1. I'm running FX3 in desktop mode with one monitor. What should I be putting in the parameter field for FX3? I copied the one from VPX but obviously that doesn't work. I have the tables in the wheel but can't launch them from pbx b/c of the parameter.
2. Does the built in record function also record FX3 tables? Anything special I need to get that working other than getting the tables to come up in the front end using a db file? How do we set it up so the tables just load? I'm assuming that would be driven by the parameter?
1) FX3 parameters only works for cabinet mode. In desktop mode you can use the grid positions. I never used it, but that should do the trick
2) Yes build in records works (for me), but it cannot load a table in desktop mode
not sure what you mean by the 'grid positions'? where is this?
Within gamemanager (but also in Database manager), there is a grid position select box.
This means (as I understand it right), the position in the fx3 menu where that game is.
So 1x1 takes the first game and with sendkeys PinballX will navigate to it.
Not sure, but thought in the manual of Database manager there is a link to thread (and small explanation)
Sorry, thats all I have, because running my version in cabinet mode(its free, just get the activation from zen studios)
