Hi,
I just compiled MAME .143 and updated my roms to .143 using ClrMamePro - now some roms doesn't work ie. frogger and digdug (they work fine when running mame from the commandline) - screen just blacks out for a little while then returns to GameEx.
The games that doesn't work from GameEx seems to be started with:
Running: cmd.exe /c C: C:\Emulators\MAME\mame.exe frogger -rompath C:\Emulators\MAME\roms  -bezel -artwork_directory artworkgameex
Trying this from the command-line made MAME complain about not understanding '-artwork_directory'
while games that work inside GameEx is started with:
Running: cmd.exe /c C: C:\Emulators\MAME\mame.exe elevator -rompath C:\Emulators\MAME\roms
Any idea why the extra switches are set on some games - or how to disable it?
EDIT:
Found a switch to turn off bezels for vertical games - that did the trick.
After looking at the commandline-options for my mame.exe it seems that -artwork_directory should be -artpath and -bezel should (probably) be -use_bezels (it doesn't complain about -bezel but it's not listed when I do a mame -showusage).
Anywhere I can tell GameEx to put that in instead of -bezel -artwork_directory ? (ie. how/where/when is the runitgame.bat created).
What version of GameEx are you using?
11.91 - just updated today (ie. just installed on-top of the old installation), as I figured that it might need an update, too ;)
GameEx should be checking your MAME version and making the artwork path change according to what you have for a MAME dist. Please try and run a rom now and post your GameEx log in its entirety.
23:51:00.0  07/29/11:  Opening Configuration File
23:51:00.1 07/29/11: GameEx: Version 11.91: Starting Log
23:51:00.1 07/29/11: Operating System Platform: Win32NT
23:51:00.1 07/29/11: Operating System Name: Windows Vista
23:51:00.1 07/29/11: Operating System Version: 6.1.7601
23:51:00.1 07/29/11: Aero NOT running
23:51:00.1 07/29/11: Initializing Vista/Windows 7 volume control
23:51:00.1 07/29/11: Checking for versions of .net Framework installed
23:51:00.1 07/29/11: .net Framework 2.0 Installed
23:51:00.1 07/29/11: .net Framework 3.0 Installed
23:51:00.1 07/29/11: .net Framework 3.5 Installed
23:51:00.1 07/29/11: Genuine Intel(R) CPU T2250 @ 1.73GHz, 1022MB
23:51:00.1 07/29/11: 1.73Ghz - 2 Cores or CPU's
23:51:00.1 07/29/11: Running Randomize()
23:51:00.1 07/29/11: Loading PlugIns
23:51:00.2 07/29/11: Checking for applications to Launch On Startup
23:51:00.2 07/29/11: Running Misc startup tasks
23:51:00.2 07/29/11: Setting Menu types
23:51:00.2 07/29/11: Getting Configuration Values
23:51:00.2 07/29/11: Using Theme: Default - MCE Glossy
23:51:00.2 07/29/11: Checking for alternate Image Directory for Theme: Default - MCE Glossy
23:51:00.2 07/29/11: Launching HideOS.exe
23:51:00.2 07/29/11: Initialising Video/MNG DLL's
23:51:00.2 07/29/11: GameEx will check for media insertion (may affect performance)
23:51:00.2 07/29/11: Hiding Taskbar
23:51:00.3 07/29/11: Is Media Center running?
23:51:00.3 07/29/11: Checking/Creating LCD Registry values
23:51:00.4 07/29/11: Check Media Center Exit/Start Mode
23:51:00.4 07/29/11: Media Center Mode 2
23:51:00.4 07/29/11: Video previews on. Warning: Only recommended on modern systems
23:51:00.5 07/29/11: Snap Delay set to: 2
23:51:00.5 07/29/11: Get other settings
23:51:00.5 07/29/11: Desktop set to Hide ICONS and set Background to Black
23:51:00.5 07/29/11: Set: Find emulator artwork on best match basis
23:51:00.5 07/29/11: Using DirectInput for keyboard input
23:51:00.5 07/29/11: Start work for Form
23:51:00.5 07/29/11: Getting Original Screen Size
23:51:00.5 07/29/11: Opening Database Connection
23:51:01.3 07/29/11: Initializing Component
23:51:01.4 07/29/11: Retrieving resolution setting
23:51:01.4 07/29/11: MAME Path is: C:\Emulators\MAME
23:51:01.4 07/29/11: daphne Path is: C:\Emulators\Daphne
23:51:01.4 07/29/11: daphne EXE file is: Daphne.exe
23:51:01.5 07/29/11: Use daphne on. Daphne.exe will launch games
23:51:01.5 07/29/11: MAME EXE file is: mame.exe
23:51:01.5 07/29/11: ROM Path is: C:\Emulators\MAME\roms
23:51:01.5 07/29/11: Catver.ini is located at: C:\GameEx\DATA\catver.ini
23:51:01.5 07/29/11: controls.ini is located at: C:\GameEx\data\controls.ini
23:51:01.5 07/29/11: History.dat is located at: C:\GameEx\DATA\history.dat
23:51:01.5 07/29/11: nplayers.ini is located at: C:\GameEx\DATA\nplayers.ini
23:51:01.5 07/29/11: command.dat is located at: C:\GameEx\DATA\command.dat
23:51:01.5 07/29/11: MAMEinfo.dat is located at: C:\GameEx\DATA\mameinfo.dat
23:51:01.5 07/29/11: Loading Controls.ini map file
23:51:01.5 07/29/11: Snap Path is: C:\Emulators\MAME\snap
23:51:01.6 07/29/11: AVI Snap Path is: C:\Emulators\MAME\video
23:51:01.6 07/29/11: Flyer Path is: C:\Emulators\MAME\flyers
23:51:01.6 07/29/11: Cabinet Path is: C:\Emulators\MAME\cabinets
23:51:01.6 07/29/11: Cabinet 3D Path is: C:\Emulators\MAME\cabinets3d
23:51:01.6 07/29/11: Title Path is: C:\Emulators\MAME\titles
23:51:01.6 07/29/11: PCB Path is: C:\Emulators\MAME\pcb
23:51:01.6 07/29/11: Artwork Preview Path is: C:\Emulators\MAME\artwork
23:51:01.6 07/29/11: Panel Path is: C:\Emulators\MAME\cpanel
23:51:01.7 07/29/11: Manual Path is: C:\Emulators\MAME\manuals
23:51:01.7 07/29/11: Icon Path is: C:\Emulators\MAME\icons
23:51:01.7 07/29/11: Marquee Path is: C:\Emulators\MAME\marquees
23:51:01.8 07/29/11: Loading Custom Emulators
23:51:01.8 07/29/11: Loading Emulator 1: Atari 5200
23:51:01.8 07/29/11: Loading Emulator 2: Nintendo SNES
23:51:01.8 07/29/11: Loading Emulator 3: Nintendo N64
23:51:01.8 07/29/11: Loading Emulator 4: [Arcade] Arcade (MAME)
23:51:01.9 07/29/11: Using 3D Alpha Blended Animations.
23:51:01.9 07/29/11: Using General Font: Trebuchet MS
23:51:01.9 07/29/11: Using Title Font: Trebuchet MS
23:51:01.9 07/29/11: Initialising Direct3D
23:51:02.1 07/29/11: Setting Resolution to 1280x800 32 bit color
23:51:02.1 07/29/11: Creating Surfaces
23:51:02.7 07/29/11: Creating Primary Surface - Full Screen Mode
23:51:02.7 07/29/11: Creating Back Buffer
23:51:03.0 07/29/11: Loading graphic Surfaces
23:51:03.0 07/29/11: Display is running at: 1280x800 32bit color, 60hz
23:51:03.1 07/29/11: Creating Surfaces Misc and Dialogs
23:51:03.4 07/29/11: Creating Surfaces Volume
23:51:03.4 07/29/11: Creating Surfaces Arrows
23:51:03.5 07/29/11: Creating Surfaces GameEXlogo Text
23:51:03.5 07/29/11: Creating Surfaces Toolbar
23:51:03.8 07/29/11: Creating Surfaces Backgrounds
23:51:03.8 07/29/11: Creating Surfaces Toolbar Controls
23:51:03.8 07/29/11: Creating Surfaces GameEx Logo
23:51:03.9 07/29/11: Creating Surface Unselected
23:51:03.9 07/29/11: Creating Surfaces Home & Exit
23:51:04.0 07/29/11: Creating Surfaces Snaps
23:51:04.0 07/29/11: Creating Surfaces Menu and List Bars
23:51:04.5 07/29/11: Creating Fonts
23:51:04.5 07/29/11: Creating Game Font
23:51:05.1 07/29/11: Creating Game Font Faded
23:51:05.2 07/29/11: Creating Title Font
23:51:05.2 07/29/11: Restoring Title Font From Cache
23:51:05.7 07/29/11: Creating Menu Font
23:51:05.8 07/29/11: Creating Font Black
23:51:05.9 07/29/11: Creating Font Black Small
23:51:05.9 07/29/11: Fonts Created Succesfully
23:51:05.9 07/29/11: 4MB Video Memory Used
23:51:05.9 07/29/11: Initialising Bass Audio Library
23:51:05.9 07/29/11: Creating instance of global keyboard hook
23:51:30.9 07/29/11: Playing Startup Video on thread
23:51:30.9 07/29/11: Attempting to load game list
23:51:31.4 07/29/11: Applying Language/Text
23:51:31.4 07/29/11: Text/Language: English
23:51:31.5 07/29/11: MAME CMD options: -triplebuffer -filter -multithreading
23:51:31.5 07/29/11: Loading last used Game List
23:51:31.5 07/29/11: Loading Start Page
23:51:31.6 07/29/11: Loading music
23:51:31.7 07/29/11: Initialising Windows Media Player Component
23:51:34.0 07/29/11: Creating DirectSound Device
23:51:34.0 07/29/11: Trying: Primary Sound Driver
23:51:34.0 07/29/11: Loading Sound Files
23:51:34.3 07/29/11: DirectSound Device Created Successfully
23:51:34.3 07/29/11: Initialising DirectInput for Gamepad support
23:51:34.4 07/29/11: Unable to create a joystick device
23:51:34.4 07/29/11: Initialising DirectInput for Keyboard support
23:51:34.4 07/29/11: Initializing MCE Remote
23:51:34.5 07/29/11: Playing intro sound file
23:51:34.7 07/29/11: Initialization OK! Starting GameEx!
23:51:34.7 07/29/11: Testing Main Loop Once: Processing Frame
23:51:35.6 07/29/11: Testing Main Loop Once: Main Loop ran successfully
23:51:47.6 07/29/11: Restoring Cached ICONS from File
23:52:00.8 07/29/11: Validating: Emulator_1: Custom Background:
23:52:00.8 07/29/11: Warning: Emulator_1: Custom Background Does not exist
23:52:00.8 07/29/11: Validating: Emulator_1: Snap Path: C:\GameEx\DEMO\5200\video
23:52:00.9 07/29/11: Validating: Emulator_1: Database: [Console] Atari 5200
23:52:00.9 07/29/11: Validating: Emulator_1: Title Snap Path: C:\GameEx\DEMO\5200\titles
23:52:01.0 07/29/11: Validating: Emulator_1: Box Art Path: C:\GameEx\DEMO\5200\boxart
23:52:01.0 07/29/11: Validating: Emulator_1: Cart Art Path: C:\GameEx\DEMO\5200\cart
23:52:01.0 07/29/11: Validating: Emulator_1: Manual Path: C:\GameEx\DEMO\5200\manual
23:52:01.1 07/29/11: Validating: Emulator_2: Custom Background:
23:52:01.1 07/29/11: Warning: Emulator_2: Custom Background Does not exist
23:52:01.1 07/29/11: Validating: Emulator_2: Snap Path: C:\GameEx\DEMO\SNES\video
23:52:01.1 07/29/11: Validating: Emulator_2: Database: [Console] Nintendo SNES
23:52:01.2 07/29/11: Validating: Emulator_2: Title Snap Path: C:\GameEx\DEMO\SNES\titles
23:52:01.2 07/29/11: Validating: Emulator_2: Box Art Path: C:\GameEx\DEMO\SNES\boxart
23:52:01.2 07/29/11: Validating: Emulator_2: Cart Art Path: C:\GameEx\DEMO\SNES\cart
23:52:01.2 07/29/11: Validating: Emulator_2: Manual Path: C:\GameEx\DEMO\SNES\manual
23:52:01.2 07/29/11: Validating: Emulator_3: Custom Background:
23:52:01.2 07/29/11: Warning: Emulator_3: Custom Background Does not exist
23:52:01.2 07/29/11: Validating: Emulator_3: Snap Path: C:\GameEx\DEMO\N64\video
23:52:01.2 07/29/11: Validating: Emulator_3: Database: [Console] Nintendo N64
23:52:01.2 07/29/11: Validating: Emulator_3: Title Snap Path: C:\GameEx\DEMO\N64\titles
23:52:01.2 07/29/11: Validating: Emulator_3: Box Art Path: C:\GameEx\DEMO\N64\boxart
23:52:01.2 07/29/11: Validating: Emulator_3: Cart Art Path: C:\GameEx\DEMO\N64\cart
23:52:01.2 07/29/11: Validating: Emulator_3: Manual Path: C:\GameEx\DEMO\N64\manual
23:52:01.2 07/29/11: Restoring Emulator from Cache
23:52:01.4 07/29/11: Restoring Emulator Database From Cache
23:52:01.4 07/29/11: Restoring Emulator from Cache
23:52:01.5 07/29/11: Restoring Emulator Database From Cache
23:52:01.6 07/29/11: Restoring Emulator from Cache
23:52:01.6 07/29/11: Restoring Emulator Database From Cache
23:52:14.3 07/29/11: Running: cmd.exe /c C: C:\Emulators\MAME\mame.exe frogger -rompath C:\Emulators\MAME\roms -triplebuffer -filter -multithreading -bezel -artwork_directory artworkgameex
23:52:14.7 07/29/11: Shutting down display
23:52:18.3 07/29/11: Exiting game
23:52:18.7 07/29/11: Writing MAME stats
23:52:18.8 07/29/11: Restoring Bezel
23:52:18.8 07/29/11: Plugin: Game Exit
23:52:18.8 07/29/11: Plugin: Process Commands
23:52:18.8 07/29/11: Restoring Window
23:52:18.8 07/29/11: Reinitializing Graphics System
23:52:20.5 07/29/11: Returning to GameEx
23:52:24.4 07/29/11: Exiting GameEx!
23:52:24.4 07/29/11: Saving Settings
23:52:26.3 07/29/11: Disposing Plugins
23:52:26.4 07/29/11: Closing database connection
23:52:26.5 07/29/11: Checking for applications to Launch On Exit
23:52:26.5 07/29/11: Media Center was not open when starting GameEx, so not launching
This is from trying to start frogger with GameEx configured to use bezels on vertical games.
c:\Emulators\MAME>mame -h
M.A.M.E. v0.143 (Jul 29 2011) - Multiple Arcade Machine Emulator
Copyright Nicola Salmoria and the MAME team
Man that looks right to me. You're trying to use GameEx's bezel right? Or are you trying to use the real game bezel?
GameEx's bezel I believe (-artwork_directory artworkgameex)
Just tried the Attract/Screensaver/Show MAME Bezel=Yes - it applies the same options (-bezel -artwork_directory artworkgameex) and hence fails back to GameEx-menu.
Thanks for taking the time to try and troubleshoot my problem, though ;)
Edit:
C:\Emulators\MAME>C:\Emulators\MAME\mame.exe frogger -rompath C:\Emulators\MAME\roms -triplebuffer -filter -multithreading -volume -32 -bezel -artwork_directory artworkgameex
Error: unknown option: -artwork_directory
Just for good sake ;)
I need a fresh pair of eyes here. Or I need to take a look at my own setup and see how it behaves. My GameEx bezel shows up in attract mode like it should though and I use the same MAME version (and its a compiled version as well). I'm pretty sure mine passes -artwork because MAME team recently made that change.
I feel kinda dumb.... ;)
I updated GameEx - and the first thing I should (obviously) have done then was ofcourse to update the game-list it would seem...
That's the point where GameEx detects the mame version and which options to use - now the GameEx bezel is back where it should be.
Thanks for the troubleshooting and sorry for wasting your time :)
Hey man, knowing you're up and running is never a waste of my time! Glad it's behaving as it should! biggrin.gif
No question goes unanswered around here for long, and believe me I ask more than my share of dumb questions! Haha!
Edited by nullPointer
