i'm trying to set up my ps1 emulator to run in gameex, but every time i try to play a rom the screen just goes black and it takes me back to the game description screen
i can use epsxe just fine outside of gameex
When it returns to GameEx, it could be a couple of things. The path to the roms are incorrect or the command-line is incorrect. Please export your config so we can have a look.
Most likely CL issue.I will have to look for the old epsxe line as I have switched to pSX
Im willing to bet it has to do with " where they are placed
Here is the command line I use for this emulator
epsxe.exe -nogui -slowboot -loadbin "[rompath]\[romfile]" -loadmemc0 "memcards\[rom]"
that made the rom run, but now it goes to a weird version of the black playstation logo and stops.
also, where do i find the config so i can post?
I would try the following:
Your memory card files would have to be in same location as R-DUB's for that to work.
To post a config, in Setup Wizard you go into the Emulator Selection section and click on the emulator. Then you click on the last button in the middle of the listviews with a note and an arrow pointing out. Hovering over the button will show Export Emulator(s). Then simply name the file and post it's contents in the forums by either just pasting the info or renaming as a text file since the forums won't accept ini files.
nope, it still does the same thing where it goes through the ps1 console intro to the black screen and then stops. (the sound finishes and then it loads forever)
My config:
[Emulator]
System=Sony Playstation
Category=Console
Emulator=ePSXe
Version=1.70
Rating=8.3
DownloadUrl=http://www.gamesdbase.com/setupwizard/emulators/download/epsxe.7z
RequiredFiles=scph1001.bin (512kb)
Website=http://www.epsxe.com/
Info=Sony Playstation Emulator
TitleText=Sony Playstation
StartPageName=Sony Playstation
StartPageLogo=Sony Playstation
Command=ePSXe.exe -nogui -slowboot -loadbin "[rompath]\[romfile]"
RomFilter=
Database=[Console] Sony Playstation
ConfigFile=[Mapping Off] Exit (Process Close)
MapFile=[Console] Sony Playstation.map
RomPath=C:\Roms\Sony Playstation\Roms
SnapPath=C:\Assets\Sony Playstation\Snaps
TitlePath=C:\Assets\Sony Playstation\Titles
BoxPath=C:\Assets\Sony Playstation\Boxes
CartPath=C:\Assets\Sony Playstation\Cartridges
ManualPath=C:\Assets\Sony Playstation\Manuals
ControlPanelPath=C:\Assets\Sony Playstation\Controls
WorkingPath=C:\Emulators\ePSXe
MapKeys=True
WaitBeforeKeys=
SendKeys=
ReplaceDash=False
ReplaceUnder=True
Capitals=False
RemoveBrackets=True
ShowDesktop=True
Debug=False
AlsoLaunch=
LaunchBefore=
LaunchAfter=
ExcludedFiles=
CustomBackground=
PlayMusic=False
DontShowInfo=
PlaySelectionMusic=False
SelectionMusicFolder=
PCGame=False
GamesIn7Zips=False
PlayInScreenSaver=False
ShowMostPlayed=True
RandomMostPlayed=True
CDCheck=False
CDCheckFile=
Bin/cue, many of them ripped with imgburn off of my own ps1 games
I'm in the chat room for real-time support if interested.
Do you have the PS1 bios?
Never mind, you have this running outside GameEX, so just a matter of getting the settings right.
ok nevermind i figured out the problem
if i use ISOs instead of bin/cue files then it works perfectly
now to get ssf working...
The command-line is picky with it's file types. To avoid making all new ISOS, I recommend using 3rd party software to mount the image. Daemon Tools Lite is what I would suggest unless you have another mounting app that you have.
