hi tom
I would now how to use Offlilelist screenshot with GameEX ...
on Older version of GameEx, I test this function ans I remembrer it's ok
I would install the softs definitly on my mediacenter, I configure mame, video... it's Very nice (Thank's for this mame fronted).
But the offlinelist's screenshots don't show on GameEX (I use Offlinelist since 2 years, and gameEX correctly configured)
Thanks for your help
(sorry for my poor english)
hi tom
Maybe I broke it in an update, Ill check it out sometime soon. I think your better using http://screenshotarchive.com though. That's what most people do now I think.
Notice: This domain name expired on 01/12/06 and is pending renewal or deletion
looks like i should have got on getting all my box art, screenies, etc before this :blink: thats what i get for waiting... hopefully it comes back up as archive.org's way back machine does not keep the downloads...
starting logs.
i test many config, but screens don't show;
19:58:12.8  21/01/2006:  GameEx: Version 5.40: Starting Log
19:58:12.8  21/01/2006:  Operating System Platform: Win32NT
19:58:12.8  21/01/2006:  Operating System Name: Windows XP
19:58:12.8  21/01/2006:  Operating System Version: 5.1.2600
19:58:12.8  21/01/2006:  Checking for versions of .net Framework installed
19:58:12.8  21/01/2006:  .net Framework 1.1 Installed
19:58:12.8  21/01/2006:  Checking Registration
19:58:12.8  21/01/2006:  Running Randomize()
19:58:12.9  21/01/2006:  Initialising Video/MNG DLL's
19:58:12.9  21/01/2006:  Running Misc startup tasks
19:58:12.9  21/01/2006:  Setting Menu types
19:58:12.9  21/01/2006:  Opening Configuration File
19:58:12.9  21/01/2006:  Getting Configuration Values
19:58:12.9  21/01/2006:  Using Theme: Default - Default - Animated
19:58:12.9  21/01/2006:  Checking for alternate Image Directory for Theme: Default - Default - Animated
19:58:12.9  21/01/2006:  Using Images from theme: Default - Default\MEDIA\
19:58:12.9  21/01/2006:  Text/Language: French
19:58:12.9  21/01/2006:  Applying Language/Text
19:58:12.9  21/01/2006:  Creating Scancodes.txt (List of DirectInput scan codes)
19:58:12.9  21/01/2006:  Snap Delay set to: 1
19:58:12.9  21/01/2006:  Is Media Center running?
19:58:12.9  21/01/2006:  Check Media Center Exit/Start Mode
19:58:12.9  21/01/2006:  Media Center Mode 0
19:58:12.9  21/01/2006:  Checking for applications to Launch On Startup
19:58:12.9  21/01/2006:  Get other settings
19:58:12.9  21/01/2006:  Using 3D Animations
19:58:12.9  21/01/2006:  Set: Find emulator artwork on best match basis
19:58:12.9  21/01/2006:  Launching HideOS.exe
19:58:13.8  21/01/2006:  Hiding Taskbar
19:58:13.8  21/01/2006:  Start work for Form
19:58:13.8  21/01/2006:  Getting Original Screen Size
19:58:13.8  21/01/2006:  Loading ICON
19:58:13.8  21/01/2006:  Initializing Component
19:58:13.8  21/01/2006:  Initialising Bass Audio Library
19:58:13.9  21/01/2006:  Loading default loading screen
19:58:13.9  21/01/2006:  Using General Font: Trebuchet MS
19:58:13.9  21/01/2006:  Using Title Font: Trebuchet MS
19:58:13.9  21/01/2006:  Initialising DirectDraw
19:58:14.0  21/01/2006:  Applying GameEx is Loading Image
19:58:14.0  21/01/2006:  Creating DirectDraw Device
19:58:14.0  21/01/2006:  Using Device: RADEON X800 XT
19:58:14.0  21/01/2006:  Setting Resolution to 1280x1024 32 bit color
19:58:14.0  21/01/2006:  Creating DirectDraw Surfaces
19:58:14.0  21/01/2006:  Creating Primary Surface - Full Screen Mode
19:58:14.0  21/01/2006:  Creating Back Buffer
19:58:14.0  21/01/2006:  Loading graphic surfaces
19:58:14.1  21/01/2006:  Creating Surfaces Misc and Dialogs
19:58:14.1  21/01/2006:  Creating Surface Volume
19:58:14.1  21/01/2006:  Creating Surfaces Arrows
19:58:14.1  21/01/2006:  Creating Surfaces GameEXlogo Text
19:58:14.1  21/01/2006:  Creating Surfaces Toolbar
19:58:14.1  21/01/2006:  Creating Surfaces Backgrounds
19:58:15.2  21/01/2006:  Creating Surfaces Toolbar Controls
19:58:15.2  21/01/2006:  Creating Surfaces GameEx Logo
19:58:15.2  21/01/2006:  Creating Surfaces Home & Exit
19:58:15.2  21/01/2006:  Creating Surfaces Snaps
19:58:15.2  21/01/2006:  Creating Surfaces Menu and List Bars
19:58:15.2  21/01/2006:  Creating Fonts
19:58:15.2  21/01/2006:  Creating Menu Font
19:58:15.3  21/01/2006:  Creating Game Font
19:58:15.4  21/01/2006:  Creating Game Font Standard Size
19:58:15.7  21/01/2006:  Creating Font Black
19:58:15.8  21/01/2006:  Creating Font Black Small
19:58:15.9  21/01/2006:  Creating Game Font Faded
19:58:15.9  21/01/2006:  Creating Title Font
19:58:16.2  21/01/2006:  Fonts Created Succesfully
19:58:16.2  21/01/2006:  MAME Path is: H:\allgames\arcade\mameplus
19:58:16.2  21/01/2006:  daphne Path is: H:\allgames\arcade\Daphne
19:58:16.2  21/01/2006:  daphne EXE file is: Daphne.exe
19:58:16.2  21/01/2006:  Use daphne on. Daphne.exe will launch games
19:58:16.2  21/01/2006:  ZiNc Path is: H:\allgames\arcade\mameplus\zinc11
19:58:16.2  21/01/2006:  ZiNc EXE file is: zinc.exe
19:58:16.2  21/01/2006:  Use ZiNc on. zinc.exe will launch PSX games
19:58:16.2  21/01/2006:  MAME EXE file is: mame32p.exe
19:58:16.2  21/01/2006:  ROM Path is: H:\allgames\arcade\mameplus\roms
19:58:16.2  21/01/2006:  Catver.ini is located at: C:\Program Files\GameEx\DATA\catver.ini
19:58:16.2  21/01/2006:  controls.ini is located at: C:\Program Files\GameEx\data\controls.ini
19:58:16.2  21/01/2006:  History.dat is located at: C:\Program Files\GameEx\DATA\history.dat
19:58:16.2  21/01/2006:  nplayers.ini is located at: C:\Program Files\GameEx\DATA\nplayers.ini
19:58:16.2  21/01/2006:  MAMEinfo.dat is located at: C:\Program Files\GameEx\DATA\mameinfo.dat
19:58:16.2  21/01/2006:  Loading Controls.ini map file
19:58:16.2  21/01/2006:  Loading Custom Emulators
19:58:16.2  21/01/2006:  Loading Emulator 1: Super Nes
19:58:16.3  21/01/2006:  Loading OfflineList Dat File for emulator: 1
19:58:16.4  21/01/2006:  Loading Emulator 2: GameBoy Advance
19:58:16.4  21/01/2006:  Loading OfflineList Dat File for emulator: 2
19:58:16.7  21/01/2006:  Snap path: Not Found
19:58:16.7  21/01/2006:  AVI Snap Path is: H:\allgames\arcade\mameplus\video\ingame
19:58:16.7  21/01/2006:  Flyer Path is: H:\allgames\arcade\mameplus\flyers
19:58:16.7  21/01/2006:  Cabinet Path is: H:\allgames\arcade\mameplus\cabinets
19:58:16.7  21/01/2006:  Title Path: Not Found
19:58:16.7  21/01/2006:  Panel Path is: H:\allgames\arcade\mameplus\cpanel
19:58:16.7  21/01/2006:  Icon Path is: H:\allgames\arcade\mameplus\icons
19:58:16.7  21/01/2006:  Marquee Path is: H:\allgames\arcade\mameplus\marquees
19:58:16.7  21/01/2006:  MAME CMD options: -triplebuffer -nowindow -joy
19:58:16.7  21/01/2006:  Attempting to load game list
19:58:16.8  21/01/2006:  Running: mame32p.exe -help
19:58:16.8  21/01/2006:  Running: H: H:\allgames\arcade\mameplus\mame32p.exe -help > H:\allgames\arcade\mameplus\help.txt
19:58:16.9  21/01/2006:
19:58:16.9  21/01/2006:  Now Outputing mame32p.exe - Help
19:58:16.9  21/01/2006:  --BEGIN--
19:58:16.9  21/01/2006:  M.A.M.E. v0.103 (Dec 30 2005) - Multiple Arcade Machine Emulator
19:58:16.9  21/01/2006:  Copyright (C) 1997-2005 par Nicola Salmoria et l'quipe MAME
19:58:16.9  21/01/2006:  MAME est un mulateur: il reproduit plus ou moins le fonctionnement de
19:58:16.9  21/01/2006:  plusieurs machines d'arcade. Mais le matriel est inutile sans logiciel, donc une copie
19:58:16.9  21/01/2006:  des ROMs qui fonctionnaient sur ce matriel est requis. Les ROMs, comme tout
19:58:16.9  21/01/2006:  logiciel commercial, est sous copyright et il est donc ILLEGAL
19:58:16.9  21/01/2006:  de les utiliser si vous n'avez pas l'original de la machine d'arcade. Il va sans dire que
19:58:16.9  21/01/2006:  les ROMs ne sont pas distribues avec MAME. Distribuer MAME avec des ROMs
19:58:16.9  21/01/2006:  est une violation des lois du copyright et doit tre rapport aux auteurs
19:58:16.9  21/01/2006:  pour qu'ils puissent intenter une action lgale.
19:58:16.9  21/01/2006:  Usage:  MAME nom_du_jeu [options]
19:58:16.9  21/01/2006:          MAME -showusage    Pour une brve liste des options
19:58:16.9  21/01/2006:          MAME -showconfig   Pour la liste des options de configuration
19:58:16.9  21/01/2006:          MAME -createconfig pour crer mame.ini
19:58:16.9  21/01/2006:  For usage instructions, please consult the file windows.txt
19:58:16.9  21/01/2006:  --END--
19:58:16.9  21/01/2006:  Loading last used Game List
19:58:16.9  21/01/2006:  Setting Music Volume
19:58:16.9  21/01/2006:  Creating DirectSound Device
19:58:16.9  21/01/2006:  Trying: Périphérique audio principal
19:58:16.9  21/01/2006:  Loading Sound Files
19:58:16.9  21/01/2006:  DirectSound Device Created Successfully
19:58:16.9  21/01/2006:  Creating ICONS
19:58:16.9  21/01/2006:  Restoring Cached ICONS from File
19:58:17.0  21/01/2006:  Initialising DirectInput for Gamepad support
19:58:17.0  21/01/2006:  Using Device Saitek P3000 Wireless Pad
19:58:17.1  21/01/2006:  Playing intro sound file
19:58:17.1  21/01/2006:  Initializing MCE Remote
19:58:17.1  21/01/2006:  Starting GameExtender on: 192.168.2.2:8383
19:58:17.1  21/01/2006:  Initialization OK! Starting GameEx!
19:58:17.1  21/01/2006:  Testing Main Loop Once: Processing Frame
19:58:17.2  21/01/2006:  Testing Main Loop Once: Main Loop ran successfully
19:58:28.2  21/01/2006:  Validating: Emulator_1: Custom Background: H:\allgames\console-ordi\Frontend\Offlinelist\OfflineList\imgs\Official No-Intro Nintendo Super NES - Super Famicom
19:58:28.2  21/01/2006:  Warning: Emulator_1: Custom Background Does not exist
19:58:28.2  21/01/2006:  Validating: Emulator_1: Snap Path: H:\allgames\console-ordi\Frontend\Offlinelist\OfflineList\imgs\Official No-Intro Nintendo Super NES - Super Famicom
19:58:28.2  21/01/2006:  Validating: Emulator_1: Title Snap Path:
19:58:28.2  21/01/2006:  Warning: Emulator_1: Title Snap Path Does not exist
19:58:28.2  21/01/2006:  Validating: Emulator_1: Box Art Path:
19:58:28.2  21/01/2006:  Warning: Emulator_1: Box Art Path Does not exist
19:58:28.2  21/01/2006:  Validating: Emulator_1: Cart Art Path:
19:58:28.2  21/01/2006:  Warning: Emulator_1: Cart Art Path Does not exist
19:58:28.2  21/01/2006:  Validating: Emulator_2: Custom Background: H:\allgames\console-ordi\Frontend\Offlinelist\OfflineList\imgs\GBA - Official OfflineList
19:58:28.2  21/01/2006:  Warning: Emulator_2: Custom Background Does not exist
19:58:28.2  21/01/2006:  Validating: Emulator_2: Snap Path: H:\allgames\console-ordi\Frontend\Offlinelist\OfflineList\imgs\GBA - Official OfflineList
19:58:28.2  21/01/2006:  Validating: Emulator_2: Title Snap Path: H:\allgames\console-ordi\Frontend\Offlinelist\OfflineList\imgs\GBA - Official OfflineList
19:58:28.2  21/01/2006:  Validating: Emulator_2: Box Art Path:
19:58:28.2  21/01/2006:  Warning: Emulator_2: Box Art Path Does not exist
19:58:28.2  21/01/2006:  Validating: Emulator_2: Cart Art Path:
19:58:28.2  21/01/2006:  Warning: Emulator_2: Cart Art Path Does not exist
19:59:03.7  21/01/2006:  Exiting GameEx!
19:59:03.7  21/01/2006:  Saving Settings
19:59:03.7  21/01/2006:  Writing Game List to disk
Thank tom
I see that !
BUT i don't select a directory in gameex configuration. the custum backgroung line is blank but it show at log !
in gameex.ini, the custom background is empty :
[Emulator_1]
StartPageName=Super Nes
TitleText=SNES
StartPageLogo=SNES
RomFilter=
RomsInFolders=False
ROMPath=H:\allgames\console-ordi\roms\Nintendo Super NES\roms
SnapPath=H:\allgames\console-ordi\Frontend\Offlinelist\OfflineList\imgs\Official No-Intro Nintendo Super NES - Super Famicom
WorkingPath=H:\allgames\console-ordi\emulateurs\Nintendo Super Nes
MapKeys=True
WaitBeforeKeys=
SendKeys=
ReplaceDash=False
ReplaceUnder=False
Capitals=False
RemoveBrackets=False
AlsoLaunch=
ShowDesktop=True
Debug=False
MapFile=
OLDatZip=H:\allgames\console-ordi\Frontend\Offlinelist\OfflineList\datas\Official No-Intro Nintendo Super NES - Super Famicom.zip
Command=Zsnesw.exe "[ROMPath]\[RomFile]"
TitlePath=H:\allgames\console-ordi\Frontend\Offlinelist\OfflineList\imgs\Official No-Intro Nintendo Super NES - Super Famicom
BoxPath=
LaunchBefore=
LaunchAfter=
CartPath=
configFile=
ExcludedFiles=
CustomBackground=
[Emulator_2]
It's a mistake ???
I see that !
[Emulator_1]
TitleText=SNES
StartPageLogo=SNES
RomFilter=
RomsInFolders=False
MapKeys=True
WaitBeforeKeys=
SendKeys=
ReplaceDash=False
ReplaceUnder=False
Capitals=False
AlsoLaunch=
ShowDesktop=True
Debug=False
MapFile=
BoxPath=
LaunchBefore=
LaunchAfter=
CartPath=
configFile=
ExcludedFiles=
CustomBackground=
[Emulator_2]
It's a mistake ???
No, its working fine, just perhaps it should not say "Warning:"
Also I believe the offlinelist support only ever worked for game snaps and not the other artwork. What with Screenshot archive and emumovies, I kind of lost ineterest in supporting offline further.
I understand Screenshot archive is down, if anyone knows who to contact maybe I can help them out with hosting?
Registrant:
Craig Sturrock
8 Vostok Place
Modbury North
Adelaide, South Australia 5092
Australia
Registered through: GoDaddy.com (http://www.godaddy.com)
Domain Name: SCREENSHOTARCHIVE.COM
Created on: 12-Jan-04
Expires on: 12-Jan-06
Last Updated on: 16-Dec-04
Administrative Contact:
Sturrock, Craig [email protected]
8 Vostok Place
Modbury North
Australia
088123456
Technical Contact:
8 Vostok Place
Modbury North
Australia
088123456
Domain servers in listed order:
PARK5.SECURESERVER.NET
PARK6.SECURESERVER.NET
Registry Status: REGISTRAR-LOCK
As I did not get a chance to DL box art, screenies, etc I am very interested in this B) llet me know if there is anything I can do to help.
