hi, i just added snes roms to gameex and everything works fine when i start it but when i finish playing a game and hit esc to return to gameex i get an error, i added my logfile, anyone can help me? tyvm
20:44:56.6 4-7-2007: GameEx: Version 8.20: Starting Log
20:44:56.6 4-7-2007: Operating System Platform: Win32NT
20:44:56.6 4-7-2007: Operating System Name: Windows XP
20:44:56.6 4-7-2007: Operating System Version: 5.1.2600
20:44:56.6 4-7-2007: Checking for versions of .net Framework installed
20:44:56.6 4-7-2007: .net Framework 2.0 Installed
20:44:56.6 4-7-2007: Intel® Pentium® 4 CPU 2.66GHz
20:44:56.6 4-7-2007: 2,67Ghz
20:44:56.6 4-7-2007: Running Randomize()
20:44:56.6 4-7-2007: Loading PlugIns
20:44:56.7 4-7-2007: Checking for applications to Launch On Startup
20:44:56.7 4-7-2007: Running Misc startup tasks
20:44:56.7 4-7-2007: Setting Menu types
20:44:56.7 4-7-2007: Opening Configuration File
20:44:56.7 4-7-2007: Getting Configuration Values
20:44:56.7 4-7-2007: Using Theme: Acidbrain Vision
20:44:56.7 4-7-2007: Checking for alternate Image Directory for Theme: Acidbrain Vision
20:44:56.7 4-7-2007: Launching HideOS.exe
20:44:56.7 4-7-2007: Initialising Video/MNG DLL's
20:44:56.7 4-7-2007: Hiding Taskbar
20:44:56.7 4-7-2007: Is Media Center running?
20:44:56.7 4-7-2007: Checking/Creating LCD Registry values
20:44:56.7 4-7-2007: Check Media Center Exit/Start Mode
20:44:56.7 4-7-2007: Media Center Mode 2
20:44:56.7 4-7-2007: Video previews on. Warning: Only recommended on modern systems
20:44:56.7 4-7-2007: Snap Delay set to: 2
20:44:56.7 4-7-2007: Get other settings
20:44:56.7 4-7-2007: Set: Find emulator artwork on best match basis
20:44:56.8 4-7-2007: Start work for Form
20:44:56.8 4-7-2007: Getting Original Screen Size
20:44:56.8 4-7-2007: Opening Database Connection
20:44:57.0 4-7-2007: Initializing Component
20:44:57.0 4-7-2007: Creating Radio Station Genres
20:44:57.1 4-7-2007: Succesfully created station genres
20:44:57.1 4-7-2007: MAME Path is: C:\Emulators\Mame32
20:44:57.1 4-7-2007: daphne Path is: C:\Emulators\Daphne
20:44:57.1 4-7-2007: daphne EXE file is: Daphne.exe
20:44:57.1 4-7-2007: Use daphne on. Daphne.exe will launch games
20:44:57.1 4-7-2007: MAME EXE file is: Mame32.exe
20:44:57.1 4-7-2007: ROM Path is: D:\mame\roms
20:44:57.1 4-7-2007: Catver.ini is located at: C:\Program Files\GameEx\DATA\catver.ini
20:44:57.1 4-7-2007: controls.ini is located at: C:\Program Files\GameEx\data\controls.ini
20:44:57.1 4-7-2007: History.dat is located at: C:\Program Files\GameEx\DATA\history.dat
20:44:57.1 4-7-2007: nplayers.ini is located at: C:\Program Files\GameEx\DATA\nplayers.ini
20:44:57.1 4-7-2007: MAMEinfo.dat is located at: C:\Program Files\GameEx\DATA\mameinfo.dat
20:44:57.1 4-7-2007: Loading Controls.ini map file
20:44:57.2 4-7-2007: Snap Path is: D:\mame\snap
20:44:57.2 4-7-2007: AVI Snap Path is: C:\Emulators\Mame32\avisnap
20:44:57.2 4-7-2007: Flyer Path is: D:\mame\flyers
20:44:57.2 4-7-2007: Cabinet Path is: D:\mame\cabinets
20:44:57.2 4-7-2007: Title Path is: D:\mame\titles
20:44:57.2 4-7-2007: Panel Path is: D:\mame\cpanel
20:44:57.2 4-7-2007: Manual Path is: D:\mame\manuals
20:44:57.2 4-7-2007: Icon Path is: D:\mame\mamuicons
20:44:57.2 4-7-2007: Marquee Path is: D:\mame\marquees
20:44:57.2 4-7-2007: Loading Custom Emulators
20:44:57.2 4-7-2007: Loading Emulator 1: Nintendo 64 Games
20:44:57.2 4-7-2007: Loading Emulator 2: Nintendo SNES games
20:44:57.3 4-7-2007: Loading Emulator 3: Nintendo NES Games
20:44:57.4 4-7-2007: Using 2D Animations
20:44:57.4 4-7-2007: Using General Font: Trebuchet MS
20:44:57.4 4-7-2007: Using Title Font: Trebuchet MS
20:44:57.4 4-7-2007: MAME CMD options: -triplebuffer -nowindow -joy
20:44:57.4 4-7-2007: Attempting to load game list
20:44:57.5 4-7-2007: Initialising DirectDraw
20:44:57.6 4-7-2007: Applying GameEx is Loading Image
20:44:57.6 4-7-2007: Creating DirectDraw Device
20:44:57.6 4-7-2007: Using Device: Primair beeldschermstuurprogramma
20:44:57.6 4-7-2007: 242mb video memory available
20:44:57.7 4-7-2007: Setting Resolution to 800x600 32 bit color
20:44:57.7 4-7-2007: Creating DirectDraw Surfaces
20:44:57.7 4-7-2007: Creating Primary Surface - Full Screen Mode
20:44:57.7 4-7-2007: Creating Back Buffer
20:44:57.7 4-7-2007: Version 2 Theme being used. Loading.
20:44:57.7 4-7-2007: Loading Button Data
20:44:57.8 4-7-2007: Loading Font Data
20:44:57.8 4-7-2007: Loading Layout Data
20:44:57.8 4-7-2007: Loading Taskbar Data
20:44:57.8 4-7-2007: Loading graphic Surfaces
20:44:57.8 4-7-2007: Creating Surfaces Misc and Dialogs
20:44:57.9 4-7-2007: Creating Surfaces Volume
20:44:57.9 4-7-2007: Creating Surfaces Arrows
20:44:57.9 4-7-2007: Creating Surfaces GameEXlogo Text
20:44:57.9 4-7-2007: Creating Surfaces Toolbar
20:44:58.0 4-7-2007: Creating Surfaces Backgrounds
20:44:58.1 4-7-2007: Creating Surfaces Toolbar Controls
20:44:58.2 4-7-2007: Creating Surfaces GameEx Logo
20:44:58.2 4-7-2007: Creating Surfaces Home & Exit
20:44:58.2 4-7-2007: Creating Surfaces Snaps
20:44:58.2 4-7-2007: Creating Surfaces Menu and List Bars
20:44:58.2 4-7-2007: Creating Fonts
20:44:58.2 4-7-2007: Creating Menu Font
20:44:58.3 4-7-2007: Restoring Menu Font From Cache
20:44:58.3 4-7-2007: Creating Game Font
20:44:58.4 4-7-2007: Creating Font Black
20:44:58.6 4-7-2007: Creating Font Black Small
20:44:58.7 4-7-2007: Creating Game Font Faded
20:44:58.8 4-7-2007: Creating Title Font
20:44:58.8 4-7-2007: Restoring Title Font From Cache
20:44:58.9 4-7-2007: Fonts Created Succesfully
20:44:58.9 4-7-2007: 221mb video memory left available
20:44:58.9 4-7-2007: Creating instance of global keyboard hook
20:44:58.9 4-7-2007: Starting GameExtender Publisher
20:44:58.9 4-7-2007: Text/Language: English
20:44:58.9 4-7-2007: Applying Language/Text
20:44:59.0 4-7-2007: Initialising Bass Audio Library
20:44:59.1 4-7-2007: Loading last used Game List
20:44:59.1 4-7-2007: Setting Music Volume
20:44:59.1 4-7-2007: Cannot Load Play List. Check Path and filename
20:44:59.1 4-7-2007: Creating DirectSound Device
20:44:59.1 4-7-2007: Trying: Primair geluidsstuurprogramma
20:44:59.1 4-7-2007: Loading Sound Files
20:44:59.2 4-7-2007: DirectSound Device Created Successfully
20:44:59.2 4-7-2007: Creating ICONS
20:44:59.2 4-7-2007: Restoring Cached ICONS from File
20:44:59.4 4-7-2007: Initialising DirectInput for Gamepad support
20:44:59.5 4-7-2007: Unable to create a joystick device
20:44:59.5 4-7-2007: Playing intro sound file
20:44:59.5 4-7-2007: Initializing MCE Remote
20:44:59.5 4-7-2007: Initialization OK! Starting GameEx!
20:44:59.5 4-7-2007: Testing Main Loop Once: Processing Frame
20:44:59.9 4-7-2007: Testing Main Loop Once: Main Loop ran successfully
20:45:09.6 4-7-2007: Error: One or more theme objects were outside the bounds of the resolution
20:45:09.9 4-7-2007: Validating: Emulator_1: Custom Background: D:\Nintendo 64\snaps
20:45:09.9 4-7-2007: Warning: Emulator_1: Custom Background Does not exist
20:45:09.9 4-7-2007: Validating: Emulator_1: Snap Path: D:\Nintendo 64\snaps
20:45:09.9 4-7-2007: Validating: Emulator_1: Database: N64
20:45:09.9 4-7-2007: Validating: Emulator_1: Title Snap Path: D:\Nintendo 64\titles
20:45:09.9 4-7-2007: Validating: Emulator_1: Box Art Path: D:\Nintendo 64\box
20:45:09.9 4-7-2007: Validating: Emulator_1: Cart Art Path: D:\Nintendo 64\carts
20:45:09.9 4-7-2007: Validating: Emulator_1: Manual Path:
20:45:09.9 4-7-2007: Warning: Emulator_1: Manual Path Does not exist
20:45:09.9 4-7-2007: Loading OfflineList Dat File for emulator: 1
20:45:09.9 4-7-2007: Cannot Find Offline List Dat File
20:45:09.9 4-7-2007: Validating: Emulator_2: Custom Background:
20:45:09.9 4-7-2007: Warning: Emulator_2: Custom Background Does not exist
20:45:09.9 4-7-2007: Validating: Emulator_2: Snap Path:
20:45:09.9 4-7-2007: Warning: Emulator_2: Snap Path Does not exist
20:45:09.9 4-7-2007: Validating: Emulator_2: Database:
20:45:09.9 4-7-2007: Warning: Emulator_2: Database Does not exist
20:45:09.9 4-7-2007: Validating: Emulator_2: Title Snap Path:
20:45:09.9 4-7-2007: Warning: Emulator_2: Title Snap Path Does not exist
20:45:09.9 4-7-2007: Validating: Emulator_2: Box Art Path:
20:45:09.9 4-7-2007: Warning: Emulator_2: Box Art Path Does not exist
20:45:09.9 4-7-2007: Validating: Emulator_2: Cart Art Path:
20:45:09.9 4-7-2007: Warning: Emulator_2: Cart Art Path Does not exist
20:45:09.9 4-7-2007: Validating: Emulator_2: Manual Path:
20:45:09.9 4-7-2007: Warning: Emulator_2: Manual Path Does not exist
20:45:09.9 4-7-2007: Validating: Emulator_3: Custom Background:
20:45:09.9 4-7-2007: Warning: Emulator_3: Custom Background Does not exist
20:45:09.9 4-7-2007: Validating: Emulator_3: Snap Path:
20:45:09.9 4-7-2007: Warning: Emulator_3: Snap Path Does not exist
20:45:09.9 4-7-2007: Validating: Emulator_3: Database:
20:45:09.9 4-7-2007: Warning: Emulator_3: Database Does not exist
20:45:09.9 4-7-2007: Validating: Emulator_3: Title Snap Path:
20:45:09.9 4-7-2007: Warning: Emulator_3: Title Snap Path Does not exist
20:45:09.9 4-7-2007: Validating: Emulator_3: Box Art Path:
20:45:09.9 4-7-2007: Warning: Emulator_3: Box Art Path Does not exist
20:45:09.9 4-7-2007: Validating: Emulator_3: Cart Art Path:
20:45:09.9 4-7-2007: Warning: Emulator_3: Cart Art Path Does not exist
20:45:09.9 4-7-2007: Validating: Emulator_3: Manual Path:
20:45:09.9 4-7-2007: Warning: Emulator_3: Manual Path Does not exist
20:45:13.1 4-7-2007: Running: cmd.exe /c C: zsnesw.exe "D:\super nintendo\2020 Super Baseball (U).smc"
20:45:24.9 4-7-2007: Escape Pressed, exiting emulator
20:45:28.3 4-7-2007: 21 Consecutive Exceptions Occured: Exiting
20:45:28.3 4-7-2007: Closing database connection
20:45:28.3 4-7-2007: First Exception:
20:45:28.3 4-7-2007: Argument 'Number' is not a valid value.
20:45:28.3 4-7-2007: at Microsoft.VisualBasic.ErrObject.Raise(Int32 Number, Object Source, Object Description, Object HelpFile, Object HelpContext)
20:45:28.3 4-7-2007: at GameEx.GameEx.mainform.GetRectFromString(String rectstring, Double RatioX, Double RatioY, Boolean keepaspect)
20:45:28.3 4-7-2007: at GameEx.GameEx.mainform.LoadV2Theme(Int32 TargetWidth, Int32 TargetHeight, Boolean DoLog, Boolean JustLayout)
20:45:28.3 4-7-2007: at GameEx.GameEx.mainform.InitDirectDraw(Boolean FullScreenWindowed, Boolean nodispose, Boolean reinit, Boolean DontLoadSurfaces, Boolean SetSizingX, Int32 RefreshRate)
20:45:28.3 4-7-2007: at GameEx.GameEx.mainform.ReInitDDraw(Boolean NoDispose, Boolean DontLoadSurfaces, Boolean SetSizingX)
20:45:28.3 4-7-2007: at GameEx.GameEx.mainform.LaunchEmu(Boolean LaunchedFromAttract)
20:45:28.3 4-7-2007: at GameEx.GameEx.mainform.processgamemenu()
20:45:28.3 4-7-2007: at GameEx.GameEx.mainform.DisplayFrame()
20:45:28.3 4-7-2007: Last Exception:
20:45:28.3 4-7-2007: Object reference not set to an instance of an object.
20:45:28.3 4-7-2007: at Microsoft.DirectX.DirectDraw.Surface.get_SurfaceDescription()
20:45:28.3 4-7-2007: at GameEx.GameEx.mainform.DrawBackground()
Im not sure why its happing when your exiting zsnes, but this error is being caused by what seems to be an invalid theme configuration file. Are you using custom layouts for ZSNES?
  • 5 years later...
this happening to me too just when I am about to use Mustarda-Big(1024x768) theme and run zsnes I get the IDirect Draw crash error. so when I set it back to the main defualt theme the zsnes run fine with no error. so I thought maybe have to do with custom setting of zsnes and the theme but I was wrong :( so Im stuck with the default setting its there something in the theme.ini cause the zsnes to crash like that ? also I am using the lastest game ex 12.98
Hi JCGamer!
Would you mind posting a copy of your emulator config for ZSNES, and a copy of your log after having experienced this error? Here's a brief tutorial regarding how to access that information. While it may appear to be the same issue reported by the OP (clear back in 2007!), there's a good chance that this may be a different problem. The information provided in those files will give our troubleshooters a much better indication of what's going on with your setup.
Thank you!
Hi JCGamer!
Thank you!
well this is very very wierd I dont know what had happend but I must of did something to the setting but I went to activate the game ex with Mustarda-Big(1024x768) theme and then I run the zsnes emulator for hoping to get the same error to show you but all the suddin I did not give me no error. its weird I might done something to the program now Im not getting no error. this very very wierd and comfusing. but its runing okay for now. if I encounter this probelm agian I follow that guide and share the log file of the cuase of this error I had, so for right now its runing okay o.o *jc confused and puzzled*
