Hey all. For some reason when I load GameEx it takes about 30-35 seconds for the initial menu to come up after the startup logo and music play. It used to fire up in 5 seconds or less before. Any ideas what's causing the delay?
What does the log indicate?
Delays at startup are in my experience normally caused by GameEx trying to access remote or non existant drives, files or folders.
You really should know how to post properly by now. Slapped rist ;)
I know I figured it out by checking the log out. Something must have gone wonky since it's listing a bunch of paths as not found again. I'll poke further in. :)
PS: can't believe I didn't post my log. D'oh! Haha!
I can believe it! :P
Don't know what to make of the log, it's loading emus twice for some reason. the log file doesn't really reflect the delay except i backed out of GameEx as soon as it let me. here's the log anyway if anyone wants to look:
20:48:47.3 6/23/2011: Opening Configuration File
20:48:47.3 6/23/2011: GameEx: Version 11.82: Starting Log
20:48:47.3 6/23/2011: Operating System Platform: Win32NT
20:48:47.3 6/23/2011: Operating System Name: Windows XP
20:48:47.3 6/23/2011: Operating System Version: 5.1.2600
20:48:47.3 6/23/2011: Checking for versions of .net Framework installed
20:48:47.3 6/23/2011: .net Framework 1.0 Installed
20:48:47.3 6/23/2011: .net Framework 1.1 Installed
20:48:47.3 6/23/2011: .net Framework 2.0 Installed
20:48:47.3 6/23/2011: .net Framework 3.0 Installed
20:48:47.3 6/23/2011: .net Framework 3.5 Installed
20:48:47.3 6/23/2011: Intel® Core™2 CPU E7500 @ 2.93GHz, 2047MB
20:48:47.3 6/23/2011: 2.94Ghz - 2 Cores or CPU's
20:48:47.3 6/23/2011: Running Randomize()
20:48:47.4 6/23/2011: Loading PlugIns
20:48:47.4 6/23/2011: Loaded Plugin:"Launch" Version 1.0 By Ben Baker
20:48:47.4 6/23/2011: PlugIn: "Launch" Initialized OK
20:48:47.4 6/23/2011: Using Plugin System Version: 1.4
20:48:47.4 6/23/2011: Checking for applications to Launch On Startup
20:48:47.4 6/23/2011: Launching and waiting: F:\BatFiles\StartUpNoMM.bat
20:48:47.5 6/23/2011: Running Misc startup tasks
20:48:47.5 6/23/2011: Setting Menu types
20:48:47.5 6/23/2011: Getting Configuration Values
20:48:47.5 6/23/2011: Using Theme: BlueBox
20:48:47.5 6/23/2011: Checking for alternate Image Directory for Theme: BlueBox
20:48:47.5 6/23/2011: Launching GameExtender.exe (GameExtender Viewer)
20:48:48.1 6/23/2011: Launching HideOS.exe
20:48:48.1 6/23/2011: Initialising Video/MNG DLL's
20:48:48.2 6/23/2011: GameEx will check for media insertion (may affect performance)
20:48:48.2 6/23/2011: Hiding Taskbar
20:48:48.3 6/23/2011: Is Media Center running?
20:48:48.3 6/23/2011: Checking/Creating LCD Registry values
20:48:48.3 6/23/2011: Check Media Center Exit/Start Mode
20:48:48.3 6/23/2011: Media Center Mode 2
20:48:48.3 6/23/2011: Video previews on. Warning: Only recommended on modern systems
20:48:48.3 6/23/2011: Custom Keyboard Input enabled: Getting custom codes
20:48:48.3 6/23/2011: Advanced Custom Keyboard Input enabled: Getting custom codes
20:48:48.3 6/23/2011: Snap Delay set to: 2
20:48:48.3 6/23/2011: Get other settings
20:48:48.3 6/23/2011: Desktop set to Hide ICONS and set Background to Black
20:48:48.3 6/23/2011: Set: Find emulator artwork on best match basis
20:48:48.3 6/23/2011: Using DirectInput for keyboard input
20:48:48.3 6/23/2011: Start work for Form
20:48:48.3 6/23/2011: Getting Original Screen Size
20:48:48.3 6/23/2011: Opening Database Connection
20:48:48.4 6/23/2011: Initializing Component
20:48:48.5 6/23/2011: Retrieving resolution setting
20:48:48.5 6/23/2011: MAME Path is: D:\Emulators\MAME
20:48:48.5 6/23/2011: Client/Server MAME Path is: C:\MAMEHub\dist
20:48:48.5 6/23/2011: Client/Server MAME EXE file is: vmame.exe
20:48:48.5 6/23/2011: Use Client/Server MAME On. vmame.exe will launch NetPlay games
20:48:48.5 6/23/2011: Model 2 Path Path is: D:\Emulators\M2
20:48:48.5 6/23/2011: Multi Core/Hyper Threading detected. Looking for emulator_multicpu.exe
20:48:48.5 6/23/2011: Model 2 EXE file is: emulator_multicpu.exe
20:48:48.5 6/23/2011: Model 2 emulator with command line support detected
20:48:48.5 6/23/2011: Use Model 2 on. emulator_multicpu.exe will launch Sega Model 2 games
20:48:48.5 6/23/2011: MAME EXE file is: mame.exe
20:48:48.5 6/23/2011: ROM Path is: D:\Emulators\MAME\roms
20:48:48.5 6/23/2011: Catver.ini is located at: D:\Emulators\MAME\Catver.ini
20:48:48.5 6/23/2011: controls.ini is located at: D:\Emulators\MAME\controls.ini
20:48:48.5 6/23/2011: History.dat is located at: D:\Emulators\MAME\history.dat
20:48:48.5 6/23/2011: nplayers.ini is located at: D:\Emulators\MAME\nplayers.ini
20:48:48.5 6/23/2011: command.dat is located at: C:\GameEx\DATA\command.dat
20:48:48.5 6/23/2011: MAMEinfo.dat is located at: D:\Emulators\MAME\mameinfo.dat
20:48:48.5 6/23/2011: Loading Controls.ini map file
20:48:48.5 6/23/2011: Snap Path is: D:\Emulators\MAME\extras\snap
20:48:48.5 6/23/2011: AVI Snap Path is: D:\Emulators\MAME\extras\videos
20:48:48.5 6/23/2011: Flyer Path is: D:\Emulators\MAME\extras\flyers
20:48:48.5 6/23/2011: Cabinet Path is: D:\Emulators\MAME\extras\cabinets
20:48:48.5 6/23/2011: Cabinet 3D Path is: D:\Emulators\MAME\extras\cabinets3d
20:48:48.5 6/23/2011: Title Path is: D:\Emulators\MAME\extras\titles
20:48:48.5 6/23/2011: PCB Path is: D:\Emulators\MAME\extras\pcb
20:48:48.5 6/23/2011: Artwork Preview Path is: D:\Emulators\MAME\artworkgameex
20:48:48.5 6/23/2011: Panel Path is: D:\Emulators\MAME\extras\cpanel
20:48:48.5 6/23/2011: Manual Path is: D:\Emulators\MAME\extras\manuals
20:48:48.5 6/23/2011: Icon Path is: D:\Emulators\MAME\icons
20:48:48.5 6/23/2011: Marquee Path is: D:\Emulators\MAME\extras\marquees
20:48:48.6 6/23/2011: Loading Custom Emulators
20:48:48.6 6/23/2011: Loading Emulator 1: NINTENDO N64
20:48:48.6 6/23/2011: Loading Emulator 2: NINTENDO SNES
20:48:48.6 6/23/2011: Loading Emulator 3: NINTENDO NES
20:48:48.6 6/23/2011: Loading Emulator 4: NINTENDO GameBoy Advance
20:48:48.6 6/23/2011: Loading Emulator 5: NINTENDO GameBoy Color
20:48:48.6 6/23/2011: Loading Emulator 6: SEGA CD
20:48:48.6 6/23/2011: Loading Emulator 7: SEGA Genesis
20:48:48.6 6/23/2011: Loading Emulator 8: SEGA Master System
20:48:48.6 6/23/2011: Loading Emulator 9: SEGA Game Gear
20:48:48.6 6/23/2011: Loading Emulator 10: NEC TurboGrafx-16
20:48:48.6 6/23/2011: Loading Emulator 11: ATARI 2600
20:48:48.6 6/23/2011: Loading Emulator 12: ATARI 5200
20:48:48.6 6/23/2011: Loading Emulator 13: ATARI 7800
20:48:48.6 6/23/2011: Loading Emulator 14: COLECO Vision
20:48:48.6 6/23/2011: Loading Emulator 15: MATTEL Intellivision
20:48:48.6 6/23/2011: Loading Emulator 17: VISUAL PinMAME
20:48:48.6 6/23/2011: Loading Emulator 19: ATARI Lynx
20:48:48.6 6/23/2011: Loading Emulator 20: SONY Playstation
20:48:48.6 6/23/2011: Loading Emulator 21: SEGA Saturn
20:48:48.6 6/23/2011: Loading Emulator 22: NINTENDO Game Cube
20:48:48.7 6/23/2011: Loading Emulator 23: MICROSOFT Windows
20:48:48.7 6/23/2011: Loading Emulator 24: OPEN Beats Of Rage
20:48:48.7 6/23/2011: Loading Emulator 25: MICROSOFT Windows
20:48:48.7 6/23/2011: Loading Emulator 27: NINTENDO DS
20:48:48.7 6/23/2011: Loading Emulator 28: SEGA Dreamcast
20:48:48.7 6/23/2011: Loading Emulator 29: FUTURE Pinball
20:48:48.7 6/23/2011: Loading Emulator Group 1: MICROSOFT Windows
20:48:48.7 6/23/2011: Using Version 3 Themes Animations
20:48:48.7 6/23/2011: Using General Font: Tahoma
20:48:48.7 6/23/2011: Using Title Font: Tahoma
20:48:48.7 6/23/2011: Initialising Direct3D
20:48:48.7 6/23/2011: Applying GameEx is Loading Image
20:48:48.9 6/23/2011: Setting Resolution to 1680x1050 32 bit color
20:48:48.9 6/23/2011: Creating Surfaces
20:48:49.2 6/23/2011: Creating Primary Surface - Full Screen Mode
20:48:49.2 6/23/2011: Creating Back Buffer
20:48:49.3 6/23/2011: Version 2 Theme being used. Loading.
20:48:49.3 6/23/2011: Loading Button Data
20:48:49.3 6/23/2011: Loading Font Data
20:48:49.3 6/23/2011: Loading Layout Data
20:48:49.3 6/23/2011: Loading Taskbar Data
20:48:49.3 6/23/2011: Loading graphic Surfaces
20:48:49.3 6/23/2011: Display is running at: 1680x1050 32bit color, 60hz
20:48:49.4 6/23/2011: Creating Surfaces Misc and Dialogs
20:48:49.5 6/23/2011: Creating Surfaces Volume
20:48:49.5 6/23/2011: Creating Surfaces Arrows
20:48:49.5 6/23/2011: Creating Surfaces GameEXlogo Text
20:48:49.5 6/23/2011: Creating Surfaces Toolbar
20:48:49.5 6/23/2011: Creating Surfaces Backgrounds
20:48:49.5 6/23/2011: Creating Surfaces Toolbar Controls
20:48:49.6 6/23/2011: Creating Surfaces GameEx Logo
20:48:49.6 6/23/2011: Creating Surface Unselected
20:48:49.6 6/23/2011: Creating Surfaces Snaps
20:48:49.6 6/23/2011: Creating Surfaces Menu and List Bars
20:48:49.7 6/23/2011: Creating Fonts
20:48:49.7 6/23/2011: Creating Game Font
20:48:49.8 6/23/2011: Creating Game Font Faded
20:48:49.9 6/23/2011: Creating Title Font
20:48:50.0 6/23/2011: Restoring Title Font From Cache
20:48:50.2 6/23/2011: Creating Font Black
20:48:50.3 6/23/2011: Creating Font Black Small
20:48:50.4 6/23/2011: Fonts Created Succesfully
20:48:50.4 6/23/2011: 7MB Video Memory Used
20:48:50.4 6/23/2011: Initialising Bass Audio Library
20:48:50.4 6/23/2011: Creating instance of global keyboard hook
20:48:51.3 6/23/2011: Attempting to load game list
20:48:51.5 6/23/2011: Loading Custom Emulators
20:48:51.5 6/23/2011: Loading Emulator 1: NINTENDO N64
20:48:51.5 6/23/2011: Loading Emulator 2: NINTENDO SNES
20:48:51.5 6/23/2011: Loading Emulator 3: NINTENDO NES
20:48:51.5 6/23/2011: Loading Emulator 4: NINTENDO GameBoy Advance
20:48:51.5 6/23/2011: Loading Emulator 5: NINTENDO GameBoy Color
20:48:51.5 6/23/2011: Loading Emulator 6: SEGA CD
20:48:51.5 6/23/2011: Loading Emulator 7: SEGA Genesis
20:48:51.5 6/23/2011: Loading Emulator 8: SEGA Master System
20:48:51.5 6/23/2011: Loading Emulator 9: SEGA Game Gear
20:48:51.5 6/23/2011: Loading Emulator 10: NEC TurboGrafx-16
20:48:51.5 6/23/2011: Loading Emulator 11: ATARI 2600
20:48:51.5 6/23/2011: Loading Emulator 12: ATARI 5200
20:48:51.5 6/23/2011: Loading Emulator 13: ATARI 7800
20:48:51.5 6/23/2011: Loading Emulator 14: COLECO Vision
20:48:51.5 6/23/2011: Loading Emulator 15: MATTEL Intellivision
20:48:51.5 6/23/2011: Loading Emulator 17: VISUAL PinMAME
20:48:51.5 6/23/2011: Loading Emulator 19: ATARI Lynx
20:48:51.5 6/23/2011: Loading Emulator 20: SONY Playstation
20:48:51.5 6/23/2011: Loading Emulator 21: SEGA Saturn
20:48:51.5 6/23/2011: Loading Emulator 22: NINTENDO Game Cube
20:48:51.5 6/23/2011: Loading Emulator 23: MICROSOFT Windows
20:48:51.5 6/23/2011: Loading Emulator 24: OPEN Beats Of Rage
20:48:51.5 6/23/2011: Loading Emulator 25: MICROSOFT Windows
20:48:51.5 6/23/2011: Loading Emulator 27: NINTENDO DS
20:48:51.5 6/23/2011: Loading Emulator 28: SEGA Dreamcast
20:48:51.5 6/23/2011: Loading Emulator 29: FUTURE Pinball
20:48:51.6 6/23/2011: Loading Emulator Group 1: MICROSOFT Windows
20:48:51.6 6/23/2011: GameExtender Not found snap: D:\Images\no_img.png
20:48:51.6 6/23/2011: Starting GameExtender on: 192.168.1.151:8383
20:48:51.6 6/23/2011: GameExtender using specific custom images for systems.
20:48:51.6 6/23/2011: Applying Language/Text
20:48:51.6 6/23/2011: Text/Language: Custom
20:48:51.6 6/23/2011: MAME CMD options: -nowindow -joy -mt -video d3d -numscreens 2 -noka -cheat
20:48:51.6 6/23/2011: Loading last used Game List
20:48:51.6 6/23/2011: Creating DirectSound Device
20:48:51.7 6/23/2011: Trying: Primary Sound Driver
20:48:51.7 6/23/2011: Loading Sound Files
20:48:51.7 6/23/2011: DirectSound Device Created Successfully
20:48:51.7 6/23/2011: Gamepad/Joystick disabled
20:48:51.7 6/23/2011: Initialising DirectInput for Keyboard support
20:48:51.8 6/23/2011: Initializing MCE Remote
20:48:51.8 6/23/2011: Playing intro sound file
20:48:51.8 6/23/2011: Initialization OK! Starting GameEx!
20:48:51.8 6/23/2011: Testing Main Loop Once: Processing Frame
20:48:52.3 6/23/2011: Testing Main Loop Once: Main Loop ran successfully
20:49:49.0 6/23/2011: Exiting GameEx!
20:49:49.0 6/23/2011: Saving Settings
20:49:49.0 6/23/2011: Closing GameExtender Viewer
20:49:50.8 6/23/2011: Disposing Plugins
20:49:50.8 6/23/2011: Closing database connection
20:49:50.8 6/23/2011: Checking for applications to Launch On Exit
20:49:50.8 6/23/2011: Launching and waiting: F:\BatFiles\CloseNoMM.bat
20:49:50.9 6/23/2011: Media Center was not open when starting GameEx, so not launching
Here's the 60 second delay that caught my eye:
Any ideas as to what's causing this?
.:EDIT:. not even a big deal to me really, was just curious. It still goes plenty fast once the menu pops up, so IDK.
As always, thanks a big bunch Tom! :)
Still have the 60 second delay.
22:09:59.4 6/23/2011: Opening Configuration File
22:09:59.4 6/23/2011: GameEx: Version 11.83: Starting Log
22:09:59.4 6/23/2011: Operating System Platform: Win32NT
22:09:59.4 6/23/2011: Operating System Name: Windows XP
22:09:59.4 6/23/2011: Operating System Version: 5.1.2600
22:09:59.4 6/23/2011: Checking for versions of .net Framework installed
22:09:59.4 6/23/2011: .net Framework 1.0 Installed
22:09:59.4 6/23/2011: .net Framework 1.1 Installed
22:09:59.4 6/23/2011: .net Framework 2.0 Installed
22:09:59.4 6/23/2011: .net Framework 3.0 Installed
22:09:59.4 6/23/2011: .net Framework 3.5 Installed
22:09:59.4 6/23/2011: Intel® Core™2 CPU E7500 @ 2.93GHz, 2047MB
22:09:59.4 6/23/2011: 2.94Ghz - 2 Cores or CPU's
22:09:59.4 6/23/2011: Running Randomize()
22:09:59.5 6/23/2011: Loading PlugIns
22:09:59.5 6/23/2011: Loaded Plugin:"Launch" Version 1.0 By Ben Baker
22:09:59.5 6/23/2011: PlugIn: "Launch" Initialized OK
22:09:59.5 6/23/2011: Using Plugin System Version: 1.4
22:09:59.5 6/23/2011: Checking for applications to Launch On Startup
22:09:59.5 6/23/2011: Launching and waiting: F:\BatFiles\StartUpNoMM.bat
22:09:59.6 6/23/2011: Running Misc startup tasks
22:09:59.6 6/23/2011: Setting Menu types
22:09:59.6 6/23/2011: Getting Configuration Values
22:09:59.6 6/23/2011: Using Theme: BlueBox
22:09:59.6 6/23/2011: Checking for alternate Image Directory for Theme: BlueBox
22:09:59.6 6/23/2011: Launching GameExtender.exe (GameExtender Viewer)
22:10:00.2 6/23/2011: Launching HideOS.exe
22:10:00.2 6/23/2011: Initialising Video/MNG DLL's
22:10:00.3 6/23/2011: GameEx will check for media insertion (may affect performance)
22:10:00.3 6/23/2011: Hiding Taskbar
22:10:00.3 6/23/2011: Using Cabinet Friendly Control System
22:10:00.3 6/23/2011: Is Media Center running?
22:10:00.3 6/23/2011: Checking/Creating LCD Registry values
22:10:00.3 6/23/2011: Check Media Center Exit/Start Mode
22:10:00.3 6/23/2011: Media Center Mode 2
22:10:00.3 6/23/2011: Video previews on. Warning: Only recommended on modern systems
22:10:00.3 6/23/2011: Custom Keyboard Input enabled: Getting custom codes
22:10:00.3 6/23/2011: Advanced Custom Keyboard Input enabled: Getting custom codes
22:10:00.3 6/23/2011: Snap Delay set to: 2
22:10:00.3 6/23/2011: Get other settings
22:10:00.3 6/23/2011: Desktop set to Hide ICONS and set Background to Black
22:10:00.3 6/23/2011: Set: Find emulator artwork on best match basis
22:10:00.3 6/23/2011: Using DirectInput for keyboard input
22:10:00.3 6/23/2011: Start work for Form
22:10:00.3 6/23/2011: Getting Original Screen Size
22:10:00.3 6/23/2011: Opening Database Connection
22:10:00.4 6/23/2011: Initializing Component
22:10:00.5 6/23/2011: Retrieving resolution setting
22:10:00.5 6/23/2011: MAME Path is: D:\Emulators\MAME
22:10:00.5 6/23/2011: Client/Server MAME Path is: C:\MAMEHub\dist
22:10:00.5 6/23/2011: Client/Server MAME EXE file is: vmame.exe
22:10:00.5 6/23/2011: Use Client/Server MAME On. vmame.exe will launch NetPlay games
22:10:00.5 6/23/2011: Model 2 Path Path is: D:\Emulators\M2
22:10:00.5 6/23/2011: Multi Core/Hyper Threading detected. Looking for emulator_multicpu.exe
22:10:00.5 6/23/2011: Model 2 EXE file is: emulator_multicpu.exe
22:10:00.5 6/23/2011: Model 2 emulator with command line support detected
22:10:00.5 6/23/2011: Use Model 2 on. emulator_multicpu.exe will launch Sega Model 2 games
22:10:00.5 6/23/2011: MAME EXE file is: mame.exe
22:10:00.5 6/23/2011: ROM Path is: D:\Emulators\MAME\roms
22:10:00.5 6/23/2011: Catver.ini is located at: D:\Emulators\MAME\Catver.ini
22:10:00.5 6/23/2011: controls.ini is located at: D:\Emulators\MAME\controls.ini
22:10:00.5 6/23/2011: History.dat is located at: D:\Emulators\MAME\history.dat
22:10:00.5 6/23/2011: nplayers.ini is located at: D:\Emulators\MAME\nplayers.ini
22:10:00.5 6/23/2011: command.dat is located at: C:\GameEx\DATA\command.dat
22:10:00.5 6/23/2011: MAMEinfo.dat is located at: D:\Emulators\MAME\mameinfo.dat
22:10:00.5 6/23/2011: Loading Controls.ini map file
22:10:00.5 6/23/2011: Loading Custom Emulators
22:10:00.5 6/23/2011: Loading Emulator 1: NINTENDO N64
22:10:00.5 6/23/2011: Loading Emulator 2: NINTENDO SNES
22:10:00.5 6/23/2011: Loading Emulator 3: NINTENDO NES
22:10:00.5 6/23/2011: Loading Emulator 4: NINTENDO GameBoy Advance
22:10:00.5 6/23/2011: Loading Emulator 5: NINTENDO GameBoy Color
22:10:00.5 6/23/2011: Loading Emulator 6: SEGA CD
22:10:00.5 6/23/2011: Loading Emulator 7: SEGA Genesis
22:10:00.5 6/23/2011: Loading Emulator 8: SEGA Master System
22:10:00.6 6/23/2011: Loading Emulator 9: SEGA Game Gear
22:10:00.6 6/23/2011: Loading Emulator 10: NEC TurboGrafx-16
22:10:00.6 6/23/2011: Loading Emulator 11: ATARI 2600
22:10:00.6 6/23/2011: Loading Emulator 12: ATARI 5200
22:10:00.6 6/23/2011: Loading Emulator 13: ATARI 7800
22:10:00.6 6/23/2011: Loading Emulator 14: COLECO Vision
22:10:00.6 6/23/2011: Loading Emulator 15: MATTEL Intellivision
22:10:00.6 6/23/2011: Loading Emulator 17: VISUAL PinMAME
22:10:00.6 6/23/2011: Loading Emulator 19: ATARI Lynx
22:10:00.6 6/23/2011: Loading Emulator 20: SONY Playstation
22:10:00.6 6/23/2011: Loading Emulator 21: SEGA Saturn
22:10:00.6 6/23/2011: Loading Emulator 22: NINTENDO Game Cube
22:10:00.6 6/23/2011: Loading Emulator 23: MICROSOFT Windows
22:10:00.6 6/23/2011: Loading Emulator 24: OPEN Beats Of Rage
22:10:00.6 6/23/2011: Loading Emulator 25: MICROSOFT Windows
22:10:00.6 6/23/2011: Loading Emulator 27: NINTENDO DS
22:10:00.6 6/23/2011: Loading Emulator 28: SEGA Dreamcast
22:10:00.6 6/23/2011: Loading Emulator 29: FUTURE Pinball
22:10:00.6 6/23/2011: Loading Emulator Group 1: MICROSOFT Windows
22:10:00.6 6/23/2011: Snap Path is: D:\Emulators\MAME\extras\snap
22:10:00.6 6/23/2011: AVI Snap Path is: D:\Emulators\MAME\extras\videos
22:10:00.6 6/23/2011: Flyer Path is: D:\Emulators\MAME\extras\flyers
22:10:00.6 6/23/2011: Cabinet Path is: D:\Emulators\MAME\extras\cabinets
22:10:00.6 6/23/2011: Cabinet 3D Path is: D:\Emulators\MAME\extras\cabinets3d
22:10:00.6 6/23/2011: Title Path is: D:\Emulators\MAME\extras\titles
22:10:00.6 6/23/2011: PCB Path is: D:\Emulators\MAME\extras\pcb
22:10:00.6 6/23/2011: Artwork Preview Path is: D:\Emulators\MAME\artworkgameex
22:10:00.6 6/23/2011: Panel Path is: D:\Emulators\MAME\extras\cpanel
22:10:00.6 6/23/2011: Manual Path is: D:\Emulators\MAME\extras\manuals
22:10:00.6 6/23/2011: Icon Path is: D:\Emulators\MAME\icons
22:10:00.6 6/23/2011: Marquee Path is: D:\Emulators\MAME\extras\marquees
22:10:00.6 6/23/2011: Using Version 3 Themes Animations
22:10:00.6 6/23/2011: Using General Font: Tahoma
22:10:00.6 6/23/2011: Using Title Font: Tahoma
22:10:00.7 6/23/2011: Initialising Direct3D
22:10:00.7 6/23/2011: Applying GameEx is Loading Image
22:10:00.9 6/23/2011: Setting Resolution to 1680x1050 32 bit color
22:10:00.9 6/23/2011: Creating Surfaces
22:10:01.2 6/23/2011: Creating Primary Surface - Full Screen Mode
22:10:01.2 6/23/2011: Creating Back Buffer
22:10:01.2 6/23/2011: Version 2 Theme being used. Loading.
22:10:01.2 6/23/2011: Loading Button Data
22:10:01.2 6/23/2011: Loading Font Data
22:10:01.3 6/23/2011: Loading Layout Data
22:10:01.3 6/23/2011: Loading Taskbar Data
22:10:01.3 6/23/2011: Loading graphic Surfaces
22:10:01.3 6/23/2011: Display is running at: 1680x1050 32bit color, 60hz
22:10:01.4 6/23/2011: Creating Surfaces Misc and Dialogs
22:10:01.5 6/23/2011: Creating Surfaces Volume
22:10:01.5 6/23/2011: Creating Surfaces Arrows
22:10:01.5 6/23/2011: Creating Surfaces GameEXlogo Text
22:10:01.5 6/23/2011: Creating Surfaces Toolbar
22:10:01.5 6/23/2011: Creating Surfaces Backgrounds
22:10:01.5 6/23/2011: Creating Surfaces Toolbar Controls
22:10:01.5 6/23/2011: Creating Surfaces GameEx Logo
22:10:01.6 6/23/2011: Creating Surface Unselected
22:10:01.6 6/23/2011: Creating Surfaces Snaps
22:10:01.6 6/23/2011: Creating Surfaces Menu and List Bars
22:10:01.7 6/23/2011: Creating Fonts
22:10:01.7 6/23/2011: Creating Game Font
22:10:01.8 6/23/2011: Creating Game Font Faded
22:10:01.9 6/23/2011: Creating Title Font
22:10:01.9 6/23/2011: Restoring Title Font From Cache
22:10:02.2 6/23/2011: Creating Font Black
22:10:02.2 6/23/2011: Creating Font Black Small
22:10:02.3 6/23/2011: Fonts Created Succesfully
22:10:02.3 6/23/2011: 7MB Video Memory Used
22:10:02.3 6/23/2011: Initialising Bass Audio Library
22:10:02.3 6/23/2011: Creating instance of global keyboard hook
22:10:03.3 6/23/2011: Attempting to load game list
22:10:03.4 6/23/2011: GameExtender Not found snap: D:\Images\no_img.png
22:10:03.4 6/23/2011: Starting GameExtender on: 192.168.1.151:8383
22:10:03.4 6/23/2011: GameExtender using specific custom images for systems.
22:10:03.4 6/23/2011: Applying Language/Text
22:10:03.4 6/23/2011: Text/Language: Custom
22:10:03.5 6/23/2011: MAME CMD options: -nowindow -joy -mt -video d3d -numscreens 2 -noka -cheat
22:10:03.5 6/23/2011: Loading last used Game List
22:10:03.5 6/23/2011: Creating DirectSound Device
22:10:03.5 6/23/2011: Trying: Primary Sound Driver
22:10:03.5 6/23/2011: Loading Sound Files
22:10:03.5 6/23/2011: DirectSound Device Created Successfully
22:10:03.5 6/23/2011: Gamepad/Joystick disabled
22:10:03.5 6/23/2011: Initialising DirectInput for Keyboard support
22:10:03.7 6/23/2011: Initializing MCE Remote
22:10:03.7 6/23/2011: Playing intro sound file
22:10:03.7 6/23/2011: Initialization OK! Starting GameEx!
22:10:03.7 6/23/2011: Testing Main Loop Once: Processing Frame
22:10:04.2 6/23/2011: Testing Main Loop Once: Main Loop ran successfully
22:11:09.9 6/23/2011: Exiting GameEx!
22:11:09.9 6/23/2011: Saving Settings
22:11:09.9 6/23/2011: Closing GameExtender Viewer
22:11:11.8 6/23/2011: Disposing Plugins
22:11:11.8 6/23/2011: Closing database connection
22:11:11.8 6/23/2011: Checking for applications to Launch On Exit
22:11:11.8 6/23/2011: Launching and waiting: F:\BatFiles\CloseNoMM.bat
22:11:12.0 6/23/2011: Media Center was not open when starting GameEx, so not launching
Also just to mention it, setup wiz was complaining that it couldn't find eetupwizardsettings_en.xml so I ammended my setupwizard.xml with the _en and it worked. This delay is unusual though, no? I'll attach my ini too:
