This just randomly started happening about 4 months of operation.
When opening gameex on my cabinet, the menu immediately goes to shutdown as if the down key is being held. I checked the wiring to make sure it was ok, and I even unplugged EVERYTHING except for the monitor and restarted to see if that would fix it. Same thing happens (I used a remote desktop to test it).
I uninstalled and deleted all configurations for gameex and then reinstalled it. Same issue with a fresh install. This ONLY happens in gameex also. Opening any other program/game, no keys are stuck. I'm completely out of ideas ><. Any help would be greatly appreciated.
00:40:25.0 11/27/2009: GameEx: Version 10.28: Starting Log
00:40:25.0 11/27/2009: Operating System Platform: Win32NT
00:40:25.0 11/27/2009: Operating System Name: Windows XP
00:40:25.0 11/27/2009: Operating System Version: 5.1.2600
00:40:25.0 11/27/2009: Checking for versions of .net Framework installed
00:40:25.0 11/27/2009: .net Framework 2.0 Installed
00:40:25.0 11/27/2009: .net Framework 3.0 Installed
00:40:25.0 11/27/2009: Pentium® Dual-Core CPU E5200 @ 2.50GHz, 2046MB
00:40:25.0 11/27/2009: 3.75Ghz - 2 Cores or CPU's
00:40:25.0 11/27/2009: Running Randomize()
00:40:25.0 11/27/2009: Loading PlugIns
00:40:25.0 11/27/2009: Checking for applications to Launch On Startup
00:40:25.0 11/27/2009: Running Misc startup tasks
00:40:25.0 11/27/2009: Setting Menu types
00:40:25.0 11/27/2009: Opening Configuration File
00:40:25.0 11/27/2009: Getting Configuration Values
00:40:25.1 11/27/2009: Using Theme: Default - Media Center
00:40:25.1 11/27/2009: Checking for alternate Image Directory for Theme: Default - Media Center
00:40:25.1 11/27/2009: Using Images from theme: Default - Media Center V1\MEDIA\
00:40:25.1 11/27/2009: Initialising Video/MNG DLL's
00:40:25.1 11/27/2009: GameEx will check for media insertion (may affect performance)
00:40:25.1 11/27/2009: Is Media Center running?
00:40:25.1 11/27/2009: Checking/Creating LCD Registry values
00:40:25.1 11/27/2009: Check Media Center Exit/Start Mode
00:40:25.1 11/27/2009: Media Center Mode 2
00:40:25.1 11/27/2009: Video previews on. Warning: Only recommended on modern systems
00:40:25.1 11/27/2009: Snap Delay set to: 2
00:40:25.1 11/27/2009: Get other settings
00:40:25.1 11/27/2009: Desktop set to Hide ICONS and set Background to Black
00:40:25.1 11/27/2009: Set: Find emulator artwork on best match basis
00:40:25.1 11/27/2009: Start work for Form
00:40:25.1 11/27/2009: Getting Original Screen Size
00:40:25.1 11/27/2009: Opening Database Connection
00:40:25.2 11/27/2009: Initializing Component
00:40:25.2 11/27/2009: Retrieving resolution setting
00:40:25.2 11/27/2009: Initialising Windows Media Player Component
00:40:25.2 11/27/2009: MAME Path is: C:\Emulators\Mame32
00:40:25.2 11/27/2009: Cannot Find MAME Path: MAME Disabled
00:40:25.2 11/27/2009: Loading Controls.ini map file
00:40:25.2 11/27/2009: Loading Custom Emulators
00:40:25.3 11/27/2009: Using Version 3 Themes Animations
00:40:25.3 11/27/2009: Using General Font: Trebuchet MS
00:40:25.3 11/27/2009: Using Title Font: Trebuchet MS
00:40:25.3 11/27/2009: Initialising DirectDraw
00:40:25.3 11/27/2009: Applying GameEx is Loading Image
00:40:25.4 11/27/2009: Creating DirectDraw Device
00:40:25.4 11/27/2009: Using Device: Primary Display Driver
00:40:26.0 11/27/2009: 0mb video memory available
00:40:26.1 11/27/2009: Creating DirectDraw Surfaces
00:40:26.1 11/27/2009: Creating Primary Surface - Windowed Mode
00:40:26.1 11/27/2009: Creating Back Buffer
00:40:26.1 11/27/2009: Loading graphic Surfaces
00:40:26.1 11/27/2009: Display is running at: 1366x768 32bit color, 60hz
00:40:26.1 11/27/2009: Creating Surfaces Flags
00:40:26.1 11/27/2009: Creating Surfaces Misc and Dialogs
00:40:26.2 11/27/2009: Creating Surfaces Volume
00:40:26.2 11/27/2009: Creating Surfaces Arrows
00:40:26.2 11/27/2009: Creating Surfaces GameEXlogo Text
00:40:26.2 11/27/2009: Creating Surfaces Toolbar
00:40:26.3 11/27/2009: Creating Surfaces Backgrounds
00:40:26.8 11/27/2009: Creating Surfaces Toolbar Controls
00:40:26.8 11/27/2009: Creating Surfaces GameEx Logo
00:40:26.8 11/27/2009: Creating Surface Unselected
00:40:26.9 11/27/2009: Creating Surfaces Home & Exit
00:40:26.9 11/27/2009: Creating Surfaces Snaps
00:40:26.9 11/27/2009: Creating Surfaces Menu and List Bars
00:40:27.0 11/27/2009: Creating Fonts
00:40:27.0 11/27/2009: Creating Game Font
00:40:27.1 11/27/2009: Creating Game Font Faded
00:40:27.1 11/27/2009: Creating Title Font
00:40:27.1 11/27/2009: Restoring Title Font From Cache
00:40:27.6 11/27/2009: Creating Font Black
00:40:27.7 11/27/2009: Creating Font Black Small
00:40:27.7 11/27/2009: Fonts Created Succesfully
00:40:27.7 11/27/2009: 0mb video memory left available
00:40:27.7 11/27/2009: Creating instance of global keyboard hook
00:40:27.7 11/27/2009: Initialising Bass Audio Library
00:40:27.8 11/27/2009: Applying Language/Text
00:40:27.8 11/27/2009: Text/Language: English
00:40:27.8 11/27/2009: MAME CMD options: -nowindow -joy -skip_gameinfo
00:40:27.8 11/27/2009: Loading last used Game List
00:40:27.9 11/27/2009: Creating DirectSound Device
00:40:27.9 11/27/2009: Trying: Primary Sound Driver
00:40:27.9 11/27/2009: Loading Sound Files
00:40:27.9 11/27/2009: DirectSound Device Created Successfully
00:40:27.9 11/27/2009: Initialising DirectInput for Gamepad support
00:40:27.9 11/27/2009: Using Device PPJoy Virtual joystick 1
00:40:27.9 11/27/2009: Using Device PPJoy Virtual joystick 2
00:40:28.0 11/27/2009: Initializing MCE Remote
00:40:28.0 11/27/2009: Playing intro sound file
00:40:28.0 11/27/2009: Initialization OK! Starting GameEx!
00:40:28.0 11/27/2009: Testing Main Loop Once: Processing Frame
00:40:28.2 11/27/2009: Testing Main Loop Once: Main Loop ran successfully
00:40:54.9 11/27/2009: Exiting GameEx!
00:40:54.9 11/27/2009: Saving Settings
00:40:55.0 11/27/2009: Disposing Plugins
00:40:55.0 11/27/2009: Closing database connection
00:40:55.0 11/27/2009: Checking for applications to Launch On Exit
Wow I just uninstalled the ppjoy program and all is well again. Thats really wierd since they were working just fine for months. Thanks a ton, this problem was killing me!
If you disable the two PPJoy Virtual Joysticks do you still get the same problem?
Can you elaborate on why this suggestion works? I would of never thunk that.
Since there was some kind of "phantom" input occuring and he already tried unplugging hardware I thought it could be a joystick causing the problem. In the log file it shows the attached joysticks so then I suggested to disable them. I'm not exactly sure what would cause it but it's likely some sort of keypress is being interpreted as a joystick down, so re-installing and re-configuring PPJoy and making sure there is no keypress might solve the problem.
yes reinstalling ppjoy fixed the problem but I have no idea how it happened in the first place, very wierd. Thanks again for the help!
