Forgive me .. but is this normal ??? pinbal x is owned .. I put the post in a more explicit way because I suppose it is not well explained to me .. and I apologize ... 1) there are no verses of what or how I set it .. if I restart the setting some settings arbitrarily change ... 2) given the problem of point 1 I faced the bull by the horns .. and that is I went to change the settings of pinball x directly in the config folder of the notepad .. well everything works only that then when I restart .. my settings disappear .. and the default ones return ... and they are made several times .. this happens to me when i want to place the dmd ..
any of you have these problems or have no idea how they can solve it ??? thank you in advance
It sounds like your pinballx ini file is being overwritten, the only time i've seen that is when not doing a clean shutdown. How are you closing pinballx? (are you just turning the pc off?!)
Please also attach your pinballx log and ini (both versions, after your edit, and after 'reset') files. Thanks.
Are you using a shadow volume copy to backup your system or a qnap or synology type of backup ?
I use Synology and see some file getting back after modification.
