MESS)
23:00:55.0 9/15/2011: Loading Emulator 15: Atari 7800 (MESS)
23:00:55.0 9/15/2011: Loading Emulator 16: Game Boy Advance (MESS)
23:00:55.0 9/15/2011: Loading Emulator 17: GCE Vectrex (MESS)
23:00:55.0 9/15/2011: Loading Emulator 18: Nintendo Game Boy (MESS)
23:00:55.0 9/15/2011: Loading Emulator 19: Atari Lynx (Handy)
23:00:55.0 9/15/2011: Loading Emulator 20: Nintendo Game Boy Color (MESS)
23:00:55.0 9/15/2011: Loading Emulator 22: Nintendo SNES (ZSNES)
23:00:55.0 9/15/2011: Loading Emulator 23: Sega Genesis (MESS)
23:00:55.0 9/15/2011: Loading Emulator 24: Sega Master System (MESS)
23:00:55.0 9/15/2011: Loading Emulator 25: MisFit Mame
23:00:55.0 9/15/2011: Loading Emulator 26: Panasonic 3DO
23:00:55.0 9/15/2011: Loading Emulator 27: Nintendo NES (VirtuaNES)
23:00:55.0 9/15/2011: Loading Emulator 28: HazeMDFX
23:00:55.0 9/15/2011: Loading Emulator 29: Sega Game Gear (MESS)
23:00:55.0 9/15/2011: Loading Emulator 30: Sega 32x (Fusion)
23:00:55.0 9/15/2011: Loading Emulator 31: Nintendo DS (No$Zoomer)
23:00:55.0 9/15/2011: Loading Emulator 32: Sega Master System (Fusion)
23:00:55.0 9/15/2011: Loading Emulator 33: Sega Game Gear (Fusion)
23:00:55.0 9/15/2011: Loading Emulator 34: Mattel Intellivision (MESS)
23:00:55.0 9/15/2011: Loading Emulator 35: NEC TurboGrafx 16 (Ootake)
23:00:55.0 9/15/2011: Loading Emulator 36: Nintendo Game Boy Color (VisualBoyAdvance)
23:00:55.0 9/15/2011: Loading Emulator 37: Nintendo Game Boy (VisualBoyAdvance)
23:00:55.0 9/15/2011: Loading Emulator 38: Nintendo Game Boy Advance (VisualBoyAdvance)
23:00:55.0 9/15/2011: Loading Emulator 39: Arcade (WinKawaks)
23:00:55.0 9/15/2011: Loading Emulator 40: Sony Playstation (ePSXe)
23:00:55.0 9/15/2011: Loading Emulator 41: Sony Playstation (pSX)
23:00:55.0 9/15/2011: Loading Emulator 42: Arcade (Mjolnir)
23:00:55.0 9/15/2011: Loading Emulator 43: Bandai WonderSwan Color (Oswan)
23:00:55.0 9/15/2011: Loading Emulator 44: Super Game Boy (MESS)
23:00:55.0 9/15/2011: Loading Emulator 45: Nintendo Super Game Boy (BGB)
23:00:55.0 9/15/2011: Loading Emulator 46: Namco System 22 (Vivanonno)
23:00:55.0 9/15/2011: Using 3D Alpha Blended Animations.
23:00:55.0 9/15/2011: Using General Font: HandelGothic BT
23:00:55.0 9/15/2011: Using Title Font: HandelGothic BT
23:00:55.1 9/15/2011: Initialising Direct3D
23:00:55.1 9/15/2011: Applying GameEx is Loading Image
23:00:55.1 9/15/2011: Setting Resolution to 1920x1080 32 bit color
23:00:55.1 9/15/2011: Creating Surfaces
23:00:55.4 9/15/2011: Creating Primary Surface - Full Screen Mode
23:00:55.4 9/15/2011: Creating Back Buffer
23:00:55.4 9/15/2011: Loading graphic Surfaces
23:00:55.4 9/15/2011: Display is running at: 1920x1080 32bit color, 60hz
23:00:55.4 9/15/2011: Creating Surfaces Misc and Dialogs
23:00:55.5 9/15/2011: Creating Surfaces Volume
23:00:55.5 9/15/2011: Creating Surfaces Arrows
23:00:55.5 9/15/2011: Creating Surfaces GameEXlogo Text
23:00:55.5 9/15/2011: Creating Surfaces Toolbar
23:00:55.5 9/15/2011: Creating Surfaces Backgrounds
23:00:55.7 9/15/2011: Creating Surfaces Toolbar Controls
23:00:55.7 9/15/2011: Creating Surfaces GameEx Logo
23:00:55.7 9/15/2011: Creating Surface Unselected
23:00:55.7 9/15/2011: Creating Surfaces Home & Exit
23:00:55.7 9/15/2011: Creating Surfaces Snaps
23:00:55.7 9/15/2011: Creating Surfaces Menu and List Bars
23:00:55.9 9/15/2011: Creating Fonts
23:00:55.9 9/15/2011: Creating Game Font
23:00:55.9 9/15/2011: Error: Error in the application.
23:00:55.9 9/15/2011: at Microsoft.DirectX.Direct3D.Font..ctor(Device device, Font font)
23:00:55.9 9/15/2011: at ᜓ..ctor(String A_0, ᜎ A_1, Form A_2, String A_3, Single A_4, FontStyle A_5, SpriteFlags A_6)
23:00:55.9 9/15/2011: at a.ខ()
23:00:55.9 9/15/2011: at a.ᜃ(Boolean A_0, Boolean A_1, Boolean A_2)
23:00:55.9 9/15/2011: at a.ᜀ(Boolean A_0, Boolean A_1, Boolean A_2, Boolean A_3, Int32 A_4)
23:00:55.9 9/15/2011: at a.ᜁ(Boolean A_0, Boolean A_1, Boolean A_2)
23:00:55.9 9/15/2011: at a.ᜀ(Boolean A_0, String A_1, Boolean A_2)
23:00:55.9 9/15/2011: at a..ctor()
23:00:55.9 9/15/2011: Closing database connection
23:00:56.0 9/15/2011: Disposing Plugins
23:00:56.0 9/15/2011: GameEx is exiting with errors
23:00:56.0 9/15/2011: Deleting search cache
23:00:57.7 9/15/2011: ERRORS DETECTED: EXITING
Someone Splain Please?
We're no longer supporting advanced config, remember! ;)
It's either under display options in setup wizard, or it's in your theme's ini (remember the theme.ini overrides GameEx settings). :)
Well, I have old habits I just cant let go, no offence to Ben I know he puts alot of work into the setup wizard. On the same hand, the advanced utility is still included so I cannot write if off all together.. right?
Sad to say, but wrong. Unfortunately it's no longer being updated or included with new installs and a ton of features are missing.
Don't worry Brian, it was hard for me to let it go too at first. I rebuilt my cab's guts and when I reinstalled GameEx it was gone. I've grown to love the wiz though. It's quite a bit easier to get around in. :D
Thanks Guys. I changed the theme and it's working again. Some time this weekend ima hop in my favorite thread and setup type X
If you liked that theme you can easily change the font. Just open the theme.ini in notepad and change the name of the font, or search the web and install the font you're missing.
