Hey guys, I finally got around to wiring up my control panel and hooking it up to my Gameex PC. I have tested all the joysticks and buttons in notepad and they all work just fine. They are currently set to the default MAME configuration on my ipac4. For some reason though, I am unable to select anything within the GameEx menu. I am able to navigate with my joystick, but none of the buttons work to select any of the menu items, even the player three button that is mapped to enter. I have played MAME games straight from the emulator with this configuration with no problems. I'm sure I am missing something simple but any help figuring out what it is would be greatly appreciated. Thanks.
Do I have to have the "enter" button mapped to a player 1 switch for it to register at the gameex menu since that seems to be the only joystick that I can use to navigate the menu. Or should the player 3 switch that is mapped to the "enter" key be doing the trick. Thanks.
Thanks for your response. That did the trick. I had tried accessing the keyboard input edit from the old advanced configuration menu but I always got an error. Finally checked through the setup wizard and was able to change the select key to a player 1 button that I wanted. Thanks again for your help.
