Hey. So I use Custom Menus. I have Taito Type X set up as follows:
Arcade Games -> Arcade Machines -> Taito Type X
Every time I load up the TTX menu, GameEx crashes right after it loads the list of games. I noticed all my emus are crashing my system also as soon as the list pops up. Man it's fubared real bad! LOL
Here's the log file:
18:01:02.7 8/25/2011: Opening Configuration File
18:01:02.7 8/25/2011: GameEx: Version 12.05: Starting Log
18:01:02.7 8/25/2011: Operating System Platform: Win32NT
18:01:02.7 8/25/2011: Operating System Name: Windows Vista
18:01:02.7 8/25/2011: Operating System Version: 6.1.7601
18:01:02.7 8/25/2011: Aero running
18:01:02.7 8/25/2011: Initializing Vista/Windows 7 volume control
18:01:02.7 8/25/2011: Checking for versions of .net Framework installed
18:01:02.7 8/25/2011: .net Framework 2.0 Installed
18:01:02.7 8/25/2011: .net Framework 3.0 Installed
18:01:02.7 8/25/2011: .net Framework 3.5 Installed
18:01:02.7 8/25/2011: Intel® Core™2 Duo CPU E7500 @ 2.93GHz, 2047MB
18:01:02.7 8/25/2011: 2.93Ghz - 2 Cores or CPU's
18:01:02.7 8/25/2011: Running Randomize()
18:01:02.7 8/25/2011: Loading PlugIns
18:01:02.7 8/25/2011: Loaded Plugin:"Launch" Version 1.0 By Ben Baker
18:01:02.7 8/25/2011: PlugIn: "Launch" Initialized OK
18:01:02.7 8/25/2011: Using Plugin System Version: 1.4
18:01:02.7 8/25/2011: Checking for applications to Launch On Startup
18:01:02.7 8/25/2011: Launching and waiting: E:\BatFiles\StartUpNoMM.bat
18:01:02.8 8/25/2011: Running Misc startup tasks
18:01:02.8 8/25/2011: Setting Menu types
18:01:02.8 8/25/2011: Getting Configuration Values
18:01:02.8 8/25/2011: Using Theme: BlueBox
18:01:02.8 8/25/2011: Checking for alternate Image Directory for Theme: BlueBox
18:01:02.8 8/25/2011: Launching GameExtender.exe (GameExtender Viewer)
18:01:03.0 8/25/2011: Launching HideOS.exe
18:01:03.0 8/25/2011: Initialising Video/MNG DLL's
18:01:03.0 8/25/2011: GameEx will check for media insertion (may affect performance)
18:01:03.0 8/25/2011: Hiding Taskbar
18:01:03.0 8/25/2011: Using Cabinet Friendly Control System
18:01:03.0 8/25/2011: Is Media Center running?
18:01:03.0 8/25/2011: Checking/Creating LCD Registry values
18:01:03.0 8/25/2011: Check Media Center Exit/Start Mode
18:01:03.0 8/25/2011: Media Center Mode 2
18:01:03.0 8/25/2011: Video previews on. Warning: Only recommended on modern systems
18:01:03.0 8/25/2011: Custom Keyboard Input enabled: Getting custom codes
18:01:03.0 8/25/2011: Advanced Custom Keyboard Input enabled: Getting custom codes
18:01:03.0 8/25/2011: Snap Delay set to: 2
18:01:03.0 8/25/2011: Get other settings
18:01:03.0 8/25/2011: Desktop set to Hide ICONS and set Background to Black
18:01:03.0 8/25/2011: Set: Find emulator artwork on best match basis
18:01:03.0 8/25/2011: Using DirectInput for keyboard input
18:01:03.0 8/25/2011: Start work for Form
18:01:03.0 8/25/2011: Getting Original Screen Size
18:01:03.0 8/25/2011: Opening Database Connection
18:01:03.1 8/25/2011: Initializing Component
18:01:03.1 8/25/2011: Retrieving resolution setting
18:01:03.1 8/25/2011: MAME Path is: F:\Emulators\MAME
18:01:03.1 8/25/2011: Client/Server MAME Path is: C:\MAMEHub\dist
18:01:03.1 8/25/2011: Client/Server MAME EXE file is: vmame.exe
18:01:03.1 8/25/2011: Use Client/Server MAME On. vmame.exe will launch NetPlay games
18:01:03.1 8/25/2011: Model 2 Path Path is: F:\Emulators\M2
18:01:03.1 8/25/2011: Multi Core/Hyper Threading detected. Looking for emulator_multicpu.exe
18:01:03.1 8/25/2011: Model 2 EXE file is: emulator_multicpu.exe
18:01:03.1 8/25/2011: Model 2 emulator with command line support detected
18:01:03.1 8/25/2011: Use Model 2 on. emulator_multicpu.exe will launch Sega Model 2 games
18:01:03.1 8/25/2011: MAME EXE file is: mame.exe
18:01:03.1 8/25/2011: ROM Path is: F:\Emulators\MAME\roms
18:01:03.1 8/25/2011: Catver.ini is located at: F:\Emulators\MAME\Catver.ini
18:01:03.1 8/25/2011: controls.ini is located at: F:\Emulators\MAME\controls.ini
18:01:03.1 8/25/2011: History.dat is located at: F:\Emulators\MAME\history.dat
18:01:03.1 8/25/2011: nplayers.ini is located at: F:\Emulators\MAME\nplayers.ini
18:01:03.1 8/25/2011: command.dat is located at: C:\GameEx\DATA\command.dat
18:01:03.1 8/25/2011: MAMEinfo.dat is located at: F:\Emulators\MAME\mameinfo.dat
18:01:03.1 8/25/2011: Loading Controls.ini map file
18:01:03.1 8/25/2011: Snap Path is: F:\Emulators\MAME\extras\HitF12
18:01:03.1 8/25/2011: AVI Snap Path is: F:\Emulators\MAME\extras\videos
18:01:03.1 8/25/2011: Flyer Path is: F:\Emulators\MAME\extras\flyers
18:01:03.1 8/25/2011: Cabinet Path is: F:\Emulators\MAME\extras\cabinets
18:01:03.1 8/25/2011: Cabinet 3D Path is: F:\Emulators\MAME\extras\cabinets3d
18:01:03.1 8/25/2011: Title Path is: F:\Emulators\MAME\titles
18:01:03.1 8/25/2011: PCB Path is: F:\Emulators\MAME\extras\pcb
18:01:03.1 8/25/2011: Artwork Preview Path is: F:\Emulators\MAME\artworkgameex
18:01:03.1 8/25/2011: Panel Path is: F:\Emulators\MAME\cpanel
18:01:03.1 8/25/2011: Manual Path is: F:\Emulators\MAME\extras\manuals
18:01:03.1 8/25/2011: Icon Path is: F:\Emulators\MAME\icons
18:01:03.1 8/25/2011: Marquee Path is: F:\Emulators\MAME\extras\marquees
18:01:03.2 8/25/2011: Applying Language/Text
18:01:03.2 8/25/2011: Text/Language: Custom
18:01:03.2 8/25/2011: Loading Custom Emulators
18:01:03.2 8/25/2011: Loading Emulator 1: NINTENDO N64
18:01:03.2 8/25/2011: Loading Emulator 2: NINTENDO SNES
18:01:03.2 8/25/2011: Loading Emulator 3: NINTENDO NES
18:01:03.2 8/25/2011: Loading Emulator 4: NINTENDO GameBoy Advance
18:01:03.2 8/25/2011: Loading Emulator 5: NINTENDO GameBoy Color
18:01:03.2 8/25/2011: Loading Emulator 6: SEGA CD
18:01:03.2 8/25/2011: Loading Emulator 7: SEGA Genesis
18:01:03.2 8/25/2011: Loading Emulator 8: SEGA Master System
18:01:03.2 8/25/2011: Loading Emulator 9: SEGA Game Gear
18:01:03.2 8/25/2011: Loading Emulator 10: NEC TurboGrafx-16
18:01:03.2 8/25/2011: Loading Emulator 11: ATARI 2600
18:01:03.2 8/25/2011: Loading Emulator 12: ATARI 5200
18:01:03.2 8/25/2011: Loading Emulator 13: ATARI 7800
18:01:03.2 8/25/2011: Loading Emulator 14: COLECO Vision
18:01:03.2 8/25/2011: Loading Emulator 15: MATTEL Intellivision
18:01:03.2 8/25/2011: Loading Emulator 17: VISUAL PinMAME
18:01:03.2 8/25/2011: Loading Emulator 19: ATARI Lynx
18:01:03.2 8/25/2011: Loading Emulator 20: SONY Playstation
18:01:03.2 8/25/2011: Loading Emulator 21: SEGA Saturn
18:01:03.2 8/25/2011: Loading Emulator 22: NINTENDO Game Cube
18:01:03.2 8/25/2011: Loading Emulator 23: MICROSOFT Windows
18:01:03.2 8/25/2011: Loading Emulator 24: OPEN Beats Of Rage
18:01:03.2 8/25/2011: Loading Emulator 25: MICROSOFT Windows
18:01:03.2 8/25/2011: Loading Emulator 27: NINTENDO DS
18:01:03.2 8/25/2011: Loading Emulator 28: SEGA Dreamcast
18:01:03.2 8/25/2011: Loading Emulator 29: FUTURE Pinball
18:01:03.2 8/25/2011: Loading Emulator 30: HOMEBREW Games
18:01:03.2 8/25/2011: Loading Emulator 31: TAITO Type X
18:01:03.2 8/25/2011: Loading Emulator Group 1: MICROSOFT Windows
18:01:03.2 8/25/2011: Using Version 3 Themes Animations
18:01:03.2 8/25/2011: Using General Font: Tahoma
18:01:03.2 8/25/2011: Using Title Font: Tahoma
18:01:03.3 8/25/2011: Initialising Direct3D
18:01:03.3 8/25/2011: Applying GameEx is Loading Image
18:01:03.4 8/25/2011: Setting Resolution to 1620x1024 32 bit color
18:01:03.4 8/25/2011: Creating Surfaces
18:01:03.8 8/25/2011: Creating Primary Surface - Full Screen Mode
18:01:03.8 8/25/2011: Creating Back Buffer
18:01:03.8 8/25/2011: Version 2 Theme being used. Loading.
18:01:03.8 8/25/2011: Loading Button Data
18:01:03.8 8/25/2011: Loading Font Data
18:01:03.8 8/25/2011: Loading Layout Data
18:01:03.8 8/25/2011: Loading Taskbar Data
18:01:03.8 8/25/2011: Loading graphic Surfaces
18:01:03.8 8/25/2011: Display is running at: 1680x1050 32bit color, 59hz
18:01:03.9 8/25/2011: Creating Surfaces Misc and Dialogs
18:01:03.9 8/25/2011: Creating Surfaces Volume
18:01:03.9 8/25/2011: Creating Surfaces Arrows
18:01:03.9 8/25/2011: Creating Surfaces GameEXlogo Text
18:01:03.9 8/25/2011: Creating Surfaces Toolbar
18:01:04.0 8/25/2011: Creating Surfaces Backgrounds
18:01:04.0 8/25/2011: Creating Surfaces Toolbar Controls
18:01:04.0 8/25/2011: Creating Surfaces GameEx Logo
18:01:04.0 8/25/2011: Creating Surface Unselected
18:01:04.0 8/25/2011: Creating Surfaces Snaps
18:01:04.0 8/25/2011: Creating Surfaces Menu and List Bars
18:01:04.0 8/25/2011: Creating Fonts
18:01:04.0 8/25/2011: Creating Game Font
18:01:04.1 8/25/2011: Creating Game Font Faded
18:01:04.2 8/25/2011: Creating Title Font
18:01:04.2 8/25/2011: Restoring Title Font From Cache
18:01:04.3 8/25/2011: Creating Font Black
18:01:04.4 8/25/2011: Creating Font Black Small
18:01:04.4 8/25/2011: Fonts Created Succesfully
18:01:04.4 8/25/2011: 7MB Video Memory Used
18:01:04.4 8/25/2011: Initialising Bass Audio Library
18:01:04.4 8/25/2011: Creating instance of global keyboard hook
18:01:05.4 8/25/2011: Attempting to load game list
18:01:05.5 8/25/2011: GameExtender Not found snap: F:\Images\no_img.png
18:01:05.5 8/25/2011: Starting GameExtender on: 192.168.1.151:8383
18:01:05.5 8/25/2011: GameExtender using specific custom images for systems.
18:01:05.5 8/25/2011: MAME CMD options: -nowindow -joy -mt -video d3d -numscreens 2 -noka -cheat
18:01:05.5 8/25/2011: Loading last used Game List
18:01:05.5 8/25/2011: Loading Start Page
18:01:05.5 8/25/2011: Creating DirectSound Device
18:01:05.6 8/25/2011: Trying: Primary Sound Driver
18:01:05.6 8/25/2011: Loading Sound Files
18:01:05.6 8/25/2011: DirectSound Device Created Successfully
18:01:05.6 8/25/2011: Initialising DirectInput for Gamepad support
18:01:05.6 8/25/2011: GameEx will just check for activity on Gamepad
18:01:05.6 8/25/2011: Using Device Controller (Xbox 360 Wireless Receiver for Windows)
18:01:05.7 8/25/2011: Initialising DirectInput for Keyboard support
18:01:05.7 8/25/2011: Initializing MCE Remote
18:01:05.7 8/25/2011: Playing intro sound file
18:01:05.8 8/25/2011: Initialization OK! Starting GameEx!
18:01:05.8 8/25/2011: Testing Main Loop Once: Processing Frame
18:01:06.1 8/25/2011: Testing Main Loop Once: Main Loop ran successfully
18:01:19.5 8/25/2011: Validating: Emulator_1: Custom Background: Back - N64.png
18:01:19.5 8/25/2011: Validating: Emulator_1: Snap Path: F:\Emulators\PJ64\Artwork\Video_AVI
18:01:19.5 8/25/2011: Validating: Emulator_1: Not Found Image: F:\Images\no_img.png
18:01:19.5 8/25/2011: Validating: Emulator_1: Custom Art Path 1: F:\Emulators\PJ64\Artwork\Snap
18:01:19.5 8/25/2011: Validating: Emulator_1: Custom Art Path 2: F:\Emulators\PJ64\Artwork\Advert
18:01:19.5 8/25/2011: Validating: Emulator_1: Control Panel Path: F:\Images\Controls\Emulators\N64.png
18:01:19.5 8/25/2011: Validating: Emulator_1: Database: [Console] Nintendo N64
18:01:19.5 8/25/2011: Validating: Emulator_1: Title Snap Path: F:\Emulators\PJ64\Artwork\Title
18:01:19.5 8/25/2011: Validating: Emulator_1: Box Art Path: F:\Emulators\PJ64\Artwork\Box
18:01:19.5 8/25/2011: Validating: Emulator_1: Cart Art Path: F:\Emulators\PJ64\Artwork\Cart
18:01:19.5 8/25/2011: Validating: Emulator_1: Manual Path: F:\Emulators\PJ64\Artwork\Manual
18:01:19.5 8/25/2011: Validating: Emulator_2: Custom Background: Back - Snes.png
18:01:19.5 8/25/2011: Validating: Emulator_2: Snap Path: F:\Emulators\ZSNES\Artwork\Video_AVI
18:01:19.5 8/25/2011: Validating: Emulator_2: Not Found Image: F:\Images\no_img.png
18:01:19.5 8/25/2011: Validating: Emulator_2: Custom Art Path 1: F:\Emulators\ZSNES\Artwork\Snap
18:01:19.5 8/25/2011: Validating: Emulator_2: Custom Art Path 2: F:\Emulators\ZSNES\Artwork\Advert
18:01:19.5 8/25/2011: Validating: Emulator_2: Control Panel Path: F:\Images\Controls\Emulators\SNES.png
18:01:19.5 8/25/2011: Validating: Emulator_2: Database: [Console] Nintendo SNES
18:01:19.5 8/25/2011: Validating: Emulator_2: Title Snap Path: F:\Emulators\ZSNES\Artwork\Title
18:01:19.5 8/25/2011: Validating: Emulator_2: Box Art Path: F:\Emulators\ZSNES\Artwork\Box
18:01:19.5 8/25/2011: Validating: Emulator_2: Cart Art Path: F:\Emulators\ZSNES\Artwork\Cart
18:01:19.5 8/25/2011: Validating: Emulator_2: Music Path: F:\Emulators\ZSNES\Artwork\Music
18:01:19.5 8/25/2011: Validating: Emulator_2: Manual Path: F:\Emulators\ZSNES\Artwork\Manual
18:01:19.5 8/25/2011: Validating: Emulator_3: Custom Background: Back - NES.png
18:01:19.5 8/25/2011: Validating: Emulator_3: Snap Path: F:\Emulators\NESTopia\artwork\Video_AVI
18:01:19.5 8/25/2011: Validating: Emulator_3: Not Found Image: F:\Images\no_img.png
18:01:19.5 8/25/2011: Validating: Emulator_3: Custom Art Path 1: F:\Emulators\NESTopia\artwork\Snap
18:01:19.5 8/25/2011: Validating: Emulator_3: Custom Art Path 2: F:\Emulators\NESTopia\artwork\Advert
18:01:19.5 8/25/2011: Validating: Emulator_3: Control Panel Path: F:\Images\Controls\Emulators\NES.png
18:01:19.5 8/25/2011: Validating: Emulator_3: Database: [Console] Nintendo NES
18:01:19.5 8/25/2011: Validating: Emulator_3: Title Snap Path: F:\Emulators\NESTopia\artwork\Title
18:01:19.5 8/25/2011: Validating: Emulator_3: Box Art Path: F:\Emulators\NESTopia\artwork\Box
18:01:19.5 8/25/2011: Validating: Emulator_3: Cart Art Path: F:\Emulators\NESTopia\artwork\Cart
18:01:19.5 8/25/2011: Validating: Emulator_3: Music Path: F:\Emulators\NESTopia\artwork\Music
18:01:19.5 8/25/2011: Validating: Emulator_3: TV Ad Path: F:\Emulators\NESTopia\artwork\Video_Advert_AVI
18:01:19.5 8/25/2011: Validating: Emulator_3: Manual Path: F:\Emulators\NESTopia\artwork\Manual
18:01:19.5 8/25/2011: Validating: Emulator_4: Custom Background: Back - Gameboy Advance.png
18:01:19.5 8/25/2011: Validating: Emulator_4: Snap Path: F:\Emulators\VBA\Artwork\GBA\Video_AVI
18:01:19.5 8/25/2011: Validating: Emulator_4: Not Found Image: F:\Images\no_img.png
18:01:19.5 8/25/2011: Validating: Emulator_4: Custom Art Path 1: F:\Emulators\VBA\Artwork\GBA\Snap
18:01:19.5 8/25/2011: Validating: Emulator_4: Custom Art Path 2: F:\Emulators\VBA\Artwork\GBA\Advert
18:01:19.5 8/25/2011: Validating: Emulator_4: Control Panel Path: F:\Images\Controls\Emulators\Gameboy Advance.png
18:01:19.5 8/25/2011: Validating: Emulator_4: Database: [Handheld] Nintendo Game Boy Advance
18:01:19.5 8/25/2011: Validating: Emulator_4: Title Snap Path: F:\Emulators\VBA\Artwork\GBA\Title
18:01:19.5 8/25/2011: Validating: Emulator_4: Box Art Path: F:\Emulators\VBA\Artwork\GBA\Box
18:01:19.5 8/25/2011: Validating: Emulator_4: Cart Art Path: F:\Emulators\VBA\Artwork\GBA\Cart
18:01:19.5 8/25/2011: Validating: Emulator_5: Custom Background: Back - Gameboy Color.png
18:01:19.5 8/25/2011: Validating: Emulator_5: Snap Path: F:\Emulators\VBA\Artwork\GBC\Video_AVI
18:01:19.5 8/25/2011: Validating: Emulator_5: Not Found Image: F:\Images\no_img.png
18:01:19.5 8/25/2011: Validating: Emulator_5: Custom Art Path 1: F:\Emulators\VBA\Artwork\GBC\Snap
18:01:19.5 8/25/2011: Validating: Emulator_5: Custom Art Path 2: F:\Emulators\VBA\Artwork\GBC\Advert
18:01:19.5 8/25/2011: Validating: Emulator_5: Control Panel Path: F:\Images\Controls\Emulators\Gameboy Color.png
18:01:19.5 8/25/2011: Validating: Emulator_5: Database: [Handheld] Nintendo Game Boy Color
18:01:19.5 8/25/2011: Validating: Emulator_5: Title Snap Path: F:\Emulators\VBA\Artwork\GBC\Title
18:01:19.5 8/25/2011: Validating: Emulator_5: Box Art Path: F:\Emulators\VBA\Artwork\GBC\Box
18:01:19.5 8/25/2011: Validating: Emulator_5: Cart Art Path: F:\Emulators\VBA\Artwork\GBC\Cart
18:01:19.5 8/25/2011: Validating: Emulator_5: Music Path: F:\Emulators\VBA\Artwork\GBC\Music
18:01:19.5 8/25/2011: Validating: Emulator_5: TV Ad Path: F:\Emulators\VBA\Artwork\GBC\Video_Advert_AVI
18:01:19.5 8/25/2011: Validating: Emulator_5: Manual Path: F:\Emulators\VBA\Artwork\GBC\Manual
18:01:19.5 8/25/2011: Validating: Emulator_6: Custom Background:
18:01:19.5 8/25/2011: Warning: Emulator_6: Custom Background Does not exist
18:01:19.5 8/25/2011: Validating: Emulator_6: Snap Path: F:\Emulators\FusionCD\Artwork\Video_AVI
18:01:19.5 8/25/2011: Validating: Emulator_6: Not Found Image: F:\Images\no_img.png
18:01:19.5 8/25/2011: Validating: Emulator_6: Custom Art Path 1: F:\Emulators\FusionCD\Artwork\Snap
18:01:19.5 8/25/2011: Validating: Emulator_6: Custom Art Path 2: F:\Emulators\FusionCD\Artwork\Advert
18:01:19.5 8/25/2011: Validating: Emulator_6: Custom Art Path 3: F:\Emulators\FusionCD\Artwork\BoxBack
18:01:19.5 8/25/2011: Validating: Emulator_6: Control Panel Path: F:\Images\Controls\Emulators\Sega CD.png
18:01:19.5 8/25/2011: Validating: Emulator_6: Database: [Console] Sega CD
18:01:19.5 8/25/2011: Validating: Emulator_6: Title Snap Path: F:\Emulators\FusionCD\Artwork\Title
18:01:19.5 8/25/2011: Validating: Emulator_6: Box Art Path: F:\Emulators\FusionCD\Artwork\Box
18:01:19.5 8/25/2011: Validating: Emulator_6: Cart Art Path: F:\Emulators\FusionCD\Artwork\CD
18:01:19.5 8/25/2011: Validating: Emulator_6: Manual Path: F:\Emulators\FusionCD\Artwork\Manual
18:01:19.5 8/25/2011: Validating: Emulator_7: Custom Background: Back - Genesis.png
18:01:19.5 8/25/2011: Validating: Emulator_7: Snap Path: F:\Emulators\Fusion\artwork\gen\Video_AVI
18:01:19.5 8/25/2011: Validating: Emulator_7: Not Found Image: F:\Images\no_img.png
18:01:19.5 8/25/2011: Validating: Emulator_7: Custom Art Path 1: F:\Emulators\Fusion\artwork\gen\Snap
18:01:19.5 8/25/2011: Validating: Emulator_7: Custom Art Path 2: F:\Emulators\Fusion\artwork\gen\Advert
18:01:19.5 8/25/2011: Validating: Emulator_7: Control Panel Path: F:\Images\Controls\Emulators\Genesis.png
18:01:19.5 8/25/2011: Validating: Emulator_7: Database: [Console] Sega Genesis
18:01:19.5 8/25/2011: Validating: Emulator_7: Title Snap Path: F:\Emulators\Fusion\artwork\gen\Title
18:01:19.5 8/25/2011: Validating: Emulator_7: Box Art Path: F:\Emulators\Fusion\artwork\gen\Box
18:01:19.5 8/25/2011: Validating: Emulator_7: Cart Art Path: F:\Emulators\Fusion\artwork\gen\Cart
18:01:19.5 8/25/2011: Validating: Emulator_7: Music Path: F:\Emulators\Fusion\artwork\gen\Music
18:01:19.5 8/25/2011: Validating: Emulator_7: Manual Path: F:\Emulators\Fusion\artwork\gen\Manual
18:01:19.5 8/25/2011: Validating: Emulator_8: Custom Background: Back - Master System.png
18:01:19.5 8/25/2011: Validating: Emulator_8: Snap Path: F:\Emulators\Fusion\artwork\sms\Video_AVI
18:01:19.5 8/25/2011: Validating: Emulator_8: Not Found Image: F:\Images\no_img.png
18:01:19.5 8/25/2011: Validating: Emulator_8: Custom Art Path 1: F:\Emulators\Fusion\artwork\sms\Snap
18:01:19.5 8/25/2011: Validating: Emulator_8: Control Panel Path: F:\Images\Controls\Emulators\Master System.png
18:01:19.5 8/25/2011: Validating: Emulator_8: Database: [Console] Sega Master System
18:01:19.5 8/25/2011: Validating: Emulator_8: Title Snap Path: F:\Emulators\Fusion\artwork\sms\Title
18:01:19.5 8/25/2011: Validating: Emulator_8: Box Art Path: F:\Emulators\Fusion\artwork\sms\Box
18:01:19.5 8/25/2011: Validating: Emulator_8: Cart Art Path: F:\Emulators\Fusion\artwork\sms\Cart
18:01:19.5 8/25/2011: Validating: Emulator_8: Manual Path: F:\Emulators\Fusion\artwork\sms\Manual
18:01:19.5 8/25/2011: Validating: Emulator_9: Custom Background: Back - Game Gear.png
18:01:19.5 8/25/2011: Validating: Emulator_9: Snap Path: F:\Emulators\Fusion\artwork\gg\Video_AVI
18:01:19.5 8/25/2011: Validating: Emulator_9: Not Found Image: F:\Images\no_img.png
18:01:19.5 8/25/2011: Validating: Emulator_9: Custom Art Path 1: F:\Emulators\Fusion\artwork\gg\Snap
18:01:19.5 8/25/2011: Validating: Emulator_9: Custom Art Path 2: F:\Emulators\Fusion\artwork\gg\Advert
18:01:19.5 8/25/2011: Validating: Emulator_9: Control Panel Path: F:\Images\Controls\Emulators\Game Gear.png
18:01:19.5 8/25/2011: Validating: Emulator_9: Database: [Handheld] Sega Game Gear
18:01:19.5 8/25/2011: Validating: Emulator_9: Title Snap Path: F:\Emulators\Fusion\artwork\gg\Title
18:01:19.5 8/25/2011: Validating: Emulator_9: Box Art Path: F:\Emulators\Fusion\artwork\gg\Box
18:01:19.5 8/25/2011: Validating: Emulator_9: Cart Art Path: F:\Emulators\Fusion\artwork\gg\Cart
18:01:19.5 8/25/2011: Validating: Emulator_9: Manual Path: F:\Emulators\Fusion\artwork\gg\Manual
18:01:19.5 8/25/2011: Validating: Emulator_10: Custom Background: Back - NEC PC Engine.png
18:01:19.5 8/25/2011: Validating: Emulator_10: Snap Path: F:\Emulators\MagicEngine\Artwork\Video_AVI
18:01:19.5 8/25/2011: Validating: Emulator_10: Not Found Image: F:\Images\no_img.png
18:01:19.5 8/25/2011: Validating: Emulator_10: Custom Art Path 1: F:\Emulators\MagicEngine\Artwork\Snap
18:01:19.5 8/25/2011: Validating: Emulator_10: Control Panel Path: F:\Images\Controls\Emulators\TG 16.png
18:01:19.5 8/25/2011: Validating: Emulator_10: Database: [Console] NEC TurboGrafx-16
18:01:19.5 8/25/2011: Validating: Emulator_10: Title Snap Path: F:\Emulators\MagicEngine\Artwork\Title
18:01:19.5 8/25/2011: Validating: Emulator_10: Box Art Path: F:\Emulators\MagicEngine\Artwork\Box
18:01:19.5 8/25/2011: Validating: Emulator_10: Cart Art Path: F:\Emulators\MagicEngine\Artwork\Cart
18:01:19.5 8/25/2011: Validating: Emulator_10: Manual Path: F:\Emulators\MagicEngine\Artwork\Manual
18:01:19.5 8/25/2011: Validating: Emulator_11: Custom Background: Back - Atari 2600.png
18:01:19.5 8/25/2011: Validating: Emulator_11: Snap Path: F:\Emulators\Stella\Artwork\Video_AVI
18:01:19.5 8/25/2011: Validating: Emulator_11: Not Found Image: F:\Images\no_img.png
18:01:19.5 8/25/2011: Validating: Emulator_11: Custom Art Path 1: F:\Emulators\Stella\Artwork\Snap
18:01:19.5 8/25/2011: Validating: Emulator_11: Custom Art Path 2: F:\Emulators\Stella\Artwork\Overlay
18:01:19.5 8/25/2011: Validating: Emulator_11: Control Panel Path: F:\Images\Controls\Emulators\Atari 2600.png
18:01:19.5 8/25/2011: Validating: Emulator_11: Database: [Console] Atari 2600
18:01:19.5 8/25/2011: Validating: Emulator_11: Box Art Path: F:\Emulators\Stella\Artwork\Box
18:01:19.5 8/25/2011: Validating: Emulator_11: Cart Art Path: F:\Emulators\Stella\Artwork\Cart
18:01:19.5 8/25/2011: Validating: Emulator_11: Manual Path: F:\Emulators\Stella\Artwork\Manual
18:01:19.5 8/25/2011: Validating: Emulator_12: Custom Background: Back - Atari 5200.png
18:01:19.5 8/25/2011: Validating: Emulator_12: Snap Path: F:\Emulators\kat5200\Artwork\Snap
18:01:19.5 8/25/2011: Validating: Emulator_12: Not Found Image: F:\Images\no_img.png
18:01:19.5 8/25/2011: Validating: Emulator_12: Custom Art Path 1: F:\Emulators\kat5200\Artwork\BoxBack
18:01:19.5 8/25/2011: Validating: Emulator_12: Custom Art Path 2: F:\Emulators\kat5200\Artwork\Overlay
18:01:19.5 8/25/2011: Validating: Emulator_12: Custom Art Path 3: F:\Emulators\kat5200\Artwork\Box_3D
18:01:19.5 8/25/2011: Validating: Emulator_12: Control Panel Path: F:\Images\Controls\Emulators\Atari 5200.png
18:01:19.5 8/25/2011: Validating: Emulator_12: Database: [Console] Atari 5200
18:01:19.5 8/25/2011: Validating: Emulator_12: Title Snap Path: F:\Emulators\kat5200\Artwork\Title
18:01:19.5 8/25/2011: Validating: Emulator_12: Box Art Path: F:\Emulators\kat5200\Artwork\Box
18:01:19.5 8/25/2011: Validating: Emulator_12: Cart Art Path: F:\Emulators\kat5200\Artwork\Cart
18:01:19.5 8/25/2011: Validating: Emulator_12: Manual Path: F:\Emulators\kat5200\Artwork\Manual
18:01:19.5 8/25/2011: Validating: Emulator_13: Custom Background: Back - Atari 7800.png
18:01:19.5 8/25/2011: Validating: Emulator_13: Snap Path: F:\Emulators\MESS\artwork\7800\Snap
18:01:19.5 8/25/2011: Validating: Emulator_13: Not Found Image: F:\Images\no_img.png
18:01:19.5 8/25/2011: Validating: Emulator_13: Control Panel Path: F:\Images\Controls\Emulators\Atari 7800.png
18:01:19.5 8/25/2011: Validating: Emulator_13: Database: [Console] Atari 7800
18:01:19.5 8/25/2011: Validating: Emulator_13: Title Snap Path: F:\Emulators\MESS\artwork\7800\Title
18:01:19.5 8/25/2011: Validating: Emulator_13: Box Art Path: F:\Emulators\MESS\artwork\7800\Box
18:01:19.5 8/25/2011: Validating: Emulator_13: Cart Art Path: F:\Emulators\MESS\artwork\7800\Cart
18:01:19.5 8/25/2011: Validating: Emulator_13: TV Ad Path: F:\Emulators\MESS\artwork\7800\Video_Advert_AVI
18:01:19.5 8/25/2011: Validating: Emulator_13: Manual Path: F:\Emulators\MESS\artwork\7800\Manual
18:01:19.5 8/25/2011: Validating: Emulator_14: Custom Background: Back - Colecovision.png
18:01:19.5 8/25/2011: Validating: Emulator_14: Snap Path: F:\Emulators\MESS\artwork\Colecovision\Video_AVI
18:01:19.5 8/25/2011: Validating: Emulator_14: Not Found Image: F:\Images\no_img.png
18:01:19.5 8/25/2011: Validating: Emulator_14: Custom Art Path 1: F:\Emulators\MESS\artwork\Colecovision\Snap
18:01:19.5 8/25/2011: Validating: Emulator_14: Custom Art Path 2: F:\Emulators\MESS\artwork\Colecovision\Overlay
18:01:19.5 8/25/2011: Validating: Emulator_14: Control Panel Path: F:\Images\Controls\Emulators\Colecovision.png
18:01:19.5 8/25/2011: Validating: Emulator_14: Database: [Console] Coleco Vision
18:01:19.5 8/25/2011: Validating: Emulator_14: Title Snap Path: F:\Emulators\MESS\artwork\Colecovision\Title
18:01:19.5 8/25/2011: Validating: Emulator_14: Box Art Path: F:\Emulators\MESS\artwork\Colecovision\Box
18:01:19.5 8/25/2011: Validating: Emulator_14: Cart Art Path: F:\Emulators\MESS\artwork\Colecovision\Cart
18:01:19.5 8/25/2011: Validating: Emulator_14: Manual Path: F:\Emulators\MESS\artwork\Colecovision\Manual
18:01:19.5 8/25/2011: Validating: Emulator_15: Custom Background: Back - Intellivision.png
18:01:19.5 8/25/2011: Validating: Emulator_15: Snap Path: F:\Emulators\Bliss\Artwork\Snap
18:01:19.5 8/25/2011: Validating: Emulator_15: Not Found Image: F:\Images\no_img.png
18:01:19.5 8/25/2011: Validating: Emulator_15: Custom Art Path 1: F:\Emulators\Bliss\Artwork\Overlay
18:01:19.5 8/25/2011: Validating: Emulator_15: Custom Art Path 2: F:\Emulators\Bliss\Artwork\CartTop
18:01:19.5 8/25/2011: Validating: Emulator_15: Control Panel Path: F:\Images\Controls\Emulators\Intellivision.png
18:01:19.5 8/25/2011: Validating: Emulator_15: Database: [Console] Mattel Intellivision
18:01:19.5 8/25/2011: Validating: Emulator_15: Title Snap Path: F:\Emulators\Bliss\Artwork\Title
18:01:19.5 8/25/2011: Validating: Emulator_15: Box Art Path: F:\Emulators\Bliss\Artwork\Box
18:01:19.5 8/25/2011: Validating: Emulator_15: Cart Art Path: F:\Emulators\Bliss\Artwork\Cart
18:01:19.5 8/25/2011: Validating: Emulator_15: Manual Path: F:\Emulators\Bliss\Artwork\Manual
18:01:19.5 8/25/2011: Validating: Emulator_17: Custom Background: Back - Visual PinMAME.png
18:01:19.5 8/25/2011: Validating: Emulator_17: Snap Path: E:\Pinball\artwork\Snap
18:01:19.5 8/25/2011: Validating: Emulator_17: Not Found Image: F:\Images\no_img.png
18:01:19.5 8/25/2011: Validating: Emulator_17: Custom Art Path 1: F:\Pinball\artwork\Backglass
18:01:19.5 8/25/2011: Warning: Emulator_17: Custom Art Path 1 Does not exist
18:01:19.5 8/25/2011: Validating: Emulator_17: Custom Art Path 2: F:\Pinball\artwork\Playfield
18:01:19.5 8/25/2011: Warning: Emulator_17: Custom Art Path 2 Does not exist
18:01:19.5 8/25/2011: Validating: Emulator_17: Custom Art Path 3: F:\Pinball\artwork\Flyer
18:01:19.5 8/25/2011: Warning: Emulator_17: Custom Art Path 3 Does not exist
18:01:19.5 8/25/2011: Validating: Emulator_17: Control Panel Path: F:\Images\Controls\Emulators\Visual PinMAME.png
18:01:19.5 8/25/2011: Validating: Emulator_17: Database: [Pinball] Visual Pinball
18:01:19.5 8/25/2011: Validating: Emulator_17: Manual Path: E:\Pinball\artwork\Manual
18:01:19.5 8/25/2011: Validating: Emulator_19: Custom Background: Back - Atari Lynx.png
18:01:19.5 8/25/2011: Validating: Emulator_19: Snap Path: F:\Emulators\Handy\Artwork\Snap
18:01:19.5 8/25/2011: Validating: Emulator_19: Not Found Image: F:\Images\no_img.png
18:01:19.5 8/25/2011: Validating: Emulator_19: Custom Art Path 1: F:\Emulators\Handy\Artwork\BoxBack
18:01:19.5 8/25/2011: Validating: Emulator_19: Database: [Handheld] Atari Lynx
18:01:19.5 8/25/2011: Validating: Emulator_19: Title Snap Path: F:\Emulators\Handy\Artwork\Title
18:01:19.5 8/25/2011: Validating: Emulator_19: Box Art Path: F:\Emulators\Handy\Artwork\Box
18:01:19.5 8/25/2011: Validating: Emulator_19: Cart Art Path: F:\Emulators\Handy\Artwork\Cart
18:01:19.5 8/25/2011: Validating: Emulator_19: Manual Path: F:\Emulators\Handy\Artwork\Manual
18:01:19.5 8/25/2011: Validating: Emulator_20: Custom Background: Back - Playstation.png
18:01:19.5 8/25/2011: Validating: Emulator_20: Snap Path: F:\Emulators\pSX\artwork\snap
18:01:19.5 8/25/2011: Validating: Emulator_20: Not Found Image: F:\Images\no_img.png
18:01:19.5 8/25/2011: Validating: Emulator_20: Control Panel Path: F:\Images\Controls\Emulators\PSX.png
18:01:19.5 8/25/2011: Validating: Emulator_20: Database: [Console] Sony Playstation
18:01:19.5 8/25/2011: Validating: Emulator_20: Title Snap Path: F:\Emulators\pSX\artwork\title
18:01:19.5 8/25/2011: Validating: Emulator_20: Box Art Path: F:\Emulators\pSX\artwork\box
18:01:19.5 8/25/2011: Validating: Emulator_20: Cart Art Path: F:\Emulators\pSX\artwork\box
18:01:19.6 8/25/2011: Validating: Emulator_20: Manual Path: F:\Emulators\pSX\artwork\manual
18:01:19.6 8/25/2011: Validating: Emulator_21: Custom Background: Back - Saturn.png
18:01:19.6 8/25/2011: Validating: Emulator_21: Snap Path: F:\Emulators\SSF\Artwork\Snap
18:01:19.6 8/25/2011: Validating: Emulator_21: Not Found Image: F:\Images\no_img.png
18:01:19.6 8/25/2011: Validating: Emulator_21: Custom Art Path 1: F:\Emulators\SSF\Artwork\BoxBack
18:01:19.6 8/25/2011: Validating: Emulator_21: Custom Art Path 2: F:\Emulators\SSF\Artwork\Advert
18:01:19.6 8/25/2011: Validating: Emulator_21: Control Panel Path: F:\Images\Controls\Emulators\Saturn.png
18:01:19.6 8/25/2011: Validating: Emulator_21: Database: [Console] Sega Saturn
18:01:19.6 8/25/2011: Validating: Emulator_21: Title Snap Path: F:\Emulators\SSF\Artwork\Title
18:01:19.6 8/25/2011: Validating: Emulator_21: Box Art Path: F:\Emulators\SSF\Artwork\Box
18:01:19.6 8/25/2011: Validating: Emulator_21: Cart Art Path: F:\Emulators\SSF\Artwork\CD
18:01:19.6 8/25/2011: Validating: Emulator_21: Manual Path: F:\Emulators\SSF\Artwork\Manual
18:01:19.6 8/25/2011: Validating: Emulator_22: Custom Background:
18:01:19.6 8/25/2011: Warning: Emulator_22: Custom Background Does not exist
18:01:19.6 8/25/2011: Validating: Emulator_22: Snap Path: F:\Emulators\Dolphin\Artwork\Snap
18:01:19.6 8/25/2011: Validating: Emulator_22: Not Found Image: F:\Images\no_img.png
18:01:19.6 8/25/2011: Validating: Emulator_22: Control Panel Path: F:\Images\Controls\Emulators\Game Cube.png
18:01:19.6 8/25/2011: Validating: Emulator_22: Database: [Console] Nintendo GameCube
18:01:19.6 8/25/2011: Validating: Emulator_22: Title Snap Path: F:\Emulators\Dolphin\Artwork\Title
18:01:19.6 8/25/2011: Validating: Emulator_22: Box Art Path: F:\Emulators\Dolphin\Artwork\Box
18:01:19.6 8/25/2011: Validating: Emulator_22: Cart Art Path: F:\Emulators\Dolphin\Artwork\Cart
18:01:19.6 8/25/2011: Validating: Emulator_22: Manual Path: F:\Emulators\Dolphin\Artwork\Manual
18:01:19.6 8/25/2011: Validating: Emulator_23: Custom Background: Back - Windows.png
18:01:19.6 8/25/2011: Validating: Emulator_23: Snap Path: E:\WinGames\Artwork\Snaps
18:01:19.6 8/25/2011: Validating: Emulator_23: Not Found Image: F:\Images\no_img.png
18:01:19.6 8/25/2011: Validating: Emulator_23: Control Panel Path: F:\Images\Controls\Windows
18:01:19.6 8/25/2011: Validating: Emulator_23: Title Snap Path: E:\WinGames\Artwork\Titles
18:01:19.6 8/25/2011: Validating: Emulator_23: Box Art Path: E:\WinGames\Artwork\Boxes
18:01:19.6 8/25/2011: Validating: Emulator_23: Cart Art Path: E:\WinGames\Artwork\Discs
18:01:19.6 8/25/2011: Validating: Emulator_23: Manual Path: E:\WinGames\Artwork\Manuals
18:01:19.6 8/25/2011: Validating: Emulator_24: Custom Background: Back - OBOR.png
18:01:19.6 8/25/2011: Validating: Emulator_24: Snap Path: F:\Emulators\OpenBOR\Artwork\Snap
18:01:19.6 8/25/2011: Validating: Emulator_24: Control Panel Path: F:\Images\Controls\Emulators\Open BOR.png
18:01:19.6 8/25/2011: Validating: Emulator_24: Title Snap Path: F:\Emulators\OpenBOR\Artwork\Title
18:01:19.6 8/25/2011: Validating: Emulator_25: Custom Background: Back - Windows.png
18:01:19.6 8/25/2011: Validating: Emulator_25: Snap Path: E:\WinGames\Artwork\Snaps
18:01:19.6 8/25/2011: Validating: Emulator_25: Not Found Image: F:\Images\no_img.png
18:01:19.6 8/25/2011: Validating: Emulator_25: Control Panel Path: F:\Images\Controls\Windows
18:01:19.6 8/25/2011: Validating: Emulator_25: Title Snap Path: E:\WinGames\Artwork\Titles
18:01:19.6 8/25/2011: Validating: Emulator_25: Box Art Path: E:\WinGames\Artwork\Boxes
18:01:19.6 8/25/2011: Validating: Emulator_25: Cart Art Path: E:\WinGames\Artwork\Discs
18:01:19.6 8/25/2011: Validating: Emulator_25: Manual Path: E:\WinGames\Artwork\Manuals
18:01:19.6 8/25/2011: Validating: Emulator_27: Custom Background: Back - Nintendo DS.png
18:01:19.6 8/25/2011: Validating: Emulator_27: Snap Path:
18:01:19.6 8/25/2011: Validating: Emulator_27: Not Found Image: F:\Images\no_img.png
18:01:19.6 8/25/2011: Validating: Emulator_27: Control Panel Path: F:\Images\Controls\Emulators\Nintendo DS.png
18:01:19.6 8/25/2011: Validating: Emulator_27: Database: [Handheld] Nintendo DS
18:01:19.6 8/25/2011: Validating: Emulator_28: Custom Background: Back - Dreamcast.png
18:01:19.6 8/25/2011: Validating: Emulator_28: Snap Path: F:\Emulators\NullDC\artwork\Snaps
18:01:19.6 8/25/2011: Validating: Emulator_28: Not Found Image: F:\Images\no_img.png
18:01:19.6 8/25/2011: Validating: Emulator_28: Database: [Console] Sega Dreamcast
18:01:19.6 8/25/2011: Validating: Emulator_28: Title Snap Path: F:\Emulators\NullDC\artwork\Titles
18:01:19.6 8/25/2011: Validating: Emulator_29: Custom Background: Back - Future Pinball.png
18:01:19.6 8/25/2011: Validating: Emulator_29: Snap Path: E:\Future Pinball\Artwork\Snaps
18:01:19.6 8/25/2011: Validating: Emulator_29: Not Found Image: F:\Images\no_img.png
18:01:19.6 8/25/2011: Validating: Emulator_29: Database: [Pinball] Future Pinball
18:01:19.6 8/25/2011: Validating: Emulator_30: Custom Background: Back - Homebrew Games.png
18:01:19.6 8/25/2011: Validating: Emulator_30: Snap Path: E:\WinGames\Artwork\Snaps
18:01:19.6 8/25/2011: Validating: Emulator_30: Not Found Image: F:\Images\no_img.png
18:01:19.6 8/25/2011: Validating: Emulator_30: Control Panel Path: F:\Images\Controls\Windows
18:01:19.6 8/25/2011: Validating: Emulator_30: Title Snap Path: E:\WinGames\Artwork\Titles
18:01:19.6 8/25/2011: Validating: Emulator_30: Box Art Path: E:\WinGames\Artwork\Boxes
18:01:19.6 8/25/2011: Validating: Emulator_30: Cart Art Path: E:\WinGames\Artwork\Discs
18:01:19.6 8/25/2011: Validating: Emulator_30: Manual Path: E:\WinGames\Artwork\Manuals
18:01:19.6 8/25/2011: Validating: Emulator_31: Custom Background:
18:01:19.6 8/25/2011: Warning: Emulator_31: Custom Background Does not exist
18:01:19.6 8/25/2011: Validating: Emulator_31: Snap Path:
18:01:19.6 8/25/2011: Validating: Emulator_31: Not Found Image: F:\Images\no_img.png
Here's the CustomMenu.INI:
# This File allows you to cusomize the menu system in GameEx
# Registered Version Feature.
[General]
# The following sections allow you to choose which items to show and where.
# Each of the following sections is a menu (list in GameEx). [Root] is shown first when starting GameEx
# Sub Menus are in Sections [MENU_[0-100][ eg. [MENU_2]
# Create new sections if required.
# The First item in a section should be Title to specify the title text to be shown
# Menu items are shown in the order of the number suffixing item..
# Each item should start with item_[0-300]=
# Then item type then the text to show and then item parameter.
# e.g item_1=0,MAME,0
# Optional Parameter 2 = Image in themes logo folder without path and extenstion
# e.g Item=-1,Custom Menu,1,MAMEALL
# The Item Types are as follows
# -1= Submenu group. Goto other menu. Parameter = Menu number e.g Item=-1,Sub Menu 1,4 goes to [MENU_4].
# - Will be listed in GameEx as "Sub Menu 1"
# 0=MAME
# 1=Emulator. Parameter = Emulator Nunber
# 2=Application. Parameter = Application Number
# 3=Web Application. Parameter = Web Application Number
# 4=Theme Picker
# 5=Start Screensaver
# 6=Configuration Application
# 7=Statistics
# 8=Export To Mce
# 9=Most Played
# 10=Last Played
# 11=Random Game
# 12=Favorites
# 13=All Games list
# 14=News
# 15=Search
# 16=Exit
# 17=Log Off
# 18=Shut Down
# 19=Hibernate
# 20=Standby
# 21=Restart
# 22=Videos
# 23=Play DVD
# 24=Jukebox
# 25=DVDs on Disk
# 26=Radio
# 27=Media Library
# 28=eBooks
# 29=Karaoke
# 30=Pictures
# 31=Daphne
# 32=Emulator Group. Paramater = Group Number
# 33=Blank Line
[ROOT]
Title=Start
Item_1=-1,Arcade Games,1,GameEx
Item_2=-1,Console Games,2,Console
Item_3=-1,Handheld Games,4,Handheld
Item_4=32,Windows Games,1,Windows
Item_5=-1,Homebrew Games,17,PC Systems
Item_6=-1,Favorites & Most Played Games,18,MAMEFavor
Item_7=-1,Jukebox,5,jukebox
Item_8=-1,Videos,6,Video
Item_9=-1,News & Weather,7,news
Item_10=-1,Search,19,Search
Item_11=5,Start Attract Mode,0,screensaver
Item_12=-1,Exit GameEx,8,Exit
[MENU_2]
TITLE=Console Games
Item_1=-1,Nintendo,11,Nintendo
Item_2=-1,Sega,14,Sega
Item_3=-1,Atari,15,atari
Item_4=-1,Misc Consoles,16,Console
[MENU_1]
TITLE=Arcade Games
Item_1=-1,Arcade Machines,12,mame
Item_2=-1,Pinball Tables,13,Pinball
Item_3=36,GameEx Arcade,0,GameEx
[MENU_4]
TITLE=Handheld Games
Item_1=-1,Nintendo,3,Nintendo
Item_2=-1,Sega,9,Sega
Item_3=-1,Misc Handhelds,10
[MENU_10]
TITLE=Other Handhelds
Item_1=1,SNK NeoGeo Pocket,18,Neo Geo Pocket Color
Item_2=1,Atari Lynx,19,Atari Lynx
[MENU_12]
TITLE=Arcade Machines
Item_1=0,MAME Games,0,mame
Item_2=1,TAITO Type X,31,Type X
[MENU_13]
TITLE=Pinball Tables
Item_1=1,FUTURE Pinball,29,Future Pinball
Item_2=1,VISUAL PinMAME,17,Visual PinMAME
[MENU_11]
TITLE=Nintendo Games
Item_1=1,Nintendo Entertainment System,3,Nintendo NES
Item_2=1,Super Nintendo,2,Super Nintendo
Item_3=1,Nintendo 64,1,N64
Item_4=1,Gamecube,22,Nintendo Gamecube
[MENU_14]
TITLE=Sega Games
Item_1=1,Master System,8,Sega Master System
Item_2=1,Genesis,7,Sega Genesis
Item_3=1,Sega CD,6,Sega CD
Item_4=1,Saturn,21,Sega Saturn
Item_5=1,Dreamcast,28,Dreamcast
[MENU_15]
TITLE=Atari Games
Item_1=1,2600,11,Atari 2600
Item_2=1,5200,12,Atari 5200
Item_3=1,7800,13,Atari 7800
[MENU_16]
TITLE=Other Console Games
Item_1=1,Sony Playstation,20,Sony Playstation
Item_2=1,NEC TurboGrafx 16,10,TurboGrafx 16
Item_3=1,GCE Vectrex,16,Vectrex
Item_4=1,ColecoVision,14,Colecovision
Item_5=1,Mattel Intellivision,15,Intellivision
[MENU_17]
TITLE=Homebrew Games
Item_1=1,Beats Of Rage,24,OpenBOR
Item_2=1,Misc Homebrew,30,PC Systems
[MENU_3]
Item_1=1,GameBoy/GameBoy Color,5,Gameboy Color
Item_2=1,GameBoy Advance,4,Gameboy Advance
Item_3=1,DS,27,Nintendo DS
[MENU_9]
TITLE=Sega Games
Item_1=1,Game Gear,9,GameGear
[MENU_5]
TITLE=Jukebox
Item_1=24,My Jukebox,0,jukebox
Item_2=2,Rhapsody,1,rhapsody
Item_3=29,Karaoke,0,karaoke
Item_4=26,Internet Radio,0,Radio
Item_5=27,Media Library,0,media
[MENU_6]
TITLE=Videos
Item_1=2,Boxee,2,Boxee
Item_2=22,My Videos,0,Video
Item_3=34,YouTube,0,youtube
Item_4=
[MENU_7]
TITLE=News & Weather
Item_1=14,RSS News Feeds,0,news
Item_2=3,Weather,1,Weather
[MENU_8]
TITLE=Exit GameEx
Item_1=16,Exit GameEx,0,Exit
Item_2=18,Shutdown MegaMAME,0,ShutDown
Item_3=21,Restart MegaMAME,0,ShutDown
Item_4=7,Statistics,0,statistics
[MENU_18]
TITLE=Favorites & Most Played
Item_1=12,Favorites,0
Item_2=9,Most Played,0,most
Item_3=10,Last Played,0,last
Item_4=11,Random Game,0,random
[MENU_19]
TITLE=Search
Item_1=15,Search...,0,Search
Item_2=13,All Games,0,allemu
And here's my GameEx ini:
.:EDIT:. WTH? Now all of the sudden it works. It crashed again like 4 times on every emu list, and now it just doesn't. Man I'm so confused... I wonder if it had something to do with selection music, because MAME and my external apps were working fine. All my emu pages play music. Oh well, self-resolved for now.
Self-resolved posts are the best kind. ;)
Yeah, cept he doesn't know what it was, or how he fixed it. Now nobody else can solve this problem if they get it. Still, glad you got it working Adultery!
Only Adultery could make the impossible happen so I'm not worried about another user running into this problem. LOL. :P
Gee thanks a lot freq! Always lookin out for a bruvva! LMAO
