hey guys im trying to set up Amiga CD32 so far i got it running outside of gameex. if i try to luanch through gameex winaue just loads a white screen with a disk that says work bench v 1.3 and the game never loads? if anyone here has amiga 32 setup can you post your .ini so i can see what im doing wrong.
thank you
Amiga CD32.txt
I don't see the image being mounted anywhere. Does the emulator support cue files? Sorry but I don't use this emulator and would have to download to verify. The reason I assume this is because in the emulator imports, it's showing that virtual clone drive is being used to mount the image.
thanks for your reply. yes this emulator will support .cue files and they work fine outside gameex. all my CD32 games are iso/cue format. i took out the virtual clone drive in the command line cause it didnt work plus i have never had luck getting emulators to work with the virtual clone drive.so i just use daemon tools as needed. although winuae seems to have an on board virtual drive so i dont need to use daemon tools.
Sorry for getting back to you so late! I was able to download this emulator and see how it works.
Please try the following command-line:
winuae.exe -f CD32.uae -G -s quickstart=cd32,0 -cdimage="[ROMPATH]\[ROMFILE]"
You can get rid of the WaitBeforeKeys and SendKeys settings also as this command-line will start it up automatically. Let me know how that works out for you.
@Frequency all your help is very much appreciated. The command line worked like a charm as far as getting the game running through gameex. the only problem im having now is getting the game to load in fullscreen. i tryed changing the display settings in the Winuae properties but everytime i close and re open winuae it goes back to windowed for some reason?
You have to load your CD32.uae config and then make the change and then save it again. It's also possible to make the change in command-line as well. But try through the config as it will make your command-line cleaner and also what a config is for. If you want real-time support I'll hang around in the chat room found in the link tab on top of forums for awhile.
I also changed the command-line to make it a little cleaner. The -G switch is the same as -s use_gui=no.
This issue is resolved!
Edited by Draco1962
This thread is marked as Resolved and is now closed. If the problem re-occurs, please start a new thread.
