Hey All.  I'm able to get my pindmdv3 to work with mirroring (using --fx3-legacy) in FX3 (using Freezy 1.8).  Is there a way I can do it using memory grabber?  My command line for FX3 is noted below.  Also, I'm running dmdext.exe as admin.
mirror --source=pinballfx3 -q -d pindmdv3 -p com3 --fps 60 --pinup PINUP\[TABLEFILE]
Thanks!
This is my dmdext line for starting fx3
 dmdext.exe mirror --source=pinballfx3 --no-virtual --quit-when-done -d pindmdv3
it is the memory grabber and works for me (dmdext 1.81)
Thanks.  I'm curious, you don't need to tell your dmdext what port your pindmdv3 is at, or set the fps (my pindmdv2 flickered back when I used to use it, until I set the fps)?
Indeed. My com port is 5, but it autodetects it. Previous version of dmdext also detect the device type. Never had to set the fps. I think 60fps for a led display is pretty high.
I created fx3 videos that can be used in the front end, but between 10 and 20 fps
I hope this helps
