Ok here is my ?
I have Dragon's Lair 1 & 2 and Space Ace CD package (I know it's not the best quality, but I bought the Dragon's Lair 20th Anniversary Collection CD for real cheap). Now I want to be able to run it in GameEx, but how should I go about doing this. I created an iso of the CD using Daemon Tools Lite but a little confused on how to set this up under GameEx as the iso image will autorun when mounted (not in fullscreen mode). So I know the iso works so I don't have to keep inserting the CD everytime.
Any ideas??
Ok here is my ?
Any ideas??
I bought these and Ive set these up before. You should just be able to install then copy the contents of each cd to the hdd. Create shortcuts to the executables, put them into a single folder. Then set that folder up as an emulator as you would normally for .lnk files/shortcuts. Send key F to get them full screen.
Oops got it to work this time put the folder in the wrong place. Had to put in the C: drive for it to work :)
Thanks Tom
