Hello,
 I'm having an issue all of a sudden I have the newest 32 bit PinballX  installed and the frontend once loaded will work around 10 seconds then screens go black..sometimes comes back and sometimes goes to desktop, or even restarts PC..Just trying to track the problem down if someone can help I would appreciate it.
log.txt PinballX.ini
I did not download LAV codecs...I have no idea what they are or what they do..Can you please tell me where to find and what they do..Thanks for your reply BTW.
I did not have luck with 64 either, that is why is went to 32, thought that might help...and it was a fresh install.
