Hi, i've seen there's a solution to play roms withs winkawaks that's a geat solution , but where can'i download the kill_winkawaks.exe ? i'don't find it on any nologic post...
regards
Here you go...probably not the same as the original since I deleted it...but should be close enough...tho i don't have my main system right now in which to test things...but source code is included to fix things if there is a problem.
I still have the original if you want it nologic. I actually haven't tried the new version. I dl'ed it btw just incase. The orignal version has worked fine for me. I'm scared to break something. :D
