Iv been trying to use the theme 'Default - BlueEx - MCE1024x768' for some time now, but...
when i try it goes to the error screen, and at the bottom it tells me that...
01:44:26.5 20/12/2006: Error: 5 - Font 'Joystix' doesn't support style 'Bold'.
01:44:26.5 20/12/2006: ERRORS DETECTED: EXITING
which is a pain, because i dont understand the point in the font being pre-installed and the theme that comes with it not being able to use the font properly?!?!
can anyone please help me on this matter?
thank you
thank you
I have no clue. Maybe just manually change the font via. theme editor.
What type of joystick??
Go to you "GameEx\Themes\Default - BlueEx - MCE1024x768" folder and open up theme.ini in Notepad.
You will see this:
[GENERAL]
ArcadeMode=False
XResolution=1024
YResolution=768
DisplayBackgroundImage=True
DialogTextWhite=True
TitleFont=Joystix
Replace Joystix with Arial or some other font that you like that has support for... eh.. being bold. Save. Start GameEx.
Emph
