I was in a game and was modifying my game input controls...
thing is I messed up the controls...
basically I need to find the file so that I can change the inputs...but not in gameex running program.
Reason is, I have the ultimarc and when I press the button that allows me to use button 1 and button 7, etc...well it makes it go full screen instead of letting me use it as button 7...anyway!
long story short, I need the folder that has the values for each button press...so that I can remove the button assigned to fullscreen...THANKS!!!!
If you mean Mame then just go into Mame's cfg folder. You can edit/delete the [rom].cfg for a specific game or default.cfg for global settings.
Thanks!
I deleted the default config file in mame, restarted and it is all reset!
Awesome
