I've read on here that previous users have been able to get MUGEN to work with their GameEx setup. I downloaded a MUGEN set that works when I click on the exe but I have been unable to get it to work with Gameex. I added it as an emulator and it shows up on my emulator list but the screen just goes black when I choose to play it and then goes back to the previous screen. The version of MUGEN I am using doesn't seem to be the winmugen version but rather just mugen. I tried to copy the Gameex config that previous users said they used but all of the posts about mugen on these forums are about 3 years old so some of the config options have changed.
I basically used these options:
DumbyValue=
STARTPAGENAME=Mugen
TITLETEXT=Mugen
StartPageLogo=emus
ROMFilter=*.exe
RomsInFolders=False
RomPath=G:\Emulators\MUGEN
SnapPath=G:\Emulators\MUGEN\snaps
TitlePath=G:\Emulators\MUGEN\snaps
BoxPath=
CartPath=
WorkingPath=G:\Emulators\MUGEN\
MapKeys=False
WaitBeforeKeys=
SendKeys=
ReplaceDash=
ReplaceUnder=
Capitals=
RemoveBrackets=
ShowDesktop=True
Debug=
MAPFile=
AlsoLaunch=
Command=winmugen.exe
OLDatZip=
LaunchBefore=
LaunchAfter=
configFile=
ExcludedFiles=
CustomBackground=
PlayMusic=
PCGame=True
DATABASE=
GamesIn7Zips=
PlayInScreenSaver=False
but instead of winmugen I have mugen.exe as my executable. I also have the snaps setup the same in config even though no snap folder exists in my MUGEN folder. If anyone is able to help me with this I would greatly appreciate it. Thanks.
Since this is not a standard emulator, it's hard to say exactly what is needed to get it working. Many things can come into play. I'll be in the chat room for a bit for real-time support if interested.
I have my MUGEN in my PC games. Set up the same with the shortcut link (*.lnk) as the rom filter. Marvel Vs. Capcom 3 MUGEN = badassness. :lol:
Issue has been resolved! The problem was with the path name. MRE's path included a "%" character and GameEx was stripping it out from the command-line. Therefore, causing it to error out with an invalid path name in the command window output.
How do you guys deal with the ESC key in mugen? I cannot find a way to change it in mugen and do not want to change it in game EX.
Let me know.
Regards
Let me know.
Regards
What exactly are you trying to accomplish? Also should start a new thread as this is a new issue and was already resolved. I will move it as soon as you respond.
