Hmm, not sure of the question, but will take a stab at the answer. I left mine in their folders (extracted them in my setup to C:\GameEx\Media\Xfiles\ and set the path accordingly in Advanced Configuration). Will probably move them to the Assets\Mame\ path eventually as I will start moving everything to my 1.5 TB secondary to free up room on my root drive.
Yeah, best to leave them in there folders. Either the console logos posted here or the 3d cabs.
thats what I figured.then whatever the folders name is you just put that in the logo line in advanced config,correct?
Yep! GameEx will match the 3D Cab folder name with the game name and, will default to the cab over marquees in the standard view.
I think we are not talking about the same thing.im talking about the 3d console models,not the 3d cabinets :)
Sorry about that, reading is fundemental, eh? B) Not sure as I don't use them but my guess would be that you would have to use the advanced configuration to utilize on of the Custom Art paths to point to the folder containing your 3D console folders for each emulator.
Jeeze... what did I miss now? I bury my head into some databases, and I find out that we also have 3d console artwork? I love the 3d Cabinets, where do I get the consoles from?
Also... anyone know where that rom deleter is that matches your 'do not display' list for MAME roms?
Thanks as always...
IMB
Check pinned topics for both. 3D console logos can be found on top and the tool can be found in the Pinned and Hot Topics sub-forum in Tempest's tools.
