Hello I'm having problems seting GameEX to read my rom folder. I get the no roms listed message
Setup:
Mame using= Mame32Plus current version.
Mame Path= D:\JOES ARCADE\MamePlus32
Mame Exe= mame32ip.exe
Mame Roms Path= G:\Arcade ROMS
Filters page in Config screen:
Filters= No filters added
Verify Roms= No
Only existing Roms= Yes
Use Game Filter= No
Only working Games= No
Don't filter these roms= *.zip since roms are zipped.
Everything else is set to yes. I want to show all game etc.
I have three harddrive and my roms are in my G: Drive. I have folder name setup this way G:\Arcade ROMS with roms in zip file. Thought when I load GamesEX it gose through startup screen just fine though when I go to click a game there are no games listed. Why?
Did I setup rom folder wrong? Is Mame32Plus the current version not compatible or something?
Has anyone here setup there Mame32Plus to work just fine with this great looking Frontend? If so please help me out any way you can. Thanks!
LegendaryGamer B)
Setup:
Verify Roms= No
Use Game Filter= No
LegendaryGamer B)
I'm pretty sure MAME32Plus works fine.
Might be a silly question, but have you seleced 'Update List' in GameEx. This needs to be done before any roms show. It can take upto 25 mins to run.
Silly Me! I got it before you replied. I forgot to hit the delete button to update list. Thanks!
I want you to know this is sweet stuff! I love your frontend compared to others I'm tried. I will be doing some donating to this fine work! :lol: I have some ideals also. I will send them soon. Keep up the great work! :)
