RE:
Q: How do I not show Adult Games.
A: Under MAME Update settings, make sure to set No Adult games, under Enable/Disable turn off Show Adult games. Then update the list.
Maybe I'm blind, but I can't seem to find the MAME Update settings. Where can I find this menu? I want the Adult Games to show up but currently they are not.
Once I get all my emulators working under this I promise I'll donate! :)
Run GameEX config , then its under Advanced mame setting , Its the 7th one down on the first page then next page. NO Adult games. Gimme the porn .
Edit: sorry for being a halfwit, I just re read your post ,
check that you have hide update turned to no in Enable/disable features in config , and double check that your mame & roms set to the right path other wise update games dont show .
My Update games is on my main mame game list (yeah I know my roms are low I am just putting them back on my cab :) )
Edited by Pandemonium
