Hi All,
I'm a new registered User.
I'm been playing with Mame32 Plus! with no issue at all.
I've registered to this great frontend and after installation WIZARD, Gameex started without any problem.
However when going into Mame game (All games) here is the error...
This one is redundant with any other selections (Horizontal Games, Originals Games, ...)
It seems related to DIRECTX:
18:54:57.5 21/10/2006: GameEx: Version 7.01: Starting Log
18:54:57.5 21/10/2006: Operating System Platform: Win32NT
18:54:57.5 21/10/2006: Operating System Name: Windows XP
18:54:57.5 21/10/2006: Operating System Version: 5.1.2600
18:54:57.5 21/10/2006: Checking for versions of .net Framework installed
18:54:57.5 21/10/2006: .net Framework 1.1 Installed
18:54:57.5 21/10/2006: .net Framework 2.0 Installed
18:54:57.5 21/10/2006: AMD Athlon 64 Processor 3200+
18:54:57.5 21/10/2006: 2Ghz
18:54:57.5 21/10/2006: Running Randomize()
18:54:57.5 21/10/2006: Checking for applications to Launch On Startup
18:54:57.5 21/10/2006: Initialising Video/MNG DLL's
18:54:57.5 21/10/2006: Running Misc startup tasks
18:54:57.5 21/10/2006: Setting Menu types
18:54:57.5 21/10/2006: Opening Configuration File
18:54:57.5 21/10/2006: Getting Configuration Values
18:54:57.5 21/10/2006: Using Theme: Default - Future Retro
18:54:57.5 21/10/2006: Checking for alternate Image Directory for Theme: Default - Future Retro
18:54:57.5 21/10/2006: Launching HideOS.exe
18:54:57.5 21/10/2006: Hiding Taskbar
18:54:57.5 21/10/2006: Is Media Center running?
18:54:57.5 21/10/2006: Checking/Creating LCD Registry values
18:54:57.5 21/10/2006: Check Media Center Exit/Start Mode
18:54:57.5 21/10/2006: Media Center Mode 2
18:54:57.5 21/10/2006: Text/Language: English
18:54:57.5 21/10/2006: Applying Language/Text
18:54:57.6 21/10/2006: Custom Keyboard Input enabled: Getting custom codes
18:54:57.7 21/10/2006: Snap Delay set to: 2
18:54:57.7 21/10/2006: Get other settings
18:54:57.7 21/10/2006: Set: Find emulator artwork on best match basis
18:54:57.7 21/10/2006: SlikStik support enabled
18:54:57.7 21/10/2006: Using DirectInput for keyboard input
18:54:57.7 21/10/2006: Start work for Form
18:54:57.7 21/10/2006: Getting Original Screen Size
18:54:57.7 21/10/2006: Loading ICON
18:54:57.7 21/10/2006: Initializing Component
18:54:57.7 21/10/2006: Initialising Bass Audio Library
18:54:57.8 21/10/2006: Loading default loading screen
18:54:57.8 21/10/2006: Loading Custom Emulators
18:54:57.9 21/10/2006: Using 3D Alpha Blended Animations. This could be slow
18:54:57.9 21/10/2006: Using General Font: Trebuchet MS
18:54:57.9 21/10/2006: Using Title Font: Alien League
18:54:57.9 21/10/2006: Starting GameExtender Publisher
18:54:57.9 21/10/2006: Initialising DirectDraw
18:54:57.9 21/10/2006: Creating DirectDraw Device
18:54:57.9 21/10/2006: Using Device: Ultimarc ArcadeVGA
18:54:58.0 21/10/2006: Setting Resolution to 640x480 32 bit color
18:54:58.0 21/10/2006: Creating DirectDraw Surfaces
18:54:58.0 21/10/2006: Creating Primary Surface - Full Screen Mode
18:54:58.0 21/10/2006: Creating Back Buffer
18:54:58.0 21/10/2006: Version 2 Theme being used. Loading.
18:54:58.0 21/10/2006: Loading Button Data
18:54:58.0 21/10/2006: Loading Font Data
18:54:58.0 21/10/2006: Loading Layout Data
18:54:58.0 21/10/2006: Loading Taskbar Data
18:54:58.0 21/10/2006: Loading graphic surfaces
18:54:58.1 21/10/2006: Creating Surfaces Misc and Dialogs
18:54:58.1 21/10/2006: Creating Surface Volume
18:54:58.1 21/10/2006: Creating Surfaces Arrows
18:54:58.1 21/10/2006: Creating Surfaces GameEXlogo Text
18:54:58.1 21/10/2006: Creating Surfaces Toolbar
18:54:58.1 21/10/2006: Creating Surfaces Backgrounds
18:54:58.2 21/10/2006: Creating Surfaces Toolbar Controls
18:54:58.2 21/10/2006: Creating Surfaces GameEx Logo
18:54:58.2 21/10/2006: Creating Surfaces Home & Exit
18:54:58.2 21/10/2006: Creating Surfaces Snaps
18:54:58.2 21/10/2006: Creating Surfaces Menu and List Bars
18:54:58.3 21/10/2006: Creating Fonts
18:54:58.3 21/10/2006: Creating Menu Font
18:54:58.3 21/10/2006: Creating Game Font
18:54:58.4 21/10/2006: Creating Font Black
18:54:58.5 21/10/2006: Creating Font Black Small
18:54:58.6 21/10/2006: Creating Game Font Faded
18:54:58.6 21/10/2006: Creating Title Font
18:54:58.6 21/10/2006: Restoring Title Font From Cache
18:54:58.7 21/10/2006: Fonts Created Succesfully
18:54:58.7 21/10/2006: Initialising Windows Media Player Component
18:54:58.8 21/10/2006: MAME Path is: G:\[1] MAME
18:54:58.8 21/10/2006: MAME EXE file is: mamep.exe
18:54:58.8 21/10/2006: ROM Paths are: G:\[A] MAME FILES\ROMS;G:\[A] MAME FILES\CHDS
18:54:58.8 21/10/2006: Catver.ini is located at: C:\Program Files\GameEx\DATA\catver.ini
18:54:58.8 21/10/2006: controls.ini is located at: C:\Program Files\GameEx\data\controls.ini
18:54:58.8 21/10/2006: History.dat is located at: C:\Program Files\GameEx\DATA\history.dat
18:54:58.8 21/10/2006: nplayers.ini is located at: C:\Program Files\GameEx\DATA\nplayers.ini
18:54:58.8 21/10/2006: MAMEinfo.dat is located at: C:\Program Files\GameEx\DATA\mameinfo.dat
18:54:58.8 21/10/2006: Loading Controls.ini map file
18:54:58.8 21/10/2006: Snap Path is: G:\[A] MAME FILES\SNAPSSHOTS
18:54:58.8 21/10/2006: AVI Snap Path is: G:\[A] MAME FILES\VIDEOS
18:54:58.8 21/10/2006: Flyer Path is: G:\[A] MAME FILES\FLYERS
18:54:58.8 21/10/2006: Cabinet Path is: G:\[A] MAME FILES\CABINETS
18:54:58.8 21/10/2006: Title Path is: G:\[A] MAME FILES\TITLES
18:54:58.8 21/10/2006: Panel Path is: G:\[A] MAME FILES\CONTROL PANELS
18:54:58.8 21/10/2006: Icon Path is: G:\[A] MAME FILES\ICONS
18:54:58.8 21/10/2006: Marquee Path is: G:\[A] MAME FILES\MARQUEES
18:54:58.8 21/10/2006: Using Ultimarc AradeVGA
18:54:58.8 21/10/2006: MAME CMD options: -video ddraw -nohwstretch
18:54:58.8 21/10/2006: Attempting to load game list
18:54:58.9 21/10/2006: Loading last used Game List
18:54:58.9 21/10/2006: Setting Music Volume
18:54:58.9 21/10/2006: Creating DirectSound Device
18:54:58.9 21/10/2006: Trying: Périphérique audio principal
18:54:58.9 21/10/2006: Loading Sound Files
18:54:59.0 21/10/2006: DirectSound Device Created Successfully
18:54:59.0 21/10/2006: Creating ICONS
18:54:59.0 21/10/2006: Restoring Cached ICONS from File
18:54:59.1 21/10/2006: Gamepad/Joystick disabled
18:54:59.1 21/10/2006: Initialising DirectInput for Keyboard support
18:54:59.2 21/10/2006: Playing Startup Video
18:54:59.8 21/10/2006: Playing intro sound file
18:54:59.8 21/10/2006: Initializing MCE Remote
18:54:59.9 21/10/2006: Initialization OK! Starting GameEx!
18:54:59.9 21/10/2006: Testing Main Loop Once: Processing Frame
18:55:00.1 21/10/2006: Testing Main Loop Once: Main Loop ran successfully
18:55:09.1 21/10/2006: 21 Consecutive Exceptions Occured: Exiting
18:55:09.1 21/10/2006: First Exception:
18:55:09.1 21/10/2006: Erreur de l'application.
18:55:09.1 21/10/2006: at Microsoft.DirectX.DirectDraw.Surface.DrawInternal(tagRECT* destRectangle, Surface sourceSurface, tagRECT* srcRectangle, DrawFlags flags, DrawEffects& bltEffects)
18:55:09.1 21/10/2006: at Microsoft.DirectX.DirectDraw.Surface.Draw(Rectangle destRectangle, Surface sourceSurface, Rectangle srcRectangle, DrawFlags flags)
18:55:09.1 21/10/2006: at GameEx.GameEx.mainform.DrawMenuImages(Boolean over)
18:55:09.1 21/10/2006: at GameEx.GameEx.mainform.DisplayFrame()
18:55:09.1 21/10/2006: Last Exception:
Thanks in advance
Jontox
Hi,
I've pointed out the error...
1) The problem is related to your theme amos_82
What is the minimal resolution to which I can use it in gameEx ? 640*480 ???
I've an ARCADEVGA with BETSON 27'' Multisynch
Default BluEx 640*480 gives me no issue at all.
What is strange is that if I try to select in the configurator "Switch to resolution" with 640*480 specified
Your theme appeared as out of the screen, I am only seeing the first quarter of the picture (top left hand corner).
Why are new theme not mentioning resolution in the Theme selection picker ?
2) The problem with using lists in all themes were related to videos.
It seems that GameEx froze when trying to display video of the game selected (Yes I have ffdshow installed).
3) Run in ArcadeMode (Turn ArcadeMode on even if displaying at a suitable resolution).
I can't see the point of that setting ?
It means that if 800*600 is fored it will run in arcademode either ? but what is arcademode exactly ?
4) In the configurator, the shift key for Alphapaging and Volume is different, but I have seen some control instruction sticker done by member of the forum on which it seems that is only one shift buttons and that volume up and down is done with 2p Stick. ? How can it be ?
5) If I select Mame32gui emulator to be run under Gameex, do I have to specify -video ddraw -nohmwstrech in Gameex if there are selected in Mame32gui ?
6) Mame32 !Plus is listing 6286 games where Gameex just 5240 games (No filter, adult and mahong games allowed). I've seen this issue quite a number of time in the forum but no real answer.
Maybe Tom should review the code behing the listing games function...
... more questions to come :-)
Thanks in advance for your help
See you soon
Jontox
