OK, I need my DVD rips to be within a certain resolution to work on WiiMC (720x480). Is there a way to either change the default Normal profile to use the exact resolution I want, or better yet, can I use my own command line switches?
I'm using Handbrake GUI for the time being, but since I store my movies on the cab and serve them around the house, it would be cool if I could rip my movies to the specs I want without ever having to leave the GameEx interface.
Thanks! :)
Thanks! :)
Not yet but as you've discovered would be a feature request. Maybe a way to customize the command-line to our liking. ;)
That's almost exactly what I was fishing for. :)
A similar plugin that does this gives this option in the ini instead of the settings. Maybe the way to go to avoid confusion and will only be used by us more techy users. The option is to use an alternative command-line. So if it exists it uses that and if not then it uses the standard ones in the setup wizard. Even that program didn't give as much control as I would like which is why I had to do something on my own to get to work the way I wanted. So maybe Tom will think it's a good feature enough to add and I'm willing to give suggestions on how it should work.
