Tom,
still having random issues when trying to run games that are grouped together. For example:
1) I have Visual Pinball 8 and Visual Pinball 9 tables grouped together.
2) Both are setup as different emulators thou.
3) When you select a VP8 table (or VP9 table) sometimes it doesn't run and kicks back to GameEx
and will not run a VP8 table, but if you select a VP9 table it runs. Note that this happens
randomly as sometimes it doesn't happen at all when you run GameEx.
4) After it happens I looked at the log and it looks like it is corrupt for some reason. As it
doesn't point at the correct VP8 table that is why it crashes.
5) When you try to run a VP9 table after the crash it like fixes itself. So when you go back
and try to run a VP8 table it runs ok.
Very strange!
btw it also happens when I have D-Fend Reloaded (DOSBox) games and zDoom grouped together as well. So it's not just Visual Pinball causing it.
UPDATE!
Well I tested with 10.80 and 11.08 and both do seem to have the same issue, but it happens less with 10.80 than it does with 11.08.
Note: When running a emulator several times in a row is when you can get it to happen more often than not.
