[RESOLVED] DVD Playback does not work -> No codec...
Hello there,
I thought I am finished with the configuration with the new Gameex version, but when I tried the DVD playback, its not working...aahhgrrr...before everything was fine. What did I do :
1. Installed WMP 11
2. Installed Sharc Codeck Pack
3. Installed new gameex version
When I go into the setup wizard, I checked DVD playback, and then I have to choose the codec for MPEG 2, but I can not choose anything...I think this is also the reason why DVD playback is not working. Also when I start WMP, he tells me that there is no MPEG2 codec...but I installed the Shark codec pack, so what do I wrong ??
André
Does it work outside of GameEx? If so, please provide your log file. You may also want to go into the Advanced Configuration and make sure that VMR9 is enabled (Under Multimedia/HTPC) and save.
I'm willing to bet it doesn't work outside of GameEx if it doesn't work in WMP. I would try reinstalling the sharkpack as a means of eliminating that.
Hi,
No it also does not play via WMP. He tells me that a compatible DVD decoder is not installed...but as I wrote, I INSTALLED the new sharc codec pack...maybe I have to change settings in shark ??
Ok, after some tests, I think I foun the problem, but thats crazy :
I installed WMP11 and after the installation, I chose "Custom settings" and not "Express Settings", and that is a big difference !! After that, everything was working fine !! I do not understand the technical difference, but thats it...now everything is working...crazy !!
I have another thing regarding the microphone, but I will start a new thread for that...
Bye,
André
