Hi all,
I just started playing with this so it might be a silly question: I'm remapping a few keys with a custom control ini file using the VKcodes.htm table. I need to remap the left shift and left alt key to something else but they are not in the VKcodes.htm file (only "shift" and "alt" but it doesnt seem to work). Anyone know where to get the code for these 2?
Thx
Domia
Hi all,
Thx
Domia
AHK can do it. What would you like them mapped to. Also do you want them permanently remapped?
Have you tried using the "Advanced Emulator Config" (aka Advanced Config Editor)? It allows you to enter keys from the keyboard instead of looking them up. It supports left and right shift/alt keys. It's in the GameEx menu under Configuration.
Thx Headkaze,
I tried the "advance Emulator Config" and I have one quick question: I wasn't able to remap the "Enter" key... when you click on remap the program waits for you to type the key but Enter is Cancel by default.
any idea?
Thx Dominique
PS: I realized what I wrote doesnt make much sense but if you try once you'll see
Hows this for service? Updated Advanced Config Editor :)
I have sent the update to Tom aswell so should be in the next release of GameEx.
That did it!
Thx a lot for your help
Domia
Hi Headkaze,
I've been using the Advance Config Editor and it solved 90% of my problems, I only have a mall issue with games not recognizing keys re-mapped to "left mouse button". The config works fine but it doesn't work in the game.. ever had that problem? (can you test on your side see if it works?)
Thx for the help,
Dominique
