I was creating snaps for Future Pinball when my PC went all blue screen of death. Since then only MAME works within GameEx. Everything else works fine outside of GameEx.
I saw strange symbols running runitgame.bat (see screenshot), and I need help identifying the culprit - perhaps I need to reinstall the OS, or do a clean install of GameEx. If you guys know a better way, well that's why I'm here.
I scanned the hard disk for errors and it's fine.
runitgame.bat:
K:
CD "K:\Emulation\Future Pinball"
start " " "K:\Emulation\JoyToKey\JoytoFpinball.bat"
"Future Pinball.exe" /open "K:\Emulation\Future Pinball\Tables\Pinball Fantasies - Partyland (Digital Illusions) (1992) (light86, SlipperyPenguin) (1.51).fpt" /play /exit
PAUSE
start " " "K:\Emulation\JoyToKey\end.bat"
Log file:
04:25:54.6 14/07/2011: Opening Configuration File
04:25:54.7 14/07/2011: GameEx: Version 11.87: Starting Log
04:25:54.7 14/07/2011: Operating System Platform: Win32NT
04:25:54.7 14/07/2011: Operating System Name: Windows XP
04:25:54.7 14/07/2011: Operating System Version: 5.1.2600
04:25:54.7 14/07/2011: Checking for versions of .net Framework installed
04:25:54.7 14/07/2011: .net Framework 1.1 Installed
04:25:54.7 14/07/2011: .net Framework 2.0 Installed
04:25:54.7 14/07/2011: .net Framework 3.0 Installed
04:25:54.7 14/07/2011: .net Framework 3.5 Installed
04:25:54.7 14/07/2011: AMD Athlonâ?¢ 64 X2 Dual Core Processor 3800+, 2047MB
04:25:54.7 14/07/2011: 2Ghz - 2 Cores or CPU's
04:25:54.7 14/07/2011: Running Randomize()
04:25:54.7 14/07/2011: Loading PlugIns
04:25:54.7 14/07/2011: Checking for applications to Launch On Startup
04:25:54.7 14/07/2011: Running Misc startup tasks
04:25:54.7 14/07/2011: Setting Menu types
04:25:54.7 14/07/2011: Getting Configuration Values
04:25:54.7 14/07/2011: Using Theme: BlueBox
04:25:54.7 14/07/2011: Checking for alternate Image Directory for Theme: BlueBox
04:25:54.7 14/07/2011: Launching HideOS.exe
04:25:54.8 14/07/2011: Initialising Video/MNG DLL's
04:25:54.8 14/07/2011: GameEx will check for media insertion (may affect performance)
04:25:54.8 14/07/2011: Hiding Taskbar
04:25:54.8 14/07/2011: Is Media Center running?
04:25:54.8 14/07/2011: Checking/Creating LCD Registry values
04:25:54.8 14/07/2011: Check Media Center Exit/Start Mode
04:25:54.8 14/07/2011: Media Center Mode 2
04:25:54.8 14/07/2011: Video previews on. Warning: Only recommended on modern systems
04:25:54.9 14/07/2011: Custom Game Device Input enabled: Getting custom codes
04:25:54.9 14/07/2011: Snap Delay set to: 6
04:25:54.9 14/07/2011: Get other settings
04:25:54.9 14/07/2011: Desktop set to Hide ICONS and set Background to Black
04:25:54.9 14/07/2011: Set: Find emulator artwork on best match basis
04:25:54.9 14/07/2011: Using DirectInput for keyboard input
04:25:54.9 14/07/2011: Start work for Form
04:25:54.9 14/07/2011: Getting Original Screen Size
04:25:54.9 14/07/2011: Opening Database Connection
04:25:54.9 14/07/2011: Initializing Component
04:25:55.0 14/07/2011: Retrieving resolution setting
04:25:55.0 14/07/2011: MAME Path is: K:\Emulation\MAME
04:25:55.0 14/07/2011: MAME EXE file is: mame.exe
04:25:55.0 14/07/2011: ROM Path is: K:\Emulation\MAME\roms
04:25:55.0 14/07/2011: Catver.ini is located at: C:\GameEx\DATA\catver.ini
04:25:55.0 14/07/2011: controls.ini is located at: C:\GameEx\data\controls.ini
04:25:55.0 14/07/2011: History.dat is located at: C:\GameEx\DATA\history.dat
04:25:55.0 14/07/2011: nplayers.ini is located at: C:\GameEx\DATA\nplayers.ini
04:25:55.0 14/07/2011: command.dat is located at: C:\GameEx\DATA\command.dat
04:25:55.0 14/07/2011: MAMEinfo.dat is located at: C:\GameEx\DATA\mameinfo.dat
04:25:55.0 14/07/2011: Loading Controls.ini map file
04:25:55.0 14/07/2011: Snap Path is: K:\Emulation\MAME\snap
04:25:55.0 14/07/2011: AVI Snap Path is: K:\Emulation\MAME\avi
04:25:55.0 14/07/2011: Flyer Path is: K:\Emulation\MAME\flyers
04:25:55.0 14/07/2011: Cabinet Path is: K:\Emulation\MAME\cabinets
04:25:55.0 14/07/2011: Cabinet 3D Path: Not Found
04:25:55.0 14/07/2011: Title Path is: K:\Emulation\MAME\titles
04:25:55.0 14/07/2011: PCB Path is: K:\Emulation\MAME\pcb
04:25:55.1 14/07/2011: Artwork Preview Path: Not Found
04:25:55.1 14/07/2011: Panel Path is: K:\Emulation\MAME\cpanel
04:25:55.1 14/07/2011: Manual Path is: K:\Emulation\MAME\manuals
04:25:55.1 14/07/2011: Icon Path is: K:\Emulation\MAME\icons
04:25:55.1 14/07/2011: Marquee Path is: K:\Emulation\MAME\marquees
04:25:55.1 14/07/2011: Loading Custom Emulators
04:25:55.1 14/07/2011: Loading Emulator 1: [Pinball] Future Pinball
04:25:55.1 14/07/2011: Loading Emulator 2: [Pinball] Visual Pinball
04:25:55.1 14/07/2011: Loading Emulator 3: Amstrad CPC
04:25:55.1 14/07/2011: Loading Emulator 4: Atari 2600
04:25:55.1 14/07/2011: Loading Emulator 5: Atari 5200
04:25:55.1 14/07/2011: Loading Emulator 6: Atari 800 XL
04:25:55.2 14/07/2011: Loading Emulator 7: Commodore 64
04:25:55.2 14/07/2011: Loading Emulator 8: Commodore Amiga
04:25:55.2 14/07/2011: Loading Emulator 9: Commodore Amiga (Disk)
04:25:55.2 14/07/2011: Loading Emulator 10: Microsoft MSX
04:25:55.2 14/07/2011: Loading Emulator 11: Microsoft MSX 2
04:25:55.2 14/07/2011: Loading Emulator 12: NEC PC Engine
04:25:55.2 14/07/2011: Loading Emulator 13: NEC PC Engine CD
04:25:55.2 14/07/2011: Loading Emulator 14: NEC Supergrafx
04:25:55.2 14/07/2011: Loading Emulator 15: Nintendo Game Boy
04:25:55.2 14/07/2011: Loading Emulator 16: Nintendo Game Boy Advance
04:25:55.2 14/07/2011: Loading Emulator 17: Nintendo Game Boy Color
04:25:55.2 14/07/2011: Loading Emulator 18: Nintendo NES
04:25:55.2 14/07/2011: Loading Emulator 19: Nintendo SNES
04:25:55.2 14/07/2011: Loading Emulator 20: PC (Win/DOS)
04:25:55.3 14/07/2011: Loading Emulator 21: Sega 32X
04:25:55.3 14/07/2011: Loading Emulator 22: Sega Game Gear
04:25:55.3 14/07/2011: Loading Emulator 23: Sega Master System
04:25:55.3 14/07/2011: Loading Emulator 24: Sega Mega CD
04:25:55.3 14/07/2011: Loading Emulator 25: Sega Megadrive
04:25:55.3 14/07/2011: Loading Emulator 26: Sega Saturn (Europe)
04:25:55.3 14/07/2011: Loading Emulator 27: Sega Saturn (Japan)
04:25:55.3 14/07/2011: Loading Emulator 28: Sega Saturn (USA)
04:25:55.3 14/07/2011: Loading Emulator 29: Sega SG-1000
04:25:55.3 14/07/2011: Loading Emulator 30: ZX Spectrum 128k
04:25:55.3 14/07/2011: Loading Emulator 31: ZX Spectrum 48k
04:25:55.3 14/07/2011: Using 3D Alpha Blended Animations.
04:25:55.3 14/07/2011: Using General Font: Techno28
04:25:55.4 14/07/2011: Using Title Font: Techno28
04:25:55.4 14/07/2011: Initialising Direct3D
04:25:55.5 14/07/2011: Applying GameEx is Loading Image
04:25:55.6 14/07/2011: Setting Resolution to 1024x768 32 bit color
04:25:55.6 14/07/2011: Creating Surfaces
04:25:55.9 14/07/2011: Creating Primary Surface - Full Screen Mode
04:25:55.9 14/07/2011: Creating Back Buffer
04:25:56.0 14/07/2011: Version 2 Theme being used. Loading.
04:25:56.0 14/07/2011: Loading Button Data
04:25:56.0 14/07/2011: Loading Font Data
04:25:56.0 14/07/2011: Loading Layout Data
04:25:56.0 14/07/2011: Loading Taskbar Data
04:25:56.0 14/07/2011: Loading graphic Surfaces
04:25:56.1 14/07/2011: Display is running at: 1024x768 32bit color, 60hz
04:25:56.2 14/07/2011: Creating Surfaces Misc and Dialogs
04:25:56.2 14/07/2011: Creating Surfaces Volume
04:25:56.3 14/07/2011: Creating Surfaces Arrows
04:25:56.3 14/07/2011: Creating Surfaces GameEXlogo Text
04:25:56.3 14/07/2011: Creating Surfaces Toolbar
04:25:56.3 14/07/2011: Creating Surfaces Backgrounds
04:25:56.3 14/07/2011: Creating Surfaces Toolbar Controls
04:25:56.3 14/07/2011: Creating Surfaces GameEx Logo
04:25:56.4 14/07/2011: Creating Surface Unselected
04:25:56.4 14/07/2011: Creating Surfaces Snaps
04:25:56.4 14/07/2011: Creating Surfaces Menu and List Bars
04:25:56.5 14/07/2011: Creating Fonts
04:25:56.5 14/07/2011: Creating Game Font
04:25:56.6 14/07/2011: Creating Game Font Faded
04:25:56.7 14/07/2011: Creating Title Font
04:25:56.7 14/07/2011: Restoring Title Font From Cache
04:25:56.9 14/07/2011: Creating Font Black
04:25:56.9 14/07/2011: Creating Font Black Small
04:25:57.0 14/07/2011: Fonts Created Succesfully
04:25:57.0 14/07/2011: 3MB Video Memory Used
04:25:57.0 14/07/2011: Initialising Bass Audio Library
04:25:57.0 14/07/2011: Creating instance of global keyboard hook
04:25:57.6 14/07/2011: Attempting to load game list
04:25:57.8 14/07/2011: GameExtender Not found snap: C:\GameEx\THEMES\BlueBox\MEDIA\GameExIsLoading.png
04:25:57.9 14/07/2011: Applying Language/Text
04:25:57.9 14/07/2011: Text/Language: English
04:25:57.9 14/07/2011: MAME CMD options: -nowindow -joy -skip_gameinfo
04:25:57.9 14/07/2011: Loading last used Game List
04:25:58.0 14/07/2011: Loading Start Page
04:25:58.0 14/07/2011: Creating DirectSound Device
04:25:58.0 14/07/2011: Trying: Primary Sound Driver
04:25:58.0 14/07/2011: Loading Sound Files
04:25:58.0 14/07/2011: DirectSound Device Created Successfully
04:25:58.0 14/07/2011: Initialising DirectInput for Gamepad support
04:25:58.1 14/07/2011: Using Device Dual PSX-USB Adaptor
04:25:58.1 14/07/2011: Initialising DirectInput for Keyboard support
04:25:58.2 14/07/2011: Initializing MCE Remote
04:25:58.2 14/07/2011: Playing intro sound file
04:25:58.2 14/07/2011: Initialization OK! Starting GameEx!
04:25:58.2 14/07/2011: Testing Main Loop Once: Processing Frame
04:25:58.7 14/07/2011: Testing Main Loop Once: Main Loop ran successfully
04:26:08.1 14/07/2011: Validating: Emulator_1: Custom Background:
04:26:08.1 14/07/2011: Warning: Emulator_1: Custom Background Does not exist
04:26:08.1 14/07/2011: Validating: Emulator_1: Snap Path: K:\Emulation\Future Pinball\snap
04:26:08.1 14/07/2011: Validating: Emulator_1: Database: [Pinball] Future Pinball
04:26:08.1 14/07/2011: Validating: Emulator_2: Custom Background:
04:26:08.1 14/07/2011: Warning: Emulator_2: Custom Background Does not exist
04:26:08.1 14/07/2011: Validating: Emulator_2: Snap Path: K:\Emulation\Visual Pinball\snap
04:26:08.1 14/07/2011: Validating: Emulator_2: Not Found Image: C:\GameEx\THEMES\BlueBox\MEDIA\LOGOS\VPinball.png
04:26:08.1 14/07/2011: Validating: Emulator_2: Database: [Pinball] Visual Pinball
04:26:08.1 14/07/2011: Validating: Emulator_3: Custom Background: Back - Amstrad CPC.png
04:26:08.1 14/07/2011: Validating: Emulator_3: Snap Path: K:\Emulation\Amstrad CPC\snap
04:26:08.1 14/07/2011: Validating: Emulator_3: Not Found Image: C:\GameEx\THEMES\BlueBox\MEDIA\LOGOS\CPC 464.png
04:26:08.1 14/07/2011: Validating: Emulator_3: Database: [PC] Amstrad CPC
04:26:08.1 14/07/2011: Validating: Emulator_3: Title Snap Path: K:\Emulation\Amstrad CPC\title
04:26:08.1 14/07/2011: Validating: Emulator_4: Custom Background: Back - Atari 2600.png
04:26:08.1 14/07/2011: Validating: Emulator_4: Snap Path: K:\Emulation\Atari2600\snap
04:26:08.1 14/07/2011: Validating: Emulator_4: Not Found Image: C:\GameEx\THEMES\BlueBox\MEDIA\LOGOS\Atari 2600.png
04:26:08.1 14/07/2011: Validating: Emulator_4: Custom Art Path 1: K:\Emulation\GameEx\null
04:26:08.1 14/07/2011: Warning: Emulator_4: Custom Art Path 1 Does not exist
04:26:08.1 14/07/2011: Validating: Emulator_4: Custom Art Path 2: K:\Emulation\GameEx\null
04:26:08.1 14/07/2011: Warning: Emulator_4: Custom Art Path 2 Does not exist
04:26:08.1 14/07/2011: Validating: Emulator_4: Custom Art Path 3: K:\Emulation\GameEx\null
04:26:08.1 14/07/2011: Warning: Emulator_4: Custom Art Path 3 Does not exist
04:26:08.1 14/07/2011: Validating: Emulator_4: Control Panel Path: K:\Emulation\GameEx\null
04:26:08.1 14/07/2011: Warning: Emulator_4: Control Panel Path Does not exist
04:26:08.1 14/07/2011: Validating: Emulator_4: Instructions Path: K:\Emulation\GameEx\null
04:26:08.2 14/07/2011: Warning: Emulator_4: Instructions Path Does not exist
04:26:08.2 14/07/2011: Validating: Emulator_4: Database: [Console] Atari 2600
04:26:08.2 14/07/2011: Validating: Emulator_4: Title Snap Path: K:\Emulation\GameEx\null
04:26:08.2 14/07/2011: Warning: Emulator_4: Title Snap Path Does not exist
04:26:08.2 14/07/2011: Validating: Emulator_4: Box Art Path: K:\Emulation\GameEx\null
04:26:08.2 14/07/2011: Warning: Emulator_4: Box Art Path Does not exist
04:26:08.2 14/07/2011: Validating: Emulator_4: Cart Art Path: K:\Emulation\GameEx\null
04:26:08.2 14/07/2011: Warning: Emulator_4: Cart Art Path Does not exist
04:26:08.2 14/07/2011: Validating: Emulator_4: Manual Path: K:\Emulation\GameEx\null
04:26:08.2 14/07/2011: Warning: Emulator_4: Manual Path Does not exist
04:26:08.2 14/07/2011: Validating: Emulator_5: Custom Background: Back - Atari 5200.png
04:26:08.2 14/07/2011: Validating: Emulator_5: Snap Path: K:\Emulation\Atari5200\snaps
04:26:08.2 14/07/2011: Validating: Emulator_5: Not Found Image: C:\GameEx\THEMES\BlueBox\MEDIA\LOGOS\Atari 5200.png
04:26:08.2 14/07/2011: Validating: Emulator_5: Custom Art Path 1: K:\Emulation\GameEx\null
04:26:08.2 14/07/2011: Warning: Emulator_5: Custom Art Path 1 Does not exist
04:26:08.2 14/07/2011: Validating: Emulator_5: Custom Art Path 2: K:\Emulation\GameEx\null
04:26:08.2 14/07/2011: Warning: Emulator_5: Custom Art Path 2 Does not exist
04:26:08.2 14/07/2011: Validating: Emulator_5: Custom Art Path 3: K:\Emulation\GameEx\null
04:26:08.2 14/07/2011: Warning: Emulator_5: Custom Art Path 3 Does not exist
04:26:08.2 14/07/2011: Validating: Emulator_5: Control Panel Path: K:\Emulation\GameEx\null
04:26:08.2 14/07/2011: Warning: Emulator_5: Control Panel Path Does not exist
04:26:08.2 14/07/2011: Validating: Emulator_5: Instructions Path: K:\Emulation\GameEx\null
04:26:08.2 14/07/2011: Warning: Emulator_5: Instructions Path Does not exist
04:26:08.2 14/07/2011: Validating: Emulator_5: Database: [Console] Atari 5200
04:26:08.2 14/07/2011: Validating: Emulator_5: Title Snap Path: K:\Emulation\Atari5200\titles
04:26:08.2 14/07/2011: Validating: Emulator_5: Box Art Path: K:\Emulation\GameEx\null
04:26:08.2 14/07/2011: Warning: Emulator_5: Box Art Path Does not exist
04:26:08.2 14/07/2011: Validating: Emulator_5: Cart Art Path: K:\Emulation\GameEx\null
04:26:08.2 14/07/2011: Warning: Emulator_5: Cart Art Path Does not exist
04:26:08.2 14/07/2011: Validating: Emulator_5: Manual Path: K:\Emulation\GameEx\null
04:26:08.2 14/07/2011: Warning: Emulator_5: Manual Path Does not exist
04:26:08.3 14/07/2011: Validating: Emulator_6: Custom Background: Back - Atari 800.png
04:26:08.3 14/07/2011: Validating: Emulator_6: Snap Path: K:\Emulation\Atari 8-bit\snap
04:26:08.3 14/07/2011: Validating: Emulator_6: Not Found Image: C:\GameEx\THEMES\BlueBox\MEDIA\LOGOS\Atari 800.png
04:26:08.3 14/07/2011: Validating: Emulator_6: Custom Art Path 1: K:\Emulation\GameEx\null
04:26:08.3 14/07/2011: Warning: Emulator_6: Custom Art Path 1 Does not exist
04:26:08.3 14/07/2011: Validating: Emulator_6: Custom Art Path 2: K:\Emulation\GameEx\null
04:26:08.3 14/07/2011: Warning: Emulator_6: Custom Art Path 2 Does not exist
04:26:08.3 14/07/2011: Validating: Emulator_6: Custom Art Path 3: K:\Emulation\GameEx\null
04:26:08.3 14/07/2011: Warning: Emulator_6: Custom Art Path 3 Does not exist
04:26:08.3 14/07/2011: Validating: Emulator_6: Control Panel Path: K:\Emulation\GameEx\null
04:26:08.3 14/07/2011: Warning: Emulator_6: Control Panel Path Does not exist
04:26:08.3 14/07/2011: Validating: Emulator_6: Instructions Path: K:\Emulation\Atari 8-bit\Instructions
04:26:08.3 14/07/2011: Validating: Emulator_6: Database: [PC] Atari 8-bit
04:26:08.3 14/07/2011: Validating: Emulator_6: Title Snap Path: K:\Emulation\Atari 8-bit\title
04:26:08.3 14/07/2011: Warning: Emulator_6: Title Snap Path Does not exist
04:26:08.3 14/07/2011: Validating: Emulator_6: Box Art Path: K:\Emulation\Atari 8-bit\Inlay
04:26:08.3 14/07/2011: Validating: Emulator_6: Cart Art Path: K:\Emulation\GameEx\null
04:26:08.3 14/07/2011: Warning: Emulator_6: Cart Art Path Does not exist
04:26:08.3 14/07/2011: Validating: Emulator_6: Manual Path: K:\Emulation\Atari 8-bit\manual
04:26:08.3 14/07/2011: Validating: Emulator_7: Custom Background: Back - C64.png
04:26:08.3 14/07/2011: Validating: Emulator_7: Snap Path: K:\Emulation\C64\snap
04:26:08.3 14/07/2011: Validating: Emulator_7: Not Found Image: C:\GameEx\THEMES\BlueBox\MEDIA\LOGOS\Commodore 64.png
04:26:08.3 14/07/2011: Validating: Emulator_7: Custom Art Path 1: K:\Emulation\GameEx\null
04:26:08.3 14/07/2011: Warning: Emulator_7: Custom Art Path 1 Does not exist
04:26:08.3 14/07/2011: Validating: Emulator_7: Custom Art Path 2: K:\Emulation\GameEx\null
04:26:08.3 14/07/2011: Warning: Emulator_7: Custom Art Path 2 Does not exist
04:26:08.3 14/07/2011: Validating: Emulator_7: Custom Art Path 3: K:\Emulation\GameEx\null
04:26:08.4 14/07/2011: Warning: Emulator_7: Custom Art Path 3 Does not exist
04:26:08.4 14/07/2011: Validating: Emulator_7: Control Panel Path: K:\Emulation\GameEx\null
04:26:08.4 14/07/2011: Warning: Emulator_7: Control Panel Path Does not exist
04:26:08.4 14/07/2011: Validating: Emulator_7: Instructions Path: K:\Emulation\GameEx\null
04:26:08.4 14/07/2011: Warning: Emulator_7: Instructions Path Does not exist
04:26:08.4 14/07/2011: Validating: Emulator_7: Database: [PC] Commodore 64
04:26:08.4 14/07/2011: Validating: Emulator_7: Title Snap Path: K:\Emulation\C64\title
04:26:08.4 14/07/2011: Validating: Emulator_7: Box Art Path: K:\Emulation\C64\box
04:26:08.4 14/07/2011: Validating: Emulator_7: Cart Art Path: K:\Emulation\GameEx\null
04:26:08.4 14/07/2011: Warning: Emulator_7: Cart Art Path Does not exist
04:26:08.4 14/07/2011: Validating: Emulator_7: Manual Path: K:\Emulation\GameEx\null
04:26:08.4 14/07/2011: Warning: Emulator_7: Manual Path Does not exist
04:26:08.4 14/07/2011: Validating: Emulator_8: Custom Background: Back - Amiga.png
04:26:08.4 14/07/2011: Validating: Emulator_8: Snap Path: K:\Emulation\Amiga\WHDsnap
04:26:08.4 14/07/2011: Validating: Emulator_8: Not Found Image: C:\GameEx\THEMES\BlueBox\MEDIA\LOGOS\Commodore Amiga.png
04:26:08.4 14/07/2011: Validating: Emulator_8: Instructions Path: K:\Emulation\GameEx\null
04:26:08.4 14/07/2011: Warning: Emulator_8: Instructions Path Does not exist
04:26:08.4 14/07/2011: Validating: Emulator_8: Title Snap Path: K:\Emulation\Amiga\WHDtitle
04:26:08.4 14/07/2011: Validating: Emulator_8: Box Art Path: K:\Emulation\GameEx\null
04:26:08.4 14/07/2011: Warning: Emulator_8: Box Art Path Does not exist
04:26:08.4 14/07/2011: Validating: Emulator_8: Cart Art Path: K:\Emulation\GameEx\null
04:26:08.4 14/07/2011: Warning: Emulator_8: Cart Art Path Does not exist
04:26:08.4 14/07/2011: Validating: Emulator_8: Manual Path: K:\Emulation\GameEx\null
04:26:08.4 14/07/2011: Warning: Emulator_8: Manual Path Does not exist
04:26:08.4 14/07/2011: Validating: Emulator_9: Custom Background: Back - Amiga.png
04:26:08.4 14/07/2011: Validating: Emulator_9: Snap Path: K:\Emulation\Amiga\snap_floppies
04:26:08.5 14/07/2011: Validating: Emulator_9: Not Found Image: C:\GameEx\THEMES\BlueBox\MEDIA\LOGOS\Commodore Amiga.png
04:26:08.5 14/07/2011: Validating: Emulator_9: Custom Art Path 1: K:\Emulation\GameEx\null
04:26:08.5 14/07/2011: Warning: Emulator_9: Custom Art Path 1 Does not exist
04:26:08.5 14/07/2011: Validating: Emulator_9: Custom Art Path 2: K:\Emulation\GameEx\null
04:26:08.5 14/07/2011: Warning: Emulator_9: Custom Art Path 2 Does not exist
04:26:08.5 14/07/2011: Validating: Emulator_9: Custom Art Path 3: K:\Emulation\GameEx\null
04:26:08.5 14/07/2011: Warning: Emulator_9: Custom Art Path 3 Does not exist
04:26:08.5 14/07/2011: Validating: Emulator_9: Control Panel Path: K:\Emulation\GameEx\null
04:26:08.5 14/07/2011: Warning: Emulator_9: Control Panel Path Does not exist
04:26:08.5 14/07/2011: Validating: Emulator_9: Instructions Path: K:\Emulation\GameEx\null
04:26:08.5 14/07/2011: Warning: Emulator_9: Instructions Path Does not exist
04:26:08.5 14/07/2011: Validating: Emulator_9: Title Snap Path: K:\Emulation\Amiga\title
04:26:08.5 14/07/2011: Validating: Emulator_9: Box Art Path: K:\Emulation\GameEx\null
04:26:08.5 14/07/2011: Warning: Emulator_9: Box Art Path Does not exist
04:26:08.5 14/07/2011: Validating: Emulator_9: Cart Art Path: K:\Emulation\GameEx\null
04:26:08.5 14/07/2011: Warning: Emulator_9: Cart Art Path Does not exist
04:26:08.5 14/07/2011: Validating: Emulator_9: Manual Path: K:\Emulation\GameEx\null
04:26:08.5 14/07/2011: Warning: Emulator_9: Manual Path Does not exist
04:26:08.5 14/07/2011: Validating: Emulator_10: Custom Background: Back - MSX.png
04:26:08.5 14/07/2011: Validating: Emulator_10: Snap Path: K:\Emulation\MSX\snap
04:26:08.5 14/07/2011: Validating: Emulator_10: Not Found Image: C:\GameEx\THEMES\BlueBox\MEDIA\LOGOS\msx.png
04:26:08.5 14/07/2011: Validating: Emulator_10: Control Panel Path: K:\Emulation\GameEx\null
04:26:08.5 14/07/2011: Warning: Emulator_10: Control Panel Path Does not exist
04:26:08.5 14/07/2011: Validating: Emulator_10: Instructions Path: K:\Emulation\GameEx\null
04:26:08.5 14/07/2011: Warning: Emulator_10: Instructions Path Does not exist
04:26:08.5 14/07/2011: Validating: Emulator_10: Database: [PC] Microsoft MSX
04:26:08.5 14/07/2011: Validating: Emulator_10: Title Snap Path: K:\Emulation\MSX\title
04:26:08.5 14/07/2011: Validating: Emulator_10: Box Art Path: K:\Emulation\GameEx\null
04:26:08.5 14/07/2011: Warning: Emulator_10: Box Art Path Does not exist
04:26:08.5 14/07/2011: Validating: Emulator_10: Cart Art Path: K:\Emulation\GameEx\null
04:26:08.5 14/07/2011: Warning: Emulator_10: Cart Art Path Does not exist
04:26:08.6 14/07/2011: Validating: Emulator_10: Manual Path: K:\Emulation\GameEx\null
04:26:08.6 14/07/2011: Warning: Emulator_10: Manual Path Does not exist
04:26:08.6 14/07/2011: Validating: Emulator_11: Custom Background: Back - MSX.png
04:26:08.6 14/07/2011: Validating: Emulator_11: Snap Path: K:\Emulation\MSX\snap2
04:26:08.6 14/07/2011: Validating: Emulator_11: Not Found Image: C:\GameEx\THEMES\BlueBox\MEDIA\LOGOS\msx.png
04:26:08.6 14/07/2011: Validating: Emulator_11: Control Panel Path: K:\Emulation\GameEx\null
04:26:08.6 14/07/2011: Warning: Emulator_11: Control Panel Path Does not exist
04:26:08.6 14/07/2011: Validating: Emulator_11: Instructions Path: K:\Emulation\GameEx\null
04:26:08.6 14/07/2011: Warning: Emulator_11: Instructions Path Does not exist
04:26:08.6 14/07/2011: Validating: Emulator_11: Database: [PC] Microsoft MSX 2
04:26:08.6 14/07/2011: Validating: Emulator_11: Title Snap Path: K:\Emulation\MSX\title2
04:26:08.6 14/07/2011: Validating: Emulator_11: Box Art Path: K:\Emulation\GameEx\null
04:26:08.6 14/07/2011: Warning: Emulator_11: Box Art Path Does not exist
04:26:08.6 14/07/2011: Validating: Emulator_11: Cart Art Path: K:\Emulation\GameEx\null
04:26:08.6 14/07/2011: Warning: Emulator_11: Cart Art Path Does not exist
04:26:08.6 14/07/2011: Validating: Emulator_11: Manual Path: K:\Emulation\GameEx\null
04:26:08.6 14/07/2011: Warning: Emulator_11: Manual Path Does not exist
04:26:08.6 14/07/2011: Validating: Emulator_12: Custom Background: Back - NEC PC Engine.png
04:26:08.6 14/07/2011: Validating: Emulator_12: Snap Path: K:\Emulation\NEC PC Engine\snaps
04:26:08.6 14/07/2011: Validating: Emulator_12: Not Found Image: C:\GameEx\THEMES\BlueBox\MEDIA\LOGOS\PC Engine.png
04:26:08.6 14/07/2011: Validating: Emulator_12: Custom Art Path 1: K:\Emulation\GameEx\null
04:26:08.6 14/07/2011: Warning: Emulator_12: Custom Art Path 1 Does not exist
04:26:08.6 14/07/2011: Validating: Emulator_12: Custom Art Path 2: K:\Emulation\GameEx\null
04:26:08.6 14/07/2011: Warning: Emulator_12: Custom Art Path 2 Does not exist
04:26:08.6 14/07/2011: Validating: Emulator_12: Custom Art Path 3: K:\Emulation\GameEx\null
04:26:08.6 14/07/2011: Warning: Emulator_12: Custom Art Path 3 Does not exist
04:26:08.6 14/07/2011: Validating: Emulator_12: Control Panel Path: K:\Emulation\GameEx\null
04:26:08.7 14/07/2011: Warning: Emulator_12: Control Panel Path Does not exist
04:26:08.7 14/07/2011: Validating: Emulator_12: Instructions Path: K:\Emulation\GameEx\null
04:26:08.7 14/07/2011: Warning: Emulator_12: Instructions Path Does not exist
04:26:08.7 14/07/2011: Validating: Emulator_12: Database: [Console] NEC TurboGrafx-16
04:26:08.7 14/07/2011: Validating: Emulator_12: Title Snap Path: K:\Emulation\NEC PC Engine\titles
04:26:08.7 14/07/2011: Validating: Emulator_12: Box Art Path: K:\Emulation\GameEx\null
04:26:08.7 14/07/2011: Warning: Emulator_12: Box Art Path Does not exist
04:26:08.7 14/07/2011: Validating: Emulator_12: Cart Art Path: K:\Emulation\GameEx\null
04:26:08.7 14/07/2011: Warning: Emulator_12: Cart Art Path Does not exist
04:26:08.7 14/07/2011: Validating: Emulator_12: Manual Path: K:\Emulation\NEC PC Engine\manual
04:26:08.7 14/07/2011: Validating: Emulator_13: Custom Background: Back - NEC PC Engine.png
04:26:08.7 14/07/2011: Validating: Emulator_13: Snap Path: K:\Emulation\NEC PC Engine\snaps-cd
04:26:08.7 14/07/2011: Validating: Emulator_13: Not Found Image: C:\GameEx\THEMES\BlueBox\MEDIA\LOGOS\pcecd.png
04:26:08.7 14/07/2011: Validating: Emulator_13: Title Snap Path: K:\Emulation\NEC PC Engine\titles-cd
04:26:08.7 14/07/2011: Validating: Emulator_13: Manual Path: K:\Emulation\NEC PC Engine\manual
04:26:08.7 14/07/2011: Validating: Emulator_14: Custom Background: Back - NEC PC Engine.png
04:26:08.7 14/07/2011: Validating: Emulator_14: Snap Path: K:\Emulation\NEC PC Engine\snaps-supergrafx
04:26:08.7 14/07/2011: Validating: Emulator_14: Not Found Image: C:\GameEx\THEMES\BlueBox\MEDIA\LOGOS\supergrafx.png
04:26:08.7 14/07/2011: Validating: Emulator_14: Custom Art Path 1: K:\Emulation\GameEx\null
04:26:08.7 14/07/2011: Warning: Emulator_14: Custom Art Path 1 Does not exist
04:26:08.7 14/07/2011: Validating: Emulator_14: Custom Art Path 2: K:\Emulation\GameEx\null
04:26:08.7 14/07/2011: Warning: Emulator_14: Custom Art Path 2 Does not exist
04:26:08.7 14/07/2011: Validating: Emulator_14: Custom Art Path 3: K:\Emulation\GameEx\null
04:26:08.7 14/07/2011: Warning: Emulator_14: Custom Art Path 3 Does not exist
04:26:08.7 14/07/2011: Validating: Emulator_14: Control Panel Path: K:\Emulation\GameEx\null
04:26:08.7 14/07/2011: Warning: Emulator_14: Control Panel Path Does not exist
04:26:08.7 14/07/2011: Validating: Emulator_14: Instructions Path: K:\Emulation\GameEx\null
04:26:08.7 14/07/2011: Warning: Emulator_14: Instructions Path Does not exist
04:26:08.7 14/07/2011: Validating: Emulator_14: Database: [Console] NEC SuperGrafx
04:26:08.8 14/07/2011: Validating: Emulator_14: Title Snap Path: K:\Emulation\NEC PC Engine\titles-supergrafx
04:26:08.8 14/07/2011: Validating: Emulator_14: Box Art Path: K:\Emulation\GameEx\null
04:26:08.8 14/07/2011: Warning: Emulator_14: Box Art Path Does not exist
04:26:08.8 14/07/2011: Validating: Emulator_14: Cart Art Path: K:\Emulation\GameEx\null
04:26:08.8 14/07/2011: Warning: Emulator_14: Cart Art Path Does not exist
04:26:08.8 14/07/2011: Validating: Emulator_14: Manual Path: K:\Emulation\GameEx\null
04:26:08.8 14/07/2011: Warning: Emulator_14: Manual Path Does not exist
04:26:08.8 14/07/2011: Validating: Emulator_15: Custom Background: Back - Nintendo Gameboy.png
04:26:08.8 14/07/2011: Validating: Emulator_15: Snap Path: K:\Emulation\Gameboy\snapsGB
04:26:08.8 14/07/2011: Validating: Emulator_15: Not Found Image: C:\GameEx\THEMES\BlueBox\MEDIA\LOGOS\GameBoy.png
04:26:08.8 14/07/2011: Validating: Emulator_15: Custom Art Path 1: K:\Emulation\GameEx\null
04:26:08.8 14/07/2011: Warning: Emulator_15: Custom Art Path 1 Does not exist
04:26:08.8 14/07/2011: Validating: Emulator_15: Custom Art Path 2: K:\Emulation\GameEx\null
04:26:08.8 14/07/2011: Warning: Emulator_15: Custom Art Path 2 Does not exist
04:26:08.8 14/07/2011: Validating: Emulator_15: Custom Art Path 3: K:\Emulation\GameEx\null
04:26:08.8 14/07/2011: Warning: Emulator_15: Custom Art Path 3 Does not exist
04:26:08.8 14/07/2011: Validating: Emulator_15: Control Panel Path: K:\Emulation\GameEx\null
04:26:08.8 14/07/2011: Warning: Emulator_15: Control Panel Path Does not exist
04:26:08.8 14/07/2011: Validating: Emulator_15: Instructions Path: K:\Emulation\GameEx\null
04:26:08.8 14/07/2011: Warning: Emulator_15: Instructions Path Does not exist
04:26:08.8 14/07/2011: Validating: Emulator_15: Database: [Handheld] Nintendo Game Boy
04:26:08.8 14/07/2011: Validating: Emulator_15: Title Snap Path: K:\Emulation\Gameboy\titlesGB
04:26:08.8 14/07/2011: Validating: Emulator_15: Box Art Path: K:\Emulation\GameEx\null
04:26:08.8 14/07/2011: Warning: Emulator_15: Box Art Path Does not exist
04:26:08.8 14/07/2011: Validating: Emulator_15: Cart Art Path: K:\Emulation\GameEx\null
04:26:08.8 14/07/2011: Warning: Emulator_15: Cart Art Path Does not exist
04:26:08.9 14/07/2011: Validating: Emulator_15: Manual Path: K:\Emulation\GameEx\null
04:26:08.9 14/07/2011: Warning: Emulator_15: Manual Path Does not exist
04:26:08.9 14/07/2011: Validating: Emulator_16: Custom Background: Back - Gameboy Advance.png
04:26:08.9 14/07/2011: Validating: Emulator_16: Snap Path: K:\Emulation\Gameboy\snapsGBA
04:26:08.9 14/07/2011: Validating: Emulator_16: Not Found Image: C:\GameEx\THEMES\BlueBox\MEDIA\LOGOS\GameBoy Advance.png
04:26:08.9 14/07/2011: Validating: Emulator_16: Custom Art Path 1: K:\Emulation\GameEx\null
04:26:08.9 14/07/2011: Warning: Emulator_16: Custom Art Path 1 Does not exist
04:26:08.9 14/07/2011: Validating: Emulator_16: Custom Art Path 2: K:\Emulation\GameEx\null
04:26:08.9 14/07/2011: Warning: Emulator_16: Custom Art Path 2 Does not exist
04:26:08.9 14/07/2011: Validating: Emulator_16: Custom Art Path 3: K:\Emulation\GameEx\null
04:26:08.9 14/07/2011: Warning: Emulator_16: Custom Art Path 3 Does not exist
04:26:08.9 14/07/2011: Validating: Emulator_16: Control Panel Path: K:\Emulation\GameEx\null
04:26:08.9 14/07/2011: Warning: Emulator_16: Control Panel Path Does not exist
04:26:08.9 14/07/2011: Validating: Emulator_16: Instructions Path: K:\Emulation\GameEx\null
04:26:08.9 14/07/2011: Warning: Emulator_16: Instructions Path Does not exist
04:26:08.9 14/07/2011: Validating: Emulator_16: Database: [Handheld] Nintendo Game Boy Advance
04:26:08.9 14/07/2011: Validating: Emulator_16: Title Snap Path: K:\Emulation\Gameboy\titlesGBA
04:26:08.9 14/07/2011: Validating: Emulator_16: Box Art Path: K:\Emulation\GameEx\null
04:26:08.9 14/07/2011: Warning: Emulator_16: Box Art Path Does not exist
04:26:08.9 14/07/2011: Validating: Emulator_16: Cart Art Path: K:\Emulation\GameEx\null
04:26:08.9 14/07/2011: Warning: Emulator_16: Cart Art Path Does not exist
04:26:08.9 14/07/2011: Validating: Emulator_16: Manual Path: K:\Emulation\GameEx\null
04:26:08.9 14/07/2011: Warning: Emulator_16: Manual Path Does not exist
04:26:08.9 14/07/2011: Validating: Emulator_17: Custom Background: Back - Gameboy Colour.png
04:26:08.9 14/07/2011: Validating: Emulator_17: Snap Path: K:\Emulation\Gameboy\snapsGBC
04:26:09.0 14/07/2011: Validating: Emulator_17: Not Found Image: C:\GameEx\THEMES\BlueBox\MEDIA\LOGOS\Gameboy Colour.png
04:26:09.0 14/07/2011: Validating: Emulator_17: Custom Art Path 1: K:\Emulation\GameEx\null
04:26:09.0 14/07/2011: Warning: Emulator_17: Custom Art Path 1 Does not exist
04:26:09.0 14/07/2011: Validating: Emulator_17: Custom Art Path 2: K:\Emulation\GameEx\null
04:26:09.0 14/07/2011: Warning: Emulator_17: Custom Art Path 2 Does not exist
04:26:09.0 14/07/2011: Validating: Emulator_17: Custom Art Path 3: K:\Emulation\GameEx\null
04:26:09.0 14/07/2011: Warning: Emulator_17: Custom Art Path 3 Does not exist
04:26:09.0 14/07/2011: Validating: Emulator_17: Control Panel Path: K:\Emulation\GameEx\null
04:26:09.0 14/07/2011: Warning: Emulator_17: Control Panel Path Does not exist
04:26:09.0 14/07/2011: Validating: Emulator_17: Instructions Path: K:\Emulation\GameEx\null
04:26:09.0 14/07/2011: Warning: Emulator_17: Instructions Path Does not exist
04:26:09.0 14/07/2011: Validating: Emulator_17: Database: [Handheld] Nintendo Game Boy Color
04:26:09.0 14/07/2011: Validating: Emulator_17: Title Snap Path: K:\Emulation\Gameboy\titlesGBC
04:26:09.0 14/07/2011: Validating: Emulator_17: Box Art Path: K:\Emulation\GameEx\null
04:26:09.0 14/07/2011: Warning: Emulator_17: Box Art Path Does not exist
04:26:09.0 14/07/2011: Validating: Emulator_17: Cart Art Path: K:\Emulation\GameEx\null
04:26:09.0 14/07/2011: Warning: Emulator_17: Cart Art Path Does not exist
04:26:09.0 14/07/2011: Validating: Emulator_17: Manual Path: K:\Emulation\GameEx\null
04:26:09.0 14/07/2011: Warning: Emulator_17: Manual Path Does not exist
04:26:09.0 14/07/2011: Validating: Emulator_18: Custom Background: Back - NES.png
04:26:09.0 14/07/2011: Validating: Emulator_18: Snap Path: K:\Emulation\NES\screens
04:26:09.0 14/07/2011: Validating: Emulator_18: Not Found Image: C:\GameEx\THEMES\BlueBox\MEDIA\LOGOS\Nintendo Nes.png
04:26:09.0 14/07/2011: Validating: Emulator_18: Custom Art Path 1: K:\Emulation\GameEx\null
04:26:09.0 14/07/2011: Warning: Emulator_18: Custom Art Path 1 Does not exist
04:26:09.0 14/07/2011: Validating: Emulator_18: Custom Art Path 2: K:\Emulation\GameEx\null
04:26:09.0 14/07/2011: Warning: Emulator_18: Custom Art Path 2 Does not exist
04:26:09.0 14/07/2011: Validating: Emulator_18: Custom Art Path 3: K:\Emulation\GameEx\null
04:26:09.0 14/07/2011: Warning: Emulator_18: Custom Art Path 3 Does not exist
04:26:09.0 14/07/2011: Validating: Emulator_18: Control Panel Path: K:\Emulation\GameEx\null
04:26:09.0 14/07/2011: Warning: Emulator_18: Control Panel Path Does not exist
04:26:09.1 14/07/2011: Validating: Emulator_18: Instructions Path: K:\Emulation\GameEx\null
04:26:09.1 14/07/2011: Warning: Emulator_18: Instructions Path Does not exist
04:26:09.1 14/07/2011: Validating: Emulator_18: Database: [Console] Nintendo NES
04:26:09.1 14/07/2011: Validating: Emulator_18: Title Snap Path: K:\Emulation\NES\titles
04:26:09.1 14/07/2011: Validating: Emulator_18: Box Art Path: K:\Emulation\NES\box
04:26:09.1 14/07/2011: Validating: Emulator_18: Cart Art Path: K:\Emulation\GameEx\null
04:26:09.1 14/07/2011: Warning: Emulator_18: Cart Art Path Does not exist
04:26:09.1 14/07/2011: Validating: Emulator_18: Manual Path: K:\Emulation\GameEx\null
04:26:09.1 14/07/2011: Warning: Emulator_18: Manual Path Does not exist
04:26:09.1 14/07/2011: Validating: Emulator_19: Custom Background: Back - Snes.png
04:26:09.1 14/07/2011: Validating: Emulator_19: Snap Path: K:\Emulation\Super Nintendo\snaps
04:26:09.1 14/07/2011: Validating: Emulator_19: Not Found Image: C:\GameEx\THEMES\BlueBox\MEDIA\LOGOS\Super Nintendo.png
04:26:09.1 14/07/2011: Validating: Emulator_19: Custom Art Path 1: K:\Emulation\GameEx\null
04:26:09.1 14/07/2011: Warning: Emulator_19: Custom Art Path 1 Does not exist
04:26:09.1 14/07/2011: Validating: Emulator_19: Custom Art Path 2: K:\Emulation\GameEx\null
04:26:09.1 14/07/2011: Warning: Emulator_19: Custom Art Path 2 Does not exist
04:26:09.1 14/07/2011: Validating: Emulator_19: Custom Art Path 3: K:\Emulation\GameEx\null
04:26:09.1 14/07/2011: Warning: Emulator_19: Custom Art Path 3 Does not exist
04:26:09.1 14/07/2011: Validating: Emulator_19: Control Panel Path: K:\Emulation\GameEx\null
04:26:09.1 14/07/2011: Warning: Emulator_19: Control Panel Path Does not exist
04:26:09.1 14/07/2011: Validating: Emulator_19: Instructions Path: K:\Emulation\GameEx\null
04:26:09.1 14/07/2011: Warning: Emulator_19: Instructions Path Does not exist
04:26:09.1 14/07/2011: Validating: Emulator_19: Database: [Console] Nintendo SNES
04:26:09.1 14/07/2011: Validating: Emulator_19: Title Snap Path: K:\Emulation\Super Nintendo\titles
04:26:09.1 14/07/2011: Validating: Emulator_19: Box Art Path: K:\Emulation\Super Nintendo\box
04:26:09.2 14/07/2011: Validating: Emulator_19: Cart Art Path: K:\Emulation\Super Nintendo\cart
04:26:09.2 14/07/2011: Validating: Emulator_19: Manual Path: K:\Emulation\GameEx\null
04:26:09.2 14/07/2011: Warning: Emulator_19: Manual Path Does not exist
04:26:09.2 14/07/2011: Validating: Emulator_20: Custom Background:
04:26:09.2 14/07/2011: Warning: Emulator_20: Custom Background Does not exist
04:26:09.2 14/07/2011: Validating: Emulator_20: Snap Path: K:\Emulation\PC Games\snap
04:26:09.2 14/07/2011: Validating: Emulator_20: Not Found Image: C:\GameEx\THEMES\BlueBox\MEDIA\LOGOS\PC Games.png
04:26:09.2 14/07/2011: Validating: Emulator_20: Custom Art Path 1: K:\Emulation\GameEx\null
04:26:09.2 14/07/2011: Warning: Emulator_20: Custom Art Path 1 Does not exist
04:26:09.2 14/07/2011: Validating: Emulator_20: Custom Art Path 2: K:\Emulation\GameEx\null
04:26:09.2 14/07/2011: Warning: Emulator_20: Custom Art Path 2 Does not exist
04:26:09.2 14/07/2011: Validating: Emulator_20: Custom Art Path 3: K:\Emulation\GameEx\null
04:26:09.2 14/07/2011: Warning: Emulator_20: Custom Art Path 3 Does not exist
04:26:09.2 14/07/2011: Validating: Emulator_20: Database: Template
04:26:09.2 14/07/2011: Validating: Emulator_21: Custom Background: Back - 32X.png
04:26:09.2 14/07/2011: Validating: Emulator_21: Snap Path: K:\Emulation\Sega Megadrive\snaps32X
04:26:09.2 14/07/2011: Validating: Emulator_21: Not Found Image: C:\GameEx\THEMES\BlueBox\MEDIA\LOGOS\32X.png
04:26:09.2 14/07/2011: Validating: Emulator_21: Custom Art Path 1: K:\Emulation\GameEx\null
04:26:09.2 14/07/2011: Warning: Emulator_21: Custom Art Path 1 Does not exist
04:26:09.2 14/07/2011: Validating: Emulator_21: Custom Art Path 2: K:\Emulation\GameEx\null
04:26:09.2 14/07/2011: Warning: Emulator_21: Custom Art Path 2 Does not exist
04:26:09.2 14/07/2011: Validating: Emulator_21: Custom Art Path 3: K:\Emulation\GameEx\null
04:26:09.2 14/07/2011: Warning: Emulator_21: Custom Art Path 3 Does not exist
04:26:09.2 14/07/2011: Validating: Emulator_21: Control Panel Path: K:\Emulation\GameEx\null
04:26:09.2 14/07/2011: Warning: Emulator_21: Control Panel Path Does not exist
04:26:09.2 14/07/2011: Validating: Emulator_21: Instructions Path: K:\Emulation\GameEx\null
04:26:09.2 14/07/2011: Warning: Emulator_21: Instructions Path Does not exist
04:26:09.2 14/07/2011: Validating: Emulator_21: Database: [Console] Sega 32X
04:26:09.3 14/07/2011: Validating: Emulator_21: Title Snap Path: K:\Emulation\Sega Megadrive\titles32X
04:26:09.3 14/07/2011: Validating: Emulator_21: Box Art Path: K:\Emulation\Sega Megadrive\box
04:26:09.3 14/07/2011: Validating: Emulator_21: Cart Art Path: K:\Emulation\GameEx\null
04:26:09.3 14/07/2011: Warning: Emulator_21: Cart Art Path Does not exist
04:26:09.3 14/07/2011: Validating: Emulator_21: Manual Path: K:\Emulation\GameEx\null
04:26:09.3 14/07/2011: Warning: Emulator_21: Manual Path Does not exist
04:26:09.3 14/07/2011: Validating: Emulator_22: Custom Background: Back - Game Gear.png
04:26:09.3 14/07/2011: Validating: Emulator_22: Snap Path: K:\Emulation\Sega Game Gear\snaps
04:26:09.3 14/07/2011: Validating: Emulator_22: Not Found Image: C:\GameEx\THEMES\BlueBox\MEDIA\LOGOS\GameGear.png
04:26:09.3 14/07/2011: Validating: Emulator_22: Custom Art Path 1: K:\Emulation\GameEx\null
04:26:09.3 14/07/2011: Warning: Emulator_22: Custom Art Path 1 Does not exist
04:26:09.3 14/07/2011: Validating: Emulator_22: Custom Art Path 2: K:\Emulation\GameEx\null
04:26:09.3 14/07/2011: Warning: Emulator_22: Custom Art Path 2 Does not exist
04:26:09.3 14/07/2011: Validating: Emulator_22: Custom Art Path 3: K:\Emulation\GameEx\null
04:26:09.3 14/07/2011: Warning: Emulator_22: Custom Art Path 3 Does not exist
04:26:09.3 14/07/2011: Validating: Emulator_22: Control Panel Path: K:\Emulation\GameEx\null
04:26:09.3 14/07/2011: Warning: Emulator_22: Control Panel Path Does not exist
04:26:09.3 14/07/2011: Validating: Emulator_22: Instructions Path: K:\Emulation\GameEx\null
04:26:09.3 14/07/2011: Warning: Emulator_22: Instructions Path Does not exist
04:26:09.3 14/07/2011: Validating: Emulator_22: Database: [Handheld] Sega Game Gear
04:26:09.3 14/07/2011: Validating: Emulator_22: Title Snap Path: K:\Emulation\Sega Game Gear\titles
04:26:09.3 14/07/2011: Validating: Emulator_22: Box Art Path: K:\Emulation\GameEx\null
04:26:09.3 14/07/2011: Warning: Emulator_22: Box Art Path Does not exist
04:26:09.3 14/07/2011: Validating: Emulator_22: Cart Art Path: K:\Emulation\GameEx\null
04:26:09.4 14/07/2011: Warning: Emulator_22: Cart Art Path Does not exist
04:26:09.4 14/07/2011: Validating: Emulator_22: Manual Path: K:\Emulation\GameEx\null
04:26:09.4 14/07/2011: Warning: Emulator_22: Manual Path Does not exist
04:26:09.4 14/07/2011: Validating: Emulator_23: Custom Background: Back - Master System.png
04:26:09.4 14/07/2011: Validating: Emulator_23: Snap Path: K:\Emulation\Sega Master System\snaps
04:26:09.4 14/07/2011: Validating: Emulator_23: Not Found Image: C:\GameEx\THEMES\BlueBox\MEDIA\LOGOS\Sega Master System.png
04:26:09.4 14/07/2011: Validating: Emulator_23: Custom Art Path 1: K:\Emulation\GameEx\null
04:26:09.4 14/07/2011: Warning: Emulator_23: Custom Art Path 1 Does not exist
04:26:09.4 14/07/2011: Validating: Emulator_23: Custom Art Path 2: K:\Emulation\GameEx\null
04:26:09.4 14/07/2011: Warning: Emulator_23: Custom Art Path 2 Does not exist
04:26:09.4 14/07/2011: Validating: Emulator_23: Custom Art Path 3: K:\Emulation\GameEx\null
04:26:09.4 14/07/2011: Warning: Emulator_23: Custom Art Path 3 Does not exist
04:26:09.4 14/07/2011: Validating: Emulator_23: Control Panel Path: K:\Emulation\GameEx\null
04:26:09.4 14/07/2011: Warning: Emulator_23: Control Panel Path Does not exist
04:26:09.4 14/07/2011: Validating: Emulator_23: Instructions Path: K:\Emulation\GameEx\null
04:26:09.4 14/07/2011: Warning: Emulator_23: Instructions Path Does not exist
04:26:09.4 14/07/2011: Validating: Emulator_23: Database: Template
04:26:09.4 14/07/2011: Validating: Emulator_23: Title Snap Path: K:\Emulation\Sega Master System\titles
04:26:09.4 14/07/2011: Validating: Emulator_23: Box Art Path: K:\Emulation\Sega Master System\box
04:26:09.4 14/07/2011: Validating: Emulator_23: Cart Art Path: K:\Emulation\GameEx\null
04:26:09.4 14/07/2011: Warning: Emulator_23: Cart Art Path Does not exist
04:26:09.4 14/07/2011: Validating: Emulator_23: Manual Path: K:\Emulation\GameEx\null
04:26:09.4 14/07/2011: Warning: Emulator_23: Manual Path Does not exist
04:26:09.5 14/07/2011: Validating: Emulator_24: Custom Background: megacdback.png
04:26:09.5 14/07/2011: Warning: Emulator_24: Custom Background Does not exist
04:26:09.5 14/07/2011: Validating: Emulator_24: Snap Path: K:\Emulation\Sega Megadrive\snapsCD
04:26:09.5 14/07/2011: Validating: Emulator_24: Not Found Image: C:\GameEx\THEMES\BlueBox\MEDIA\LOGOS\MegaCD.png
04:26:09.5 14/07/2011: Validating: Emulator_24: Custom Art Path 1: K:\Emulation\GameEx\null
04:26:09.5 14/07/2011: Warning: Emulator_24: Custom Art Path 1 Does not exist
04:26:09.5 14/07/2011: Validating: Emulator_24: Custom Art Path 2: K:\Emulation\GameEx\null
04:26:09.5 14/07/2011: Warning: Emulator_24: Custom Art Path 2 Does not exist
04:26:09.5 14/07/2011: Validating: Emulator_24: Custom Art Path 3: K:\Emulation\GameEx\null
04:26:09.5 14/07/2011: Warning: Emulator_24: Custom Art Path 3 Does not exist
04:26:09.5 14/07/2011: Validating: Emulator_24: Control Panel Path: K:\Emulation\GameEx\null
04:26:09.5 14/07/2011: Warning: Emulator_24: Control Panel Path Does not exist
04:26:09.5 14/07/2011: Validating: Emulator_24: Instructions Path: K:\Emulation\GameEx\null
04:26:09.5 14/07/2011: Warning: Emulator_24: Instructions Path Does not exist
04:26:09.5 14/07/2011: Validating: Emulator_24: Database: [Console] Sega CD
04:26:09.5 14/07/2011: Validating: Emulator_24: Title Snap Path: K:\Emulation\Sega Megadrive\titlesCD
04:26:09.5 14/07/2011: Validating: Emulator_24: Box Art Path: K:\Emulation\Sega Megadrive\box
04:26:09.5 14/07/2011: Validating: Emulator_24: Cart Art Path: K:\Emulation\GameEx\null
04:26:09.5 14/07/2011: Warning: Emulator_24: Cart Art Path Does not exist
04:26:09.5 14/07/2011: Validating: Emulator_24: Manual Path: K:\Emulation\GameEx\null
04:26:09.5 14/07/2011: Warning: Emulator_24: Manual Path Does not exist
04:26:09.5 14/07/2011: Validating: Emulator_25: Custom Background: Back - Megadrive.png
04:26:09.5 14/07/2011: Validating: Emulator_25: Snap Path: K:\Emulation\Sega Megadrive\snaps
04:26:09.5 14/07/2011: Validating: Emulator_25: Not Found Image: C:\GameEx\THEMES\BlueBox\MEDIA\LOGOS\Sega Megadrive.png
04:26:09.5 14/07/2011: Validating: Emulator_25: Custom Art Path 1: K:\Emulation\GameEx\null
04:26:09.5 14/07/2011: Warning: Emulator_25: Custom Art Path 1 Does not exist
04:26:09.5 14/07/2011: Validating: Emulator_25: Custom Art Path 2: K:\Emulation\GameEx\null
04:26:09.5 14/07/2011: Warning: Emulator_25: Custom Art Path 2 Does not exist
04:26:09.5 14/07/2011: Validating: Emulator_25: Custom Art Path 3: K:\Emulation\GameEx\null
04:26:09.5 14/07/2011: Warning: Emulator_25: Custom Art Path 3 Does not exist
04:26:09.6 14/07/2011: Validating: Emulator_25: Control Panel Path: K:\Emulation\GameEx\null
04:26:09.6 14/07/2011: Warning: Emulator_25: Control Panel Path Does not exist
04:26:09.6 14/07/2011: Validating: Emulator_25: Instructions Path: K:\Emulation\GameEx\null
04:26:09.6 14/07/2011: Warning: Emulator_25: Instructions Path Does not exist
04:26:09.6 14/07/2011: Validating: Emulator_25: Database: [Console] Sega Genesis
04:26:09.6 14/07/2011: Validating: Emulator_25: Title Snap Path: K:\Emulation\Sega Megadrive\titles
04:26:09.6 14/07/2011: Validating: Emulator_25: Box Art Path: K:\Emulation\Sega Megadrive\box
04:26:09.6 14/07/2011: Validating: Emulator_25: Cart Art Path: K:\Emulation\GameEx\null
04:26:09.6 14/07/2011: Warning: Emulator_25: Cart Art Path Does not exist
04:26:09.6 14/07/2011: Validating: Emulator_25: Manual Path: K:\Emulation\GameEx\null
04:26:09.6 14/07/2011: Warning: Emulator_25: Manual Path Does not exist
04:26:09.6 14/07/2011: Validating: Emulator_26: Custom Background: Back - Saturn.png
04:26:09.6 14/07/2011: Validating: Emulator_26: Snap Path: K:\Emulation\Sega Saturn\snap
04:26:09.6 14/07/2011: Validating: Emulator_26: Not Found Image: C:\GameEx\THEMES\BlueBox\MEDIA\LOGOS\Sega Saturn.png
04:26:09.6 14/07/2011: Validating: Emulator_26: Database: [Console] Sega Saturn
04:26:09.6 14/07/2011: Validating: Emulator_26: Title Snap Path: K:\Emulation\Sega Saturn\title
04:26:09.6 14/07/2011: Validating: Emulator_27: Custom Background: Back - Saturn.png
04:26:09.6 14/07/2011: Validating: Emulator_27: Snap Path: K:\Emulation\Sega Saturn\snap
04:26:09.6 14/07/2011: Validating: Emulator_27: Not Found Image: C:\GameEx\THEMES\BlueBox\MEDIA\LOGOS\Sega Saturn.png
04:26:09.6 14/07/2011: Validating: Emulator_27: Database: [Console] Sega Saturn
04:26:09.6 14/07/2011: Validating: Emulator_27: Title Snap Path: K:\Emulation\Sega Saturn\title
04:26:09.6 14/07/2011: Validating: Emulator_28: Custom Background: Back - Saturn.png
04:26:09.6 14/07/2011: Validating: Emulator_28: Snap Path: K:\Emulation\Sega Saturn\snap
04:26:09.7 14/07/2011: Validating: Emulator_28: Not Found Image: C:\GameEx\THEMES\BlueBox\MEDIA\LOGOS\Sega Saturn.png
04:26:09.7 14/07/2011: Validating: Emulator_28: Database: [Console] Sega Saturn
04:26:09.7 14/07/2011: Validating: Emulator_28: Title Snap Path: K:\Emulation\Sega Saturn\title
04:26:09.7 14/07/2011: Validating: Emulator_29: Custom Background: sg1000back.png
04:26:09.7 14/07/2011: Warning: Emulator_29: Custom Background Does not exist
04:26:09.7 14/07/2011: Validating: Emulator_29: Snap Path: K:\Emulation\Sega SG-1000\snaps
04:26:09.7 14/07/2011: Validating: Emulator_29: Not Found Image: C:\GameEx\THEMES\BlueBox\MEDIA\LOGOS\sg1000.png
04:26:09.7 14/07/2011: Validating: Emulator_29: Custom Art Path 1: K:\Emulation\GameEx\null
04:26:09.7 14/07/2011: Warning: Emulator_29: Custom Art Path 1 Does not exist
04:26:09.7 14/07/2011: Validating: Emulator_29: Custom Art Path 2: K:\Emulation\GameEx\null
04:26:09.7 14/07/2011: Warning: Emulator_29: Custom Art Path 2 Does not exist
04:26:09.7 14/07/2011: Validating: Emulator_29: Custom Art Path 3: K:\Emulation\GameEx\null
04:26:09.7 14/07/2011: Warning: Emulator_29: Custom Art Path 3 Does not exist
04:26:09.7 14/07/2011: Validating: Emulator_29: Control Panel Path: K:\Emulation\GameEx\null
04:26:09.7 14/07/2011: Warning: Emulator_29: Control Panel Path Does not exist
04:26:09.7 14/07/2011: Validating: Emulator_29: Instructions Path: K:\Emulation\GameEx\null
04:26:09.7 14/07/2011: Warning: Emulator_29: Instructions Path Does not exist
04:26:09.7 14/07/2011: Validating: Emulator_29: Database: [Console] Sega SG-1000
04:26:09.7 14/07/2011: Validating: Emulator_29: Title Snap Path: K:\Emulation\Sega SG-1000\titles
04:26:09.7 14/07/2011: Validating: Emulator_29: Box Art Path: K:\Emulation\GameEx\null
04:26:09.7 14/07/2011: Warning: Emulator_29: Box Art Path Does not exist
04:26:09.7 14/07/2011: Validating: Emulator_29: Cart Art Path: K:\Emulation\GameEx\null
04:26:09.7 14/07/2011: Warning: Emulator_29: Cart Art Path Does not exist
04:26:09.7 14/07/2011: Validating: Emulator_29: Manual Path: K:\Emulation\GameEx\null
04:26:09.7 14/07/2011: Warning: Emulator_29: Manual Path Does not exist
04:26:09.7 14/07/2011: Validating: Emulator_30: Custom Background: Back - Spectrum.png
04:26:09.7 14/07/2011: Validating: Emulator_30: Snap Path: K:\Emulation\ZX Spectrum\snap
04:26:09.7 14/07/2011: Validating: Emulator_30: Not Found Image: C:\GameEx\THEMES\BlueBox\MEDIA\LOGOS\speccy128.png
04:26:09.8 14/07/2011: Validating: Emulator_30: Custom Art Path 1: K:\Emulation\GameEx\null
04:26:09.8 14/07/2011: Warning: Emulator_30: Custom Art Path 1 Does not exist
04:26:09.8 14/07/2011: Validating: Emulator_30: Custom Art Path 2: K:\Emulation\GameEx\null
04:26:09.8 14/07/2011: Warning: Emulator_30: Custom Art Path 2 Does not exist
04:26:09.8 14/07/2011: Validating: Emulator_30: Custom Art Path 3: K:\Emulation\GameEx\null
04:26:09.8 14/07/2011: Warning: Emulator_30: Custom Art Path 3 Does not exist
04:26:09.8 14/07/2011: Validating: Emulator_30: Control Panel Path: K:\Emulation\GameEx\null
04:26:09.8 14/07/2011: Warning: Emulator_30: Control Panel Path Does not exist
04:26:09.8 14/07/2011: Validating: Emulator_30: Instructions Path: K:\Emulation\GameEx\null
04:26:09.8 14/07/2011: Warning: Emulator_30: Instructions Path Does not exist
04:26:09.8 14/07/2011: Validating: Emulator_30: Database: [PC] Sinclair ZX Spectrum
04:26:09.8 14/07/2011: Validating: Emulator_30: Title Snap Path: K:\Emulation\ZX Spectrum\title
04:26:09.8 14/07/2011: Validating: Emulator_30: Box Art Path: K:\Emulation\ZX Spectrum\inlay
04:26:09.8 14/07/2011: Validating: Emulator_30: Cart Art Path: K:\Emulation\GameEx\null
04:26:09.8 14/07/2011: Warning: Emulator_30: Cart Art Path Does not exist
04:26:09.8 14/07/2011: Validating: Emulator_30: Manual Path: K:\Emulation\GameEx\null
04:26:09.8 14/07/2011: Warning: Emulator_30: Manual Path Does not exist
04:26:09.8 14/07/2011: Validating: Emulator_31: Custom Background: Back - Spectrum.png
04:26:09.8 14/07/2011: Validating: Emulator_31: Snap Path: K:\Emulation\ZX Spectrum\snap
04:26:09.8 14/07/2011: Validating: Emulator_31: Not Found Image: C:\GameEx\THEMES\BlueBox\MEDIA\LOGOS\Sinclair Spectrum.png
04:26:09.8 14/07/2011: Validating: Emulator_31: Custom Art Path 1: K:\Emulation\GameEx\null
04:26:09.8 14/07/2011: Warning: Emulator_31: Custom Art Path 1 Does not exist
04:26:09.8 14/07/2011: Validating: Emulator_31: Custom Art Path 2: K:\Emulation\GameEx\null
04:26:09.8 14/07/2011: Warning: Emulator_31: Custom Art Path 2 Does not exist
04:26:09.8 14/07/2011: Validating: Emulator_31: Custom Art Path 3: K:\Emulation\GameEx\null
04:26:09.9 14/07/2011: Warning: Emulator_31: Custom Art Path 3 Does not exist
04:26:09.9 14/07/2011: Validating: Emulator_31: Control Panel Path: K:\Emulation\GameEx\null
04:26:09.9 14/07/2011: Warning: Emulator_31: Control Panel Path Does not exist
04:26:09.9 14/07/2011: Validating: Emulator_31: Instructions Path: K:\Emulation\GameEx\null
04:26:09.9 14/07/2011: Warning: Emulator_31: Instructions Path Does not exist
04:26:09.9 14/07/2011: Validating: Emulator_31: Database: [PC] Sinclair ZX Spectrum
04:26:09.9 14/07/2011: Validating: Emulator_31: Title Snap Path: K:\Emulation\ZX Spectrum\title
04:26:09.9 14/07/2011: Validating: Emulator_31: Box Art Path: K:\Emulation\ZX Spectrum\inlay
04:26:09.9 14/07/2011: Validating: Emulator_31: Cart Art Path: K:\Emulation\GameEx\null
04:26:09.9 14/07/2011: Warning: Emulator_31: Cart Art Path Does not exist
04:26:09.9 14/07/2011: Validating: Emulator_31: Manual Path: K:\Emulation\GameEx\null
04:26:09.9 14/07/2011: Warning: Emulator_31: Manual Path Does not exist
04:26:09.9 14/07/2011: Restoring Emulator from Cache
04:26:10.0 14/07/2011: No Database Data
04:26:10.0 14/07/2011: Restoring Emulator from Cache
04:26:10.1 14/07/2011: No Database Data
04:26:10.2 14/07/2011: Restoring Emulator from Cache
04:26:10.3 14/07/2011: Restoring Emulator Database From Cache
04:26:11.2 14/07/2011: Restoring Emulator from Cache
04:26:11.2 14/07/2011: Restoring Emulator Database From Cache
04:26:11.3 14/07/2011: Restoring Emulator from Cache
04:26:11.3 14/07/2011: Restoring Emulator Database From Cache
04:26:11.4 14/07/2011: Restoring Emulator from Cache
04:26:11.5 14/07/2011: Restoring Emulator Database From Cache
04:26:11.5 14/07/2011: Restoring Emulator from Cache
04:26:11.7 14/07/2011: Restoring Emulator from Cache
04:26:11.8 14/07/2011: Restoring Emulator Database From Cache
04:26:11.9 14/07/2011: Restoring Emulator from Cache
04:26:11.9 14/07/2011: Restoring Emulator Database From Cache
04:26:12.0 14/07/2011: Restoring Emulator from Cache
04:26:12.0 14/07/2011: Restoring Emulator Database From Cache
04:26:12.1 14/07/2011: Restoring Emulator from Cache
04:26:12.2 14/07/2011: Restoring Emulator Database From Cache
04:26:12.2 14/07/2011: Restoring Emulator from Cache
04:26:12.4 14/07/2011: Restoring Emulator from Cache
04:26:12.5 14/07/2011: Restoring Emulator Database From Cache
04:26:12.8 14/07/2011: Restoring Emulator from Cache
04:26:12.9 14/07/2011: Restoring Emulator Database From Cache
04:26:13.1 14/07/2011: Restoring Emulator from Cache
04:26:13.1 14/07/2011: Restoring Emulator Database From Cache
04:26:13.5 14/07/2011: Restoring Emulator from Cache
04:26:13.6 14/07/2011: Restoring Emulator Database From Cache
04:26:14.0 14/07/2011: Restoring Emulator from Cache
04:26:14.0 14/07/2011: No Database Data
04:26:14.0 14/07/2011: Restoring Emulator Database From Cache
04:26:14.1 14/07/2011: Restoring Emulator Database From Cache
04:26:14.2 14/07/2011: Restoring Emulator from Cache
04:26:14.2 14/07/2011: No Database Data
04:26:14.3 14/07/2011: Restoring Emulator Database From Cache
04:26:14.3 14/07/2011: Restoring Emulator from Cache
04:26:14.4 14/07/2011: Restoring Emulator Database From Cache
04:26:14.6 14/07/2011: Restoring Emulator from Cache
04:26:14.6 14/07/2011: Restoring Emulator Database From Cache
04:26:14.7 14/07/2011: Restoring Emulator from Cache
04:26:14.7 14/07/2011: Restoring Emulator Database From Cache
04:26:14.8 14/07/2011: Restoring Emulator from Cache
04:26:14.8 14/07/2011: Restoring Emulator Database From Cache
04:26:14.9 14/07/2011: Restoring Emulator from Cache
04:26:15.0 14/07/2011: Restoring Emulator Database From Cache
04:26:15.9 14/07/2011: Restoring Emulator from Cache
04:26:16.0 14/07/2011: Restoring Emulator Database From Cache
04:26:28.5 14/07/2011: Restoring Cached ICONS from File
04:26:36.1 14/07/2011: Running: cmd.exe /c K: "Future Pinball.exe" /open "K:\Emulation\Future Pinball\Tables\Pinball Fantasies - Partyland (Digital Illusions) (1992) (light86, SlipperyPenguin) (1.51).fpt" /play /exit
04:26:36.3 14/07/2011: Shutting down display
04:26:38.4 14/07/2011: Writing Stats
04:26:38.4 14/07/2011: Plugin: Game Exit
04:26:38.4 14/07/2011: Plugin: Process Commands
04:26:38.4 14/07/2011: Refreshing Keyboard
04:26:38.5 14/07/2011: Initialising Audio
04:26:38.6 14/07/2011: Relaunching HideOS
04:26:38.8 14/07/2011: Restoring Window
04:26:38.9 14/07/2011: Reinitializing Graphics System
04:26:40.7 14/07/2011: Reloading Game Info Page
04:26:41.4 14/07/2011: Returning to GameEx
04:26:44.9 14/07/2011: Exiting GameEx!
04:26:44.9 14/07/2011: Saving Settings
04:26:46.6 14/07/2011: Disposing Plugins
04:26:46.6 14/07/2011: Closing database connection
04:26:46.7 14/07/2011: Checking for applications to Launch On Exit
Thanks for looking!
post-4854-0-44025100-1310615205_thumb.jp
Hooray! I'm glad I posted, thanks Tom :)
(Please mark as resolved)
Done! The Topic Starter can also do this for future reference. ;)
