I noticed that after I change a theme, the 'Back' button doesn't work. Or, better said, I hear the sound when I press the button, but I get stuck in the theme selection screen, and can't go back. Even using the mouse and pressing 'Back' at the top of the screen doesn't work. If I restart GameEx everything is fine... until I change the theme again.
I tried with Black Glass, Enter the Dragon and Giga Drive. I don't know if this applies to default themes too. Possibly I'll check and report here.
I don't think you need my config file since the back button and everything else work fine, it's just a glitch that occurs in the theme selection screen. But ask me if you think it could be useful.
EDIT: This happens with default themes too... :(
Cheers,
Alpha.
This issue has gone away as soon as installed 12.xx. Stuff like this is the mystery of IT... Or do you have looked into it on purpose, Tom?
Anyway, this problem is resolved.
