when pressing ~ you can change some rom options like volume ,brightness and gamma. turning the gamma up a bit helps a lot with some games on my arcade monitor but when i exit from the game it does not save what ive tweaked? what am i doing wrong? and is there a way to save the game last state? like if i am far into a game and want to finish it another day where i left off.
thanks
Thats a feature of MAME - not GAMEEX
I dont see a way to save that (per rom) in Mame
*doesnt mean it cant be done
Might want to ask that question at www.mame.net
H08. Can I save my game and resume it later?
This feature is being slowly implemented because it can be helpful to MAME developers. It's an especially complex feature, so only a small portion of the drivers support it. If you want to try it, press Shift-F7 and any key to save a state, and F7 and the key you previously pressed to load a state. This way you can save more than one state, for example by pressing A, B, C, etc. after the save or load state key. However, don't expect all drivers to work properly with this.
