Hi all. i have the problem that in resolution 1024x768 the number of games disappear. if i change the resolution to 800x600 or 640x480 the number of game appears but the scrren is not centered, it slides to the right. :o:o:o
DID YOU SAY YOU HAVE A PROBLEM WITH YOUR SCREEN?
I would think your monitor settings need adjusting perhaps? Have you tried messing with the horizontal hold button on the monitor?
Hi all. i have the problem that in resolution 1024x768 the number of games disappear. if i change the resolution to 800x600 or 640x480 the number of game appears but the scrren is not centered, it slides to the right.  :o  :o  :o
Works fine for me in the latest version of GameEx, at all font sizes. There were some fixes relating to your issue in recent versions, so make sure your running the latest version of GameEx.
i am using a tv, and all the rest of things: deskstop, programs are centered right. i am also using game ex 5.33
For anyone displaying windows on a TV: The software program Powerstrip is likely invaluable, although modern ATI and NVidia software sometimes do enough of a job.
Here is the link to Powerstrip. At least evaluate it for free to see if it's what you need. In addition don't forget the deadzone settings available in GameEx for final tweaking:
http://entechtaiwan.net/util/ps.shtm
Ideally for the best setup you will want to setup a resolution native to your TV, whether NTSC or PAL. Not sure off hand what these are though.
Tom
