hI gUYS
Not really sure if i should be asking this here but as i wanna switch to pBX here goes,
Im currently using PinUp popper ( new cabinet from a mate ) but i wanna change to pinballx as thats what im used to and support is loads better ( ive asked questions weeks ago about pop up and no answers! ) , my question is if i change to pbx will all my force feedback stuff work? as its controlled via visual pinball. i have solenoids, a shaker, a gear motor, sound system that has the datum pucks flashing beacons but no lights, also the ball launcher and nudge is on pin scape i believe, and i have a stern DMD. Will everything work if i switch or am i gonna have a night mare trying to set it all up? Will i just to be able to point pbx to my visual set and the direct outout will work up or do i need to alter the direct output files? if i do then there is no way as im hopeless at that, unless somebody is willing to remote in and set me up.
Your thought and advise welcome.
Direct answer, is I can see no reason why not.
A proper answer is just run both at the same time and see how it goes which kind of answers your question in that it all should be independent of the front end.
Of course take an image of your drive first as nobody wants to be responsible for you screwing up your shit!
  • Thanks 1
Thanks Tom, yes i suppose that would be the best idea,i can make a clone copy on a spare drive and then just like you say run side by side. Thanks. I kinda thought it would as the mechanical devices fire up before windows actually loads so it makes sense. I'm so much more at home with PBX which is why i want to change, and the support is so much better.
