Does MAMEUIFX work with the high scores feature in GameEx? I don't seem to see where it displays the high scores at? I know in MAMEUIFX it has high score support using the hiscore.dat but can't figure out how to get it to work with GameEx. I installed the HiToText and I don't see anything different or options in GameEx to view it.
Yeah there is a directory where it saves the hi-scores to with the filename .hi to under the MAMEUIFX directory
It should probably work then. You can see a full list of supported games in the HiToText thread and you can view the hiscore table from the Game Info page.
