I can't remember how to disable the GameEx logo when starting GameEx?
Been trying to re-config everything (slowly) after the fatal config crash :)
Maybe the following?
Enable/Disable Features >>> Skip Intro >>> YES
Been trying to re-config everything (slowly) after the fatal config crash smile.gif
Did you try your GameEx.UpgradeBackup.ini? Mine looks pretty close...
