I just added the Atari 7800 (pro system emulator) to my gameex. When it loads it is not giong to full screen? I was wondering what line code I use to get it that way? In the emulator itself you press ctrl f to go fullscreen. I would just like it to do so with out my keyboard. Thanks for any help.
You can make a send keys option in GameEx to make it send CTRL+F after a few seconds every time the emu launches.
According to the help file:
ProSystem Emulator Documentation
Command Line switches
The following list the command line switches allowed in ProSytem. If loading a rom file on the command line, it must be the last parameter in the list.
-Fullscreen value
Use value = 1 for fullscreen
Use value = 0 for windowed
-MenuEnabled value
Use value = 1 to enable the menu bar
Use value = 0 for no menu bar
-Palette filename
filename is the palette to use. If the name contains spaces, be sure to surround it with quotes
-Zoom value
Value can be 1 to 4 to increase the window size
-Mute value
Use value = 1 to mute the sound
Use value = 0 to enable sound
-Latency value
Set to desired Sound Latency
-SampleRate value
Set to desired Sound Sample Rate
-Region value
Use value = PAL for PAL
Use value = NTSC for NTSC
Use value = AUTO for Auto-Detect
Example
ProSystem -Fullscreen 0 -MenuEnabled 1 C:\centipede.a78
This will start ProSystem in windowed mode, with the menu bar enabled, and with C:\centipede.a78 as the rom to load.
So I would personally use the suggested command-line in GameEx. This will set the emulator fullscreen as well as hide the menubar.
ProSystem.exe -Fullscreen 1 -MenuEnabled 0 "[ROMPATH]\[ROMFILE]"
