Hoping someone can help me out.
I'm having trouble getting sound from my MAME games when using GameEX,
even though I have MAME audio mode in the config settings set to pause playlist and run MAME with sound.
Leaving the menu page when I select a game to play, the ROMS start fine but with no sound.
Please advise!
I should add that when I exit out of GameEX and choose the restart previous game command, my MAME games start up fine with sound. Anyone have any idea why this occurs?
Tarsis
Tarsis
I'm thinking something has changed in recent versions of MAME perhaps.
What version are you using, and would you be able to try a version prior to 0.92 to be sure about this?
I'm using MAME .94 and tried GameEX just now with version .91. Same problem. I don't get sound out of my MAME games. However, when I choose the "run last game" option, the game has sound. Help!
Hi, I will try and get you a solution for this and help.
Can you try turning off the Jukebox and Playlist, and see if that makes any difference?
Do you get sounds in GamEx when navigating?
What sound card is it?
Could you ensure you have the latest drivers for it, and latest version of DirectX.
Could you also post your log please?
Tom --
I turned off the Jukebox and playlist and still the same problem. However, I do get sounds in GameEX when navigating.
I'm using a Creative SB Audigy soundcard. Drivers are all updated. And-- I have version 9.0c DirectX. My log follows:
20:08:30.5 3/16/2005: GameEx: Version 3.44: Starting Log
20:08:30.5 3/16/2005: Operating System Platform ID: Win32NT
20:08:30.5 3/16/2005: Operating System Version: 5.1
20:08:30.6 3/16/2005: Running Randomize()
20:08:30.6 3/16/2005: Running Misc startup tasks
20:08:30.6 3/16/2005: Hiding Cursor
20:08:30.6 3/16/2005: Opening Configuration File
20:08:30.6 3/16/2005: Getting Configuration Values
20:08:30.6 3/16/2005: Using Theme: Default - Default
20:08:30.6 3/16/2005: Checking for alternate Image Directory for Theme: Default - Default
20:08:30.6 3/16/2005: Applying Language/Text
20:08:31.2 3/16/2005: Using DirectInput for keyboard input
20:08:31.3 3/16/2005: Launching HideOS.exe
20:08:33.2 3/16/2005: Initializing Component
20:08:33.3 3/16/2005: Using General Font: Verdana
20:08:33.3 3/16/2005: Using Title Font: Trebuchet MS
20:08:33.4 3/16/2005: Initialising DirectDraw
20:08:33.4 3/16/2005: Applying GameEx is Loading Image
20:08:33.5 3/16/2005: Creating DirectDraw Device
20:08:33.8 3/16/2005: Setting Resolution to 800x600 32 bit color
20:08:35.4 3/16/2005: Creating DirectDraw Surfaces
20:08:35.4 3/16/2005: Creating Primary Surface
20:08:35.6 3/16/2005: Creating Back Buffer
20:08:35.6 3/16/2005: Loading graphic surfaces
20:08:37.1 3/16/2005: Creating Fonts
20:08:37.1 3/16/2005: Creating Menu Font
20:08:38.9 3/16/2005: Creating Game Font
20:08:40.1 3/16/2005: Creating Menu Font Standard Size
20:08:40.9 3/16/2005: Creating Font Black
20:08:41.0 3/16/2005: Creating Font Black Small
20:08:41.2 3/16/2005: Creating Game Font Faded
20:08:42.1 3/16/2005: Creating Title Font
20:08:44.1 3/16/2005: HTML Apps is on, initialising Web Browser Component
20:08:45.7 3/16/2005: MAME Path is: G:\Mame32version89
20:08:45.8 3/16/2005: MAME EXE file is: Mame32.exe
20:08:45.8 3/16/2005: ROM Path is: G:\roms
20:08:45.8 3/16/2005: Catver.ini is located at: C:\Program Files\GameEx\DATA\catver.ini
20:08:45.8 3/16/2005: controls.ini is located at: C:\Program Files\GameEx\data\controls.ini
20:08:45.8 3/16/2005: History.dat is located at: C:\Program Files\GameEx\DATA\history.dat
20:08:45.9 3/16/2005: nplayers.ini is located at: C:\Program Files\GameEx\DATA\nplayers.ini
20:08:45.9 3/16/2005: MAMEinfo.dat is located at: C:\Program Files\GameEx\DATA\mameinfo.dat
20:08:45.9 3/16/2005: Loading Custom Emulators
20:08:46.2 3/16/2005: Snap Path is: C:\Documents and Settings\Tarsis Lopez\Desktop\MAME\Mame32\snap
20:08:46.2 3/16/2005: AVI Snap Path: Not Found
20:08:46.2 3/16/2005: Flyer Path is: C:\Documents and Settings\Tarsis Lopez\Desktop\MAME\Mame32\flyers
20:08:46.2 3/16/2005: Cabinet Path is: C:\Documents and Settings\Tarsis Lopez\Desktop\MAME\Mame32\cabinets
20:08:46.2 3/16/2005: Title Path is: C:\Documents and Settings\Tarsis Lopez\Desktop\MAME\Mame32\titles
20:08:46.2 3/16/2005: Panel Path is: C:\Documents and Settings\Tarsis Lopez\Desktop\MAME\Mame32\artwork
20:08:46.2 3/16/2005: Icon Path is: C:\Documents and Settings\Tarsis Lopez\Desktop\MAME\Mame32\icons\Iconsv[1].94
20:08:46.2 3/16/2005: Marquee Path is: C:\Documents and Settings\Tarsis Lopez\Desktop\MAME\Mame32\marquees
20:08:46.3 3/16/2005: Using Ultimarc AradeVGA
20:08:46.3 3/16/2005: Attempting to load game list
20:08:46.7 3/16/2005: Loading last used Game List
20:08:47.4 3/16/2005: Initialising Bass Audio Library
20:08:48.2 3/16/2005: Creating DirectSound Device
20:08:48.3 3/16/2005: Trying: Primary Sound Driver
20:08:48.6 3/16/2005: Trying: Playback through TotalRecorder (emulated)
20:08:48.8 3/16/2005: Trying: SB Audigy Audio [D000]
20:08:49.4 3/16/2005: Loading Sound Files
20:08:50.5 3/16/2005: DirectSound Device Created Successfully
20:08:50.6 3/16/2005: Creating ICONS
20:08:50.7 3/16/2005: Restoring Cached ICONS from File
20:08:55.3 3/16/2005: Initialising DirectInput for Gamepad support
20:08:55.3 3/16/2005: Initialising DirectInput for Keyboard support
20:08:55.4 3/16/2005: Playing Startup Video
20:08:55.5 3/16/2005: Initialization OK! Starting GameEx!
20:08:55.5 3/16/2005: Testing Main Loop Once: Processing Frame
20:08:55.5 3/16/2005: Testing Main Loop Once: Getting Tick count
20:08:55.7 3/16/2005: Testing Main Loop Once: Checking for song change
20:08:55.7 3/16/2005: Testing Main Loop Once: Checking Keyboard for Input
20:08:55.7 3/16/2005: Testing Main Loop Once: Front buffer exists?
20:08:55.7 3/16/2005: Testing Main Loop Once: Surfaces need restore?
20:08:55.7 3/16/2005: Testing Main Loop Once: Checking Joystick for input
20:08:55.7 3/16/2005: Testing Main Loop Once: Drawing Background
20:08:55.8 3/16/2005: Testing Main Loop Once: Drawing Logo
20:08:56.0 3/16/2005: Testing Main Loop Once: Flipping Surfaces
20:08:56.0 3/16/2005: Testing Main Loop Once: Main Loop ran successfully
20:09:11.6 3/16/2005: 224-288-V-True-640-288
20:09:11.7 3/16/2005: Running: cmd.exe /c G: G:\Mame32version89\Mame32.exe mspacman -rompath G:\roms -skip_disclaimer -skip_gameinfo -triplebuffer -nowindow -joy -resolution 352x256 -hwstretch -effect sharp
20:10:02.0 3/16/2005: Exiting GameEx!
20:10:02.0 3/16/2005: Saving Settings
20:10:02.3 3/16/2005: Writing Game List to disk
Tom --
Hi, yes, I can see its an issue with the Sound card.
GameEx should be using the primary sound driver, and as it seems to not be able to use it. I think that's what's hosing up.
I don't really have any suggestions on how to fix this though at the moment.
You could experiment a little with you sound config in windows. Or try reinistalling the sound card etc, maybe in a different slow.
Let us know how you get on.
Thanks,
Tom
Thanks,
Tom
BINGO!!!! It's working -- changed to SB Audigy from Total recorder as the primary sound driver. Thanks a million!!
Just call me 'da man' !
I am very pleased you have it working now.
All the best,
Tom.
Tom-
You are Da Man! Quick question -- I have the MAME Roms for a 1982 game called Journey (yes, the game featuring the band). However, GameEX doesn't list this game. Any reason why?
Tarsis
