Hey thanks for reading. So im trying to mod a table, i still need to ask for permision, but to start, i was making a test, and althoug  im not a photoshop expert, i can do simple stuff like removing backgrounds and more. So i loaded a png file , mod it with my logo, and as soon as i place it, it becomes all pixelated.  I know its a small file, but the files that im trying to mod, look blured but not pixelated. ill welcome any advice. Thanks for your help.
Not sure, but i think you're trying to scale down a larger image to 128*32?
I don't think there's an easy way to downscale an image to 128*30 with good results every time, it will depend on the source image. Most of the time you'll probably end up having to manually edit pixels to make it look 'ok'. Losing details is inevitable at that res.
You could try changing the resampling type used when downscaling (i'm not a photoshop user so don't know where that dialog is), or try scaling down in 3 or 4 steps reducing the res each time which can produce different results.
